User:Bertrik Sikken
| Name | Bertrik Sikken |
| Nick | bertrik |
| Tagline | heb ik niet |
NB-IoT module
Ordered a SIM7020 and a starter kit, see: https://www.hackster.io/voske65/arduino-nb-iot-with-sim7020-and-t-mobile-027f8f
I plan to experiment with this kind of network connectivity for perhaps a bat activity monitor or air quality monitoring.
ESP now intercom
Idea:
- create a simple battery powered intercom transmitter
- sample audio from a digital microphone, like the INMP441
- send it to another ESP using the esp-now protocol, see https://hackaday.io/project/166868-my-attempt-at-an-esp-now-mesh/log/166398-072419-maximum-transmission-throughput-of-esp-now
- play it back on the other ESP, using https://github.com/earlephilhower/ESP8266Audio
Implement code for samenmeten API
https://www.samenmetenaanluchtkwaliteit.nl/dataportaal/api-application-programming-interface
ESP mesh networking
The makers of the ESP8266 provide a software stack to run a 'mesh network' between ESP8266 nodes. As I understand this allows several ESP devices to join together and create a kind of dynamic network.
What is not quite clear is how this is all modelled. For example, do devices have addresses. And if so, what kind? Does this thing run on top of TCP/IP, or does it run on raw wifi frames? Can you designate one particular node as the 'root node' and let it bridge communication with other networks? Can you do transient low-power communication with the mesh network, e.g. wake-up, send a message, go back to sleep?
Links:
- inexpensive ep2c5t144 board
STM32 stlink V2
- transmit our own control signal, to control a quadcopter from something different than the manual remote control, e.g. automatic control
- receive the control signal, so the manual remote control that comes with a quadcopter can be used to steer other things (like a model car).
mini word clock in dutch
Simple Doppler motion sensors
AVR Arduino sample rate
Bat call cleaner
- Apply a high-pass filter to get rid of non-ultrasonics like speech, say at 10 kHz
- Convert the signal into a complex analytic signal, by creating the imaginary part using a Hilbert transform.
- The Hilbert transform can be approximated by a FIR filter of appropriate length to get the desired bandwidth.
- Split the complex signal into an instantaneous frequency and amplitude.
- The frequency is determined by differentiating the instantaneous phase (inverse tangens i/q).
- The amplitude is determined by calculating the norm of the complex signal (sqrt of i^2 + q^2)
- Average/low-pass the frequency component, say at 0.1 ms intervals. Do the same to the amplitude.
- Re-synthesize the signal s using the simple model s = A.sin(2.pi.t/f) where A is amplitude, t is time and f is frequency, interpolating A and f.
Alternative:
- chop the signal up in segments of (say) 100 ms and determine the total energy content in each segment
- choose the quietest segment and use this as a "background noise template"
- perform a fourier analysis on the template
- reduce the noise on the signal using the template:
- for each segment, apply for each frequency an attenuation based on the signal level compared to the template level
- resynthesize from fourier back into the time domain using an overlap-add method
ESP8266 as modbus master:
GPS repeater
Plan:
Indoor radar speed sign
