User:Bertrik Sikken
| Name | Bertrik Sikken |
| Nick | bertrik |
| Tagline | heb ik niet |
- transmit our own control signal, to control a quadcopter from something different than the manual remote control, e.g. automatic control
- receive the control signal, so the manual remote control that comes with a quadcopter can be used to steer other things (like a model car).
mini word clock in dutch
Local date calculation:
- http://stackoverflow.com/questions/5590429/calculating-daylight-saving-time-from-only-date
- https://github.com/niekproductions/word-clock
Understanding LoRa
Simple Doppler motion sensors
Rust
Investigate the rust language.
ESP32
I have a Wemos "LOLIN32 V1.0.0" ESP32 board, play with it. Discover bluetooth capabilities, low power modes. Compare it with ESP32.
- ESP32 Arduino page by Wemos
