User:Bertrik Sikken
User info Bertrik Sikken
Name Bertrik Sikken
Nick bertrik
Tagline heb ik niet
  • citizen science, particulate matter measurement, noise (future)
 Project Status
FrontDoorDisplayAbandoned
HabAlertAppAbandoned
ISSOAbandoned
IbmPosDisplayAbandoned
Pico TrackersAbandoned
RadarOnAStickAbandoned
WifiLampAbandoned
A4PaperDispenserCompleted
CJMCU-811Completed
CO2MeterHackingCompleted
CrawlSpaceSensorCompleted
DecodingLoraCompleted
DustSensorCompleted
ElectronicLoadCompleted
EspNowSkipCompleted
IntakefancontrollerCompleted
LichtKrantCompleted
LoRaGatewayCompleted
LoraBatBoxCompleted
LoraWanNodeCompleted
MHZ19Completed
MainsFrequencyCompleted
MiniSTM32F103ZECompleted
PowerLightCompleted
RC522HackingCompleted
RevRadioCompleted
STM32Completed
Secure iButtonCompleted
SoilHumiditySensorCompleted
StofAnanasCompleted
StofradarCompleted
TTNHABBridgeCompleted
VINDRIKTNINGCompleted
ZigbeeCoordinatorCompleted
Sensor-data-bridgeCompleted
AntiLostIn progress
AudioMothIn progress
BT785In progress
CubeCellIn progress
EspAudioSensorIn progress
Esp32camIn progress
FMCWRadarIn progress
Its-g5In progress
KaraburanIn progress
LoRa-E5-miniIn progress
LoraWanDustSensorIn progress
MainsFrequency2.0In progress
MeshtasticIn progress
Msi2500SDRIn progress
... further results
SSE webserver on ESP32
I want to be able to server server-sent-events from an ESP32C3 web server
The plan is to use an ESP32C3 to measure mains grid frequency (phase actually) and make it available over an SSE web URL. Another ESP-device can then subscribe to this and display the phase and/or the frequency on an RGB LED ring for example.
WeAct CH55x board
Cheap little boards, using the same chip as used in USB-serial converters.
Zigbee device with esp32
Cameratoezicht in Gouda
SolarEdge
Stookalert
Implementatie:
Resources:
With result:
 event: state
Use an audiomoth for this.
ESP32 C3
Flexible LED ticker
Washing machine API
TinyML
Bat box busy signal
Super tiny RFID
Specification:
Actually smart boiler
Alternatives:
Receiving gas meters
Interesting leads:
Multi-network wifi manager
Interesting candidates:
Automated bat counting
What I definitely can do:
Showstoppers:
Open work:
Interesting stuff:
Interesting stuff in GATT:
  • service 0xC760
  • 0x23
  • length byte
  • 0x10 0x04 fixed header
  • 0x00 is ...
ribbon tweeter for bat audio
3d glasses
A tear-down here:
Interesting documents:
Waterniveaumeter
Idee:
Online bat detector
mini word clock in dutch
Simple Doppler motion sensors
AVR Arduino sample rate
Indoor radar speed sign
