User:Bertrik Sikken
| Name | Bertrik Sikken |
| Nick | bertrik |
| Tagline | heb ik niet |
Super tiny RFID
See https://www.sparkfun.com/products/16464 a almost sand grain size RFID chip, 1.25mmx1.25mmx0.55mm
Actually smart boiler
Alternatives:
TinyGS
I run a tinyGS satellite ground station. It should be able to receive LoRa transmission from cube sats.
Station page: https://tinygs.com/station/bertrik@1430247931
Antenna design:
- https://community.libre.space/t/an-easy-3d-printed-quadrifilar-helix-antenna/1487
 - https://gitlab.com/surligas/qfh-antenna/-/tree/master/433
 - meaning of the dimensions https://www.jcoppens.com/ant/qfh/calc.en.php
Receiving gas meters
Interesting leads:
Multi-network wifi manager
Interesting candidates:
Automated bat counting
XBEE
- XBR-001-06
 - FCC ID: MCQ-PROS2B, see https://fccid.io/MCQ-PROS2B
 - IC: 1846A-PROS2B
What I definitely can do:
Showstoppers:
Open work:
- investigate if Helium has an open uplink API for their hotspots, if so study it etc, without paying the gateway fee
Interesting stuff:
Interesting stuff in GATT:
- service 0xC760
- 0x23
 - length byte
- 0x10 0x04 fixed header
 - 0x00 is ...
ribbon tweeter for bat audio
3d glasses
A tear-down here:
Interesting documents:
Waterniveaumeter
Idee:
Online bat detector
Blood pressure meter hacking
- bluetooth GATT profile for blood pressure monitors https://www.bluetooth.com/specifications/gatt/
 - hacking the UART on an Omron RS8 : https://blog.adafruit.com/2016/05/26/hacking-uart-to-an-omron-rs8-blood-pressure-sphygmomanometer/
 - https://hackaday.com/2015/10/11/push-blood-pressure-data-to-the-cloud-via-esp8266/
 - hacking a blood pressure monitor by monitoring i2c traffic to the EEPOM: https://www.edusteinhorst.com/hacking-a-blood-pressure-monitor/
 - inexpensive ep2c5t144 board
mini word clock in dutch
Simple Doppler motion sensors
AVR Arduino sample rate
GPS repeater
Plan:
Indoor radar speed sign
