User:Bertrik Sikken
User info Bertrik Sikken | |
Name | Bertrik Sikken |
Nick | bertrik |
Tagline | heb ik niet |
Zo'n ding 3d printen: https://twitter.com/MeOwOser/status/1250879531830915073
Smart radar modules
Nowadays you can find radar modules with integrated processor.
There's an FMCW radar available. These things can sense motion and range, interesting for tracking bats near a roost?
Interesting links:
- https://www.acconeer.com/products has a list of smart radar modules
- https://learn.sparkfun.com/tutorials/getting-started-with-the-a111-pulsed-radar-sensor/all
Other radar stuff:
- https://nl.aliexpress.com/item/33063598872.html an inexpensive radar module combined with some stm32 controller. The module outputs direction and speed of moving things. The connector on it makes the programming pins available. Hoping to find the source code so I can modify it.
- Yh-24g04, a 24 GHz quadrature doppler radar (no CPU), has modulation input, for about E16,-
- DM-39, a 24 GHz quadrature doppler radar with CPU for about E32,-. The page mentions a SRK1101 radar, with I/Q outputs and tune input.
- DM-19, a 24 GHz quadrature doppler radar with CPU for about E48,-
- FM-42, a 24 GHz FMCW radar with CPU for about US107,-
Blood pressure meter hacking
- bluetooth GATT profile for blood pressure monitors https://www.bluetooth.com/specifications/gatt/
- hacking the UART on an Omron RS8 : https://blog.adafruit.com/2016/05/26/hacking-uart-to-an-omron-rs8-blood-pressure-sphygmomanometer/
- hacking a blood pressure monitor by monitoring i2c traffic to the EEPOM: https://www.edusteinhorst.com/hacking-a-blood-pressure-monitor/
- inexpensive ep2c5t144 board
- transmit our own control signal, to control a quadcopter from something different than the manual remote control, e.g. automatic control
- receive the control signal, so the manual remote control that comes with a quadcopter can be used to steer other things (like a model car).
mini word clock in dutch
Simple Doppler motion sensors
AVR Arduino sample rate
GPS repeater
Plan:
Indoor radar speed sign
