User:Bertrik Sikken
Revision as of 18:05, 21 August 2018 by Bertrik Sikken (talk | contribs)
User info Bertrik Sikken
Name Bertrik Sikken
Nick bertrik
Tagline heb ik niet
 Project Status
FrontDoorDisplayAbandoned
HabAlertAppAbandoned
ISSOAbandoned
IbmPosDisplayAbandoned
Pico TrackersAbandoned
RadarOnAStickAbandoned
WifiLampAbandoned
A4PaperDispenserCompleted
CJMCU-811Completed
CO2MeterHackingCompleted
CrawlSpaceSensorCompleted
DecodingLoraCompleted
DustSensorCompleted
ElectronicLoadCompleted
EspNowSkipCompleted
IntakefancontrollerCompleted
LichtKrantCompleted
LoRaGatewayCompleted
LoraBatBoxCompleted
LoraWanNodeCompleted
MHZ19Completed
MainsFrequencyCompleted
MiniSTM32F103ZECompleted
PowerLightCompleted
RC522HackingCompleted
RevRadioCompleted
STM32Completed
Secure iButtonCompleted
SoilHumiditySensorCompleted
StofAnanasCompleted
StofradarCompleted
TTNHABBridgeCompleted
VINDRIKTNINGCompleted
ZigbeeCoordinatorCompleted
Sensor-data-bridgeCompleted
AntiLostIn progress
AudioMothIn progress
BT785In progress
CubeCellIn progress
EspAudioSensorIn progress
Esp32camIn progress
FMCWRadarIn progress
Its-g5In progress
KaraburanIn progress
LoRa-E5-miniIn progress
LoraWanDustSensorIn progress
MainsFrequency2.0In progress
MeshtasticIn progress
Msi2500SDRIn progress
... further results
LoRa node for airborne particulate matter
The idea is to use an SDS011 particulate matter sensor and make it send its measurement data over LoRa to TheThingsNetwork (TTN). An application listens on the TTN MQTT stream and forwards it to luftdaten.
I have a cool housing for this, which already has a connection for the antenna and a bunch of solar cells. Cayenne looks like a nice way of encoding the measurement values.
SpaceBike tracker
The idea is to use an ESP32-LoRa board + GPS to track the location of the SpaceBike. It sends periodic position updates of the location using radio to TheThingsNetwork. Power consumption is not really an issue since it's an e-bike and has a huge onboard battery, but is still expected to be fairly low anyway (milliamps).
For the privacy-conscious, it can be switched on/off. Perhaps we can do other fun/useful stuff too:
  • send data about the state of the battery.
  • capture WiFi APs for projects like https://wigle.net/
  • measure air pollution vs position
  • collect cool stats about usage, e.g. distance achieved, hours spent, etc.
QR codes for money transfer
The following document is a short description on how to encode a money transfer request in a QR code: https://www.europeanpaymentscouncil.eu/document-library/guidance-documents/quick-response-code-guidelines-enable-data-capture-initiation
The SEPA QR code is basically just a set of text lines with predefined meaning, describing the amount and the beneficiary.
https://qrcode.tec-it.com/en/sepa https://en.m.wikipedia.org/wiki/EPC_QR_code
STM32 stlink V2
ESP32 LoRa
I have one of these ESP32 TTGO LoRa boards.
First thing I tried:
Some more promising links:
HC-06 stuff
To set odd parity:
AT+PO
WiFi "top"
    • the unique MAC address
Operations on this table:
Possible issues:
mini word clock in dutch
Local date calculation:
Understanding LoRa
Simple Doppler motion sensors
AVR Arduino sample rate
Example C code
#define BUF_SIZE    16
static void ISR(void)
    static int16_t lowpass = 0;
    static int32_t sum = 0;
    static bool even = false;
    int16_t input, signal, mixed;
    input = ....
    // HPF input signal
    signal = input - lowpass;
    lowpass += signal >> 4;
    // multiply by carrier
    even = !even;
    sum += mixed ;
    sum -= buffer[index];
    buffer[index] = mixed ;
    // output LPF as 8-bit number
    out = sum >> 7;
Bat call cleaner
Alternative:
ESP8266 as modbus master:
GPS repeater
Plan:
Indoor radar speed sign
