User:Bertrik Sikken
User info Bertrik Sikken
Name Bertrik Sikken
Nick bertrik
Tagline heb ik niet
 Project Status
FrontDoorDisplayAbandoned
HabAlertAppAbandoned
ISSOAbandoned
IbmPosDisplayAbandoned
Pico TrackersAbandoned
RadarOnAStickAbandoned
WifiLampAbandoned
A4PaperDispenserCompleted
CJMCU-811Completed
CO2MeterHackingCompleted
CrawlSpaceSensorCompleted
DecodingLoraCompleted
DustSensorCompleted
ElectronicLoadCompleted
EspNowSkipCompleted
IntakefancontrollerCompleted
LichtKrantCompleted
LoRaGatewayCompleted
LoraBatBoxCompleted
LoraWanNodeCompleted
MHZ19Completed
MainsFrequencyCompleted
MiniSTM32F103ZECompleted
PowerLightCompleted
RC522HackingCompleted
RevRadioCompleted
STM32Completed
Secure iButtonCompleted
SoilHumiditySensorCompleted
StofAnanasCompleted
StofradarCompleted
TTNHABBridgeCompleted
VINDRIKTNINGCompleted
ZigbeeCoordinatorCompleted
Sensor-data-bridgeCompleted
AntiLostIn progress
AudioMothIn progress
BT785In progress
CubeCellIn progress
EspAudioSensorIn progress
Esp32camIn progress
FMCWRadarIn progress
KaraburanIn progress
LoRa-E5-miniIn progress
LoraWanDustSensorIn progress
MainsFrequency2.0In progress
MeshtasticIn progress
Msi2500SDRIn progress
MysteryLidarIn progress
... further results
SHA badge e-ink Arduino driver
The plan is to be able to use the SHA badge e-ink driver directly from Arduino (no micropython).
ESP mesh networking
The makers of the ESP8266 provide a software stack to run a 'mesh network' between ESP8266 nodes. As I understand this allows several ESP devices to join together and create a kind of dynamic network.
What is not quite clear is how this is all modelled. For example, do devices have addresses. And if so, what kind? Does this thing run on top of TCP/IP, or does it run on raw wifi frames? Can you designate one particular node as the 'root node' and let it bridge communication with other networks? Can you do transient low-power communication with the mesh network, e.g. wake-up, send a message, go back to sleep?
Links:
Battery-powered ESP8266 nodes
These ESP8266 boards with 18650 battery look like nice candidates for a low-power standalone sensor node.
Measured battery current: the board still draws about 14 mA in deep sleep mode. The ESP8266 itself probably draws less than 1 mA in deep sleep mode. This totally ruins any low-power possibilities, draining a typical 18650 in about 100 hours (about 4 days).
There is an AMS1117 chip onboard, possibly this is the source of the high idle current and perhaps we can replace it.
AI on Raspberry Pi
Particulate matter sensor at RevSpace
P1 meter on MQTT
The plan is to push the P1-data from my smart meter onto MQTT and then have other things listening on it and perhaps do actual smart things with this data.
I have a Kaifa M105a, more info about smart meters: http://domoticx.com/p1-poort-slimme-meter-hardware/
This could be as simple as an ESP8266-based microcontroller (Wemos D1 mini) just listening on the P1 port and forwarding the data. Unfortunately the port does not appear to provide enough power for the microcontroller, and I have no socket to plug in a power supply in the metering closet.
The plan is:
  • I have a cool housing for this, which already has a connection for the antenna and a bunch of solar cells.
  • Use with an SDS011 for airborne particulate measurement
For the embedded software:
  • use Arduino framework
  • use Arduino LMIC library for TTN communication
  • use Arduino SDS011 libs from luftdaten.info?
For the forwarding software:
  • use Java to listen on TTN MQTT
  • use Java code I've already written to forward it to luftdaten API
  • all sensors send to the same TTN 'application'
SpaceBike tracker
The idea is to use an ESP32-LoRa board + GPS to track the location of the SpaceBike. It sends periodic position updates of the location using radio to TheThingsNetwork. Power consumption is not really an issue since it's an e-bike and has a huge onboard battery, but is still expected to be fairly low anyway (milliamps).
For the privacy-conscious, it can be switched on/off. Perhaps we can do other fun/useful stuff too:
  • send data about the state of the battery.
  • capture WiFi APs for projects like https://wigle.net/
  • measure air pollution vs position
  • collect cool stats about usage, e.g. distance achieved, hours spent, etc.
STM32 stlink V2
HC-06 stuff
To set odd parity:
AT+PO
WiFi "top"
    • the unique MAC address
Operations on this table:
Possible issues:
mini word clock in dutch
Local date calculation:
Simple Doppler motion sensors
AVR Arduino sample rate
Example C code
#define BUF_SIZE    16
static void ISR(void)
    static int16_t lowpass = 0;
    static int32_t sum = 0;
    static bool even = false;
    int16_t input, signal, mixed;
    input = ....
    // HPF input signal
    signal = input - lowpass;
    lowpass += signal >> 4;
    // multiply by carrier
    even = !even;
    sum += mixed ;
    sum -= buffer[index];
    buffer[index] = mixed ;
    // output LPF as 8-bit number
    out = sum >> 7;
Bat call cleaner
Alternative:
ESP8266 as modbus master:
GPS repeater
Plan:
Indoor radar speed sign
