User:Bertrik Sikken
| Name | Bertrik Sikken |
| Nick | bertrik |
| Tagline | heb ik niet |
Zo'n ding 3d printen: https://twitter.com/MeOwOser/status/1250879531830915073
Smart radar modules
Nowadays you can find radar modules with integrated processor.
There's an FMCW radar available. These things can sense motion and range, interesting for tracking bats near a roost?
Interesting links:
- https://www.acconeer.com/products has a list of smart radar modules
- https://learn.sparkfun.com/tutorials/getting-started-with-the-a111-pulsed-radar-sensor/all
Other radar stuff:
- Yh-24g04, a 24 GHz quadrature doppler radar (no CPU), has modulation input, for about E16,-
- DM-39, a 24 GHz quadrature doppler radar with CPU for about E32,-. The page shows a SRK1101 radar, with I/Q outputs and tune input. Mentions Cortex M0.
- DM-19, a 24 GHz quadrature doppler radar with CPU for about E48,-. Appears similar in possibilities to DM-39. Mentions Cortex M3/M4 processor.
- another DM-19, 24 GHz quadrature doppler radar
- FM-42, a 24 GHz FMCW radar with CPU for about USD107,-
- 182MOD, a module outputting speed for about USD28,- appears to use a 5-pin radar (Vcc,Gnd,I,Q,tune?)
Blood pressure meter hacking
- bluetooth GATT profile for blood pressure monitors https://www.bluetooth.com/specifications/gatt/
- hacking the UART on an Omron RS8 : https://blog.adafruit.com/2016/05/26/hacking-uart-to-an-omron-rs8-blood-pressure-sphygmomanometer/
- hacking a blood pressure monitor by monitoring i2c traffic to the EEPOM: https://www.edusteinhorst.com/hacking-a-blood-pressure-monitor/
- inexpensive ep2c5t144 board
- transmit our own control signal, to control a quadcopter from something different than the manual remote control, e.g. automatic control
- receive the control signal, so the manual remote control that comes with a quadcopter can be used to steer other things (like a model car).
mini word clock in dutch
Simple Doppler motion sensors
AVR Arduino sample rate
GPS repeater
Plan:
Indoor radar speed sign
