User:Bertrik Sikken
| Name | Bertrik Sikken |
| Nick | bertrik |
| Tagline | heb ik niet |
- radio stuff, in particular software-defined radio, LoRa networks
- citizen science and open data (particulate matter measurement, noise, water quality)
Meshcore as citizen science data transport
Meshcore is basically a network of repeaters for lora messages with a specific setting. The idea is to use a citizen science sensor with a LoRa radio to uplink citizen science data through this repeater network, get the data repeated, then pick it up using a special kind of node is connected to the internet (e.g. MQTT) that forwards the data to a collection server for further processing.
The LoRa setting used almost universally in the Netherlands now is the EU/UK setting:
- 869.618 / SF8 / BW62.5 / CR8
- header enabled
- sync word XXXX
Description of the on-the-air message: https://gist.github.com/recrof/ca7ccff28c43d1b6bf7e55ce5159100b
Meshcore repeaters a relatively "dumb", they just forward anything that resembles a packet (they can't inspect the encrypted part).
The idea is basically:
- Sensor first starts up, sends a kind of discovery packet in "flood" mode. This kind of packet is flooded over the entire network.
- When the discovery packet reaches a special internet-connected gateway, the backend software receives it and returns a kind of acknowledgement packet back over the (best) path that it received the message on. When this reaches the sensor node, the sensor node knows the most efficient way to reach the gateway node and uses a "direct" packet. Every now and then it expects a kind of acknowledgement packet back from the server, to know that messages are still coming through. This is actually a bit similar to how LoRaWAN works.
investigate thread/matter
- check out openthread
git clone https://github.com/openthread/openthread.git cd openthread git submodule update --init --recursive
- Prepare development environment:
scripts/bootstrap
- Build it:
Thread on ESP32:
- on ESP32 C6 https://gist.github.com/gtxaspec/d26198daadfb0a8b0a0edeae2d3fd58f
- https://github.com/espressif/esp-thread-br
- https://github.com/espressif/esp-idf/tree/master/examples/openthread/ot_rcp
action lsc stekker
sipeed maix dock
rfid keyfob
- firmware github:
advanced lidars for bat detection
livox:
cubecell meshtastic motion detector
configure multitech outdoor gateway
esp32 wtf
kakofonie counter
Stuff to figure out:
- can it run on an ESP32?
- make a prototype
hypno toad
wasbeer / kat classifier
Nespresso brew counter
Remote bat box monitor
Idea:
- challenges:
- design
- hardware
KNMI API
WeAct CH55x board
Zigbee device with esp32
Cameratoezicht in Gouda
SolarEdge
Stookalert
Implementatie:
Resources:
With result:
event: state
Use an audiomoth for this.
ESP32 C3
Flexible LED ticker
Washing machine API
TinyML
Bat box busy signal
Super tiny RFID
Specification:
Actually smart boiler
Alternatives:
Receiving gas meters
Interesting leads:
Multi-network wifi manager
Interesting candidates:
Automated bat counting
What I definitely can do:
Showstoppers:
Open work:
Interesting stuff:
- https://thingsix.com/
Interesting stuff in GATT:
- service 0xC760
- 0x23
- length byte
- 0x10 0x04 fixed header
- 0x00 is ...
ribbon tweeter for bat audio
Someone gave me this idea:
3d glasses
A tear-down here:
Interesting documents:
Waterniveaumeter
Idee:
Online bat detector
- inexpensive ep2c5t144 board
mini word clock in dutch
Simple Doppler motion sensors
AVR Arduino sample rate
Indoor radar speed sign
