User:Bertrik Sikken
| Name | Bertrik Sikken |
| Nick | bertrik |
| Tagline | heb ik niet |
Zo'n ding 3d printen: https://twitter.com/MeOwOser/status/1250879531830915073
LoRa tracker
I ordered the LGT-92, a LoRaWAN tracker. It sends a position fix from GPS over LoRaWAN at regular intervals, so it can be used as a TTN mapper node.
This thing is open source:
- Hardware: https://github.com/dragino/Lora/tree/master/LGT-92
- Software: https://github.com/dragino/LGT-92_-LoRa_GPS_Tracker/tree/master/Projects/Multi/Applications/LoRa/DRAGINO-LRWAN(AT)
Stuff to play with:
- compile the firmware
- compile it in platformio
- upload it using platformio
- flash bootloader?
- update the firmware, e.g. fix bugs/warnings, add Cayenne payload (number of satellites in a specific field), discuss this with TTN mapper creator, etc.
Cheat sheet:
AT+ADR=0 AT+NJM=0 AT+CFM=0 AT+DR=5 AT+LON=1 AT+MD=0 AT+DADDR=26 01 1A 30 AT+NWKSKEY=FB 09 6B 85 86 AF 47 12 E8 AE 67 CB 7F A9 CB 51 AT+APPSKEY=CB 9B 8F F5 E6 2C 8E 87 9E 0B 6B 1F 4B 69 14 FA AT+TDC=10000 AT+NMEA886=2
ST-Link pin connections (from: https://github.com/dragino/LGT-92_-LoRa_GPS_Tracker/issues/10):
ST-LINK v2 5.0v <--> Dupont red pin ST-LINK v2 GND <--> Dupont black pin ST-LINK v2 SWCLK <--> Dupont green pin ST-LINK v2 SWDIO <--> Dupont white pin
Some "guides" get this wrong.
Command to connect with cheapie stlinkv2:
openocd -f /usr/share/openocd/scripts/interface/stlink.cfg -f /usr/share/openocd/scripts/target/stm32l0.cfg
3d glasses
A tear-down here:
Interesting documents:
Waterniveaumeter
Idee:
Online bat detector
Blood pressure meter hacking
- bluetooth GATT profile for blood pressure monitors https://www.bluetooth.com/specifications/gatt/
- hacking the UART on an Omron RS8 : https://blog.adafruit.com/2016/05/26/hacking-uart-to-an-omron-rs8-blood-pressure-sphygmomanometer/
- https://hackaday.com/2015/10/11/push-blood-pressure-data-to-the-cloud-via-esp8266/
- hacking a blood pressure monitor by monitoring i2c traffic to the EEPOM: https://www.edusteinhorst.com/hacking-a-blood-pressure-monitor/
- inexpensive ep2c5t144 board
mini word clock in dutch
Simple Doppler motion sensors
AVR Arduino sample rate
GPS repeater
Plan:
Indoor radar speed sign
