User:Bertrik Sikken
User info Bertrik Sikken
Name Bertrik Sikken
Nick bertrik
Tagline heb ik niet
 Project Status
FrontDoorDisplayAbandoned
HabAlertAppAbandoned
ISSOAbandoned
IbmPosDisplayAbandoned
Pico TrackersAbandoned
RadarOnAStickAbandoned
WifiLampAbandoned
A4PaperDispenserCompleted
CJMCU-811Completed
CO2MeterHackingCompleted
CrawlSpaceSensorCompleted
DecodingLoraCompleted
DustSensorCompleted
ElectronicLoadCompleted
EspNowSkipCompleted
IntakefancontrollerCompleted
LichtKrantCompleted
LoRaGatewayCompleted
LoraBatBoxCompleted
LoraWanNodeCompleted
MHZ19Completed
MainsFrequencyCompleted
MiniSTM32F103ZECompleted
PowerLightCompleted
RC522HackingCompleted
RevRadioCompleted
STM32Completed
Secure iButtonCompleted
SoilHumiditySensorCompleted
StofAnanasCompleted
StofradarCompleted
TTNHABBridgeCompleted
VINDRIKTNINGCompleted
ZigbeeCoordinatorCompleted
Sensor-data-bridgeCompleted
AntiLostIn progress
AudioMothIn progress
BT785In progress
CubeCellIn progress
EspAudioSensorIn progress
Esp32camIn progress
FMCWRadarIn progress
Its-g5In progress
KaraburanIn progress
LoRa-E5-miniIn progress
LoraWanDustSensorIn progress
MainsFrequency2.0In progress
MeshtasticIn progress
Msi2500SDRIn progress
... further results
TheThingsNetwork gateway stats
Goal: provide insight in local LoRaWAN spectrum use by watching traffic received on gateways
Source code: https://github.com/bertrik/ttn-gateway-collector
Idea:
  • now with TTN v3 it is possible to get a stream of JSON events, one for each packet received by a gateway
  • write an application that subscribes to the gateway events of participating gateways in an area (say a city)
  • application collects data, calculates frequency uses, identifies how much airtime each device uses, etc.
  • to enable viewing the stream, you need just a) the id of the gateway b) an API key with right 'RIGHT_GATEWAY_TRAFFIC_READ'
  • gateway owners that want to participate create an API key and share this with the application
Example of getting the data:
curl https://eu1.cloud.thethings.network/api/v3/events \
    -H "Authorization: Bearer NNSXS.3ITPM54KRJHDX6RXCCKZXFTXA4WFVIOMCTDVANY.blabla" \
    -H "Accept: text/event-stream" \
    --data '{"identifiers":[{"gateway_ids":{"gateway_id":"technolution-gouda"}}]}'
Result:
{"result":{"name":"gs.up.receive","time":"2021-09-30T21:26:30.611720036Z","identifiers":[{"gateway_ids":{"gateway_id":"technolution-gouda","eui":"008000000000B8B6"}}],"data":{"@type":"type.googleapis.com/ttn.lorawan.v3.UplinkMessage","raw_payload":"ACfYjArJyEX048UA8Y/Vs3AOHvhLkqU=","payload":{"m_hdr":{},"mic":"+EuSpQ==","join_request_payload":{"join_eui":"F445C8C90A8CD827","dev_eui":"70B3D58FF100C5E3","dev_nonce":"1E0E"}},"settings":{"data_rate":{"lora":{"bandwidth":125000,"spreading_factor":7}},"coding_rate":"4/5","frequency":"868300000","timestamp":1050976243,"time":"2021-09-30T21:26:30.600358Z"},"rx_metadata":[{"gateway_ids":{"gateway_id":"technolution-gouda","eui":"008000000000B8B6"},"time":"2021-09-30T21:26:30.600358Z","timestamp":1050976243,"rssi":-100,"channel_rssi":-100,"snr":10.2,"location":{"latitude":52.01811525353214,"longitude":4.708444422836441,"altitude":25,"source":"SOURCE_REGISTRY"},"uplink_token":"CiAKHgoSdGVjaG5vbHV0aW9uLWdvdWRhEggAgAAAAAC4thDzv5L1AxoMCIbX2IoGEIHF0aMCILiaw5jLlyw=","channel_index":1}],"received_at":"2021-09-30T21:26:30.611607169Z","correlation_ids":["gs:conn:01FGPHV2RWTBC4AG336QP0E10K","gs:uplink:01FGW9M1EKR7HYRGPD0WQ0EY1B"]},"correlation_ids":["gs:conn:01FGPHV2RWTBC4AG336QP0E10K","gs:uplink:01FGW9M1EKR7HYRGPD0WQ0EY1B"],"origin":"ip-10-100-5-46.eu-west-1.compute.internal","context":{"tenant-id":"CgN0dG4="},"visibility":{"rights":["RIGHT_GATEWAY_TRAFFIC_READ"]},"unique_id":"01FGW9M1EKEJR1Z951GZGZ2GQD"}}
ribbon tweeter for bat audio
3d glasses
A tear-down here:
Interesting documents:
Waterniveaumeter
Idee:
Online bat detector
Blood pressure meter hacking
mini word clock in dutch
Simple Doppler motion sensors
AVR Arduino sample rate
GPS repeater
Plan:
Indoor radar speed sign
