User:Bertrik Sikken
Revision as of 21:15, 19 October 2024 by Bertrik Sikken (talk | contribs) (→‎Remote bat box monitor)
User info Bertrik Sikken
Name Bertrik Sikken
Nick bertrik
Tagline heb ik niet
 Project Status
FrontDoorDisplayAbandoned
HabAlertAppAbandoned
ISSOAbandoned
IbmPosDisplayAbandoned
Pico TrackersAbandoned
RadarOnAStickAbandoned
WifiLampAbandoned
A4PaperDispenserCompleted
CJMCU-811Completed
CO2MeterHackingCompleted
CrawlSpaceSensorCompleted
DecodingLoraCompleted
DustSensorCompleted
ElectronicLoadCompleted
EspNowSkipCompleted
IntakefancontrollerCompleted
LichtKrantCompleted
LoRaGatewayCompleted
LoraBatBoxCompleted
LoraWanNodeCompleted
MHZ19Completed
MainsFrequencyCompleted
MiniSTM32F103ZECompleted
PowerLightCompleted
RC522HackingCompleted
RevRadioCompleted
STM32Completed
Secure iButtonCompleted
SoilHumiditySensorCompleted
StofAnanasCompleted
StofradarCompleted
TTNHABBridgeCompleted
VINDRIKTNINGCompleted
ZigbeeCoordinatorCompleted
Sensor-data-bridgeCompleted
AntiLostIn progress
AudioMothIn progress
CubeCellIn progress
EspAudioSensorIn progress
Esp32camIn progress
FMCWRadarIn progress
KaraburanIn progress
LoRa-E5-miniIn progress
LoraWanDustSensorIn progress
MainsFrequency2.0In progress
Msi2500SDRIn progress
MysteryLidarIn progress
Sim7020In progress
StereoBatRecorderIn progress
... further results
Idea:
KNMI API
WeAct CH55x board
Zigbee device with esp32
Cameratoezicht in Gouda
SolarEdge
Stookalert
Implementatie:
Resources:
With result:
 event: state
Use an audiomoth for this.
ESP32 C3
Flexible LED ticker
Washing machine API
TinyML
Bat box busy signal
Super tiny RFID
Specification:
Actually smart boiler
Alternatives:
Receiving gas meters
Interesting leads:
Multi-network wifi manager
Interesting candidates:
Automated bat counting
What I definitely can do:
Showstoppers:
Open work:
Interesting stuff:
Interesting stuff in GATT:
  • service 0xC760
  • 0x23
  • length byte
  • 0x10 0x04 fixed header
  • 0x00 is ...
ribbon tweeter for bat audio
3d glasses
A tear-down here:
Interesting documents:
Waterniveaumeter
Idee:
Online bat detector
mini word clock in dutch
Simple Doppler motion sensors
AVR Arduino sample rate
Indoor radar speed sign
