User:Bertrik Sikken
| Name | Bertrik Sikken |
| Nick | bertrik |
| Tagline | heb ik niet |
Understand Bluetooth AP
I'm trying to understand how to set up a bluetooth AP on a basic Linux system, such that you can connect to it using an Android phone or tablet.
The idea is that there is some kind of useful application running on the Linux system, and that the "app" on the tablet/phone provides the user interface, connecting to the Linux system using REST.
Possible useful links:
- https://www.linux.com/learn/weekend-project-personal-area-networking-bluetooth
https://www.osnews.com/story/9836/Make_your_Arch_Linux_a_Bluetooth_Access_Point: quite old, uses rfcomm, basically a serial port over bluetoothhttp://bluez.sourceforge.net/contrib/HOWTO-PAN: describes setting up a network using the "pand" utility, can't find that utility- bluetooth device class calculator
- http://blog.fraggod.net/2015/03/28/bluetooth-pan-network-setup-with-bluez-5x.html
- bt-pan script as referred by the link above
- Is Your Personal Area Network Giving You the BlueZ?
My starting point is:
- a Yocto based Linux distribution
- a Linux 4.1 kernel
- Bluez 5
Understanding the various Linux drivers and tools in the Linux bluetooth stack
- btusb: the Linux kernel driver module for many USB/bluetooth adapters, 'modprobe'-ing this module also magically takes care of downloading firmware needed
- hciconfig, low-level configuration utility for manipulating a bluetooth controller. A bit like ifconfig, it can bring the interface up or down, set options, etc.
- hcitool, yet another utility to perform low-level bluetooth operations, like querying the name of paired devices
- bluetoothd, the bluetooth daemon
- /etc/bluetooth/main.conf : supposedly (one of) the configuration files for bluetoothd
- bluetoothd can be accessed over DBUS apparently, see Bluez docs
- bluetoothctl, a more high-level configuration utility, basically a command line user interface towards bluetoothd as I understand it.
And some acronyms:
- NAP: network access protocol
- PAN: personal area network
- BNEP: bluetooth network encapsulation protocol
Getting somewhere: ?
dbus-send --system --type=method_call --print-reply --dest=org.bluez /org/bluez/hci0 org.bluez.NetworkServer1.Register string:'nap' string:'bnep'
- following this guide on the server-side (requires systemd): https://blind.guru/tag/bluetooth-pan.html#a-bluetooth-pan-access-point-with-systemd
- transmit our own control signal, to control a quadcopter from something different than the manual remote control, e.g. automatic control
- receive the control signal, so the manual remote control that comes with a quadcopter can be used to steer other things (like a model car).
mini word clock in dutch
Local date calculation:
- http://stackoverflow.com/questions/5590429/calculating-daylight-saving-time-from-only-date
- https://github.com/niekproductions/word-clock
Understanding LoRa
Simple Doppler motion sensors
Rust
Investigate the rust language.
ESP32
- ESP32 Arduino page by Wemos
AVR Arduino sample rate
Example C code
#define BUF_SIZE 16
static void ISR(void)
static int16_t lowpass = 0;
static int32_t sum = 0;
static bool even = false;
int16_t input, signal, mixed;
input = ....
// HPF input signal
signal = input - lowpass;
lowpass += signal >> 4;
// multiply by carrier
even = !even;
sum += mixed ;
sum -= buffer[index];
buffer[index] = mixed ;
// output LPF as 8-bit number
out = sum >> 7;
Bat call cleaner
- Apply a high-pass filter to get rid of non-ultrasonics like speech, say at 10 kHz
- Convert the signal into a complex analytic signal, by creating the imaginary part using a Hilbert transform.
- The Hilbert transform can be approximated by a FIR filter of appropriate length to get the desired bandwidth.
- Split the complex signal into an instantaneous frequency and amplitude.
- The frequency is determined by differentiating the instantaneous phase (inverse tangens i/q).
- The amplitude is determined by calculating the norm of the complex signal (sqrt of i^2 + q^2)
- Average/low-pass the frequency component, say at 0.1 ms intervals. Do the same to the amplitude.
- Re-synthesize the signal s using the simple model s = A.sin(2.pi.t/f) where A is amplitude, t is time and f is frequency, interpolating A and f.
Alternative:
- chop the signal up in segments of (say) 100 ms and determine the total energy content in each segment
- choose the quietest segment and use this as a "background noise template"
- perform a fourier analysis on the template
- reduce the noise on the signal using the template:
- for each segment, apply for each frequency an attenuation based on the signal level compared to the template level
- resynthesize from fourier back into the time domain using an overlap-add method
