User:Bertrik Sikken
User info Bertrik Sikken
Name Bertrik Sikken
Nick bertrik
Tagline heb ik niet
 Project Status
FrontDoorDisplayAbandoned
HabAlertAppAbandoned
ISSOAbandoned
IbmPosDisplayAbandoned
Pico TrackersAbandoned
RadarOnAStickAbandoned
WifiLampAbandoned
A4PaperDispenserCompleted
CJMCU-811Completed
CO2MeterHackingCompleted
CrawlSpaceSensorCompleted
DecodingLoraCompleted
DustSensorCompleted
ElectronicLoadCompleted
EspNowSkipCompleted
IntakefancontrollerCompleted
LichtKrantCompleted
LoRaGatewayCompleted
LoraBatBoxCompleted
LoraWanNodeCompleted
MHZ19Completed
MainsFrequencyCompleted
MiniSTM32F103ZECompleted
PowerLightCompleted
RC522HackingCompleted
RevRadioCompleted
STM32Completed
Secure iButtonCompleted
SoilHumiditySensorCompleted
StofAnanasCompleted
StofradarCompleted
TTNHABBridgeCompleted
VINDRIKTNINGCompleted
ZigbeeCoordinatorCompleted
Sensor-data-bridgeCompleted
AntiLostIn progress
AudioMothIn progress
BT785In progress
CubeCellIn progress
EspAudioSensorIn progress
Esp32camIn progress
FMCWRadarIn progress
Its-g5In progress
KaraburanIn progress
LoRa-E5-miniIn progress
LoraWanDustSensorIn progress
MainsFrequency2.0In progress
MeshtasticIn progress
Msi2500SDRIn progress
... further results
Understand Bluetooth AP
I'm trying to understand how to set up a bluetooth AP on a basic Linux system, such that you can connect to it using an Android phone or tablet.
The idea is that there is some kind of useful application running on the Linux system, and that the "app" on the tablet/phone provides the user interface, connecting to the Linux system using REST.
Possible useful links:
My starting point is:
  • a Yocto based Linux distribution
  • a Linux 4.1 kernel
  • Bluez 5
Understanding the various Linux drivers and tools in the Linux bluetooth stack
  • btusb: the Linux kernel driver module for many USB/bluetooth adapters, 'modprobe'-ing this module also magically takes care of downloading firmware needed
  • hciconfig, low-level configuration utility for manipulating a bluetooth controller. A bit like ifconfig, it can bring the interface up or down, set options, etc.
  • hcitool, yet another utility to perform low-level blue operations, like querying the name of paired devices
  • bluetoothd, the bluetooth daemon
  • bluetoothctl, a more high-level configuration utility, basically a user interface towards bluetoothd as I understand it.
  • NAP: network access protocol
  • PAN: personal area network
  • BNEP: bluetooth network encapsulation protocol
mini word clock in dutch
Local date calculation:
Understanding LoRa
Simple Doppler motion sensors
Rust
Investigate the rust language.
ESP32
I have a Wemos "LOLIN32 V1.0.0" ESP32 board, play with it. Discover bluetooth capabilities, low power modes. Compare it with ESP32.
