User:Bertrik Sikken
| Name | Bertrik Sikken |
| Nick | bertrik |
| Tagline | heb ik niet |
SSE webserver on ESP32
I want to be able to server server-sent-events from an ESP32C3 web server
- https://github.com/IU5HKU/ESP8266-ServerSentEvents
- https://github.com/lacamera/ESPAsyncWebServer?tab=readme-ov-file#async-event-source-plugin
The plan is to use an ESP32C3 to measure mains grid frequency (phase actually) and make it available over an SSE web URL. Another ESP-device can then subscribe to this and display the phase and/or the frequency on an RGB LED ring for example.
WeAct CH55x board
Cheap little boards, using the same chip as used in USB-serial converters.
Zigbee device with esp32
Cameratoezicht in Gouda
SolarEdge
Stookalert
Implementatie:
Resources:
With result:
event: state
Use an audiomoth for this.
ESP32 C3
Flexible LED ticker
Washing machine API
TinyML
Bat box busy signal
Super tiny RFID
Specification:
Actually smart boiler
Alternatives:
Receiving gas meters
Interesting leads:
Multi-network wifi manager
Interesting candidates:
Automated bat counting
What I definitely can do:
Showstoppers:
Open work:
Interesting stuff:
- https://thingsix.com/
Interesting stuff in GATT:
- service 0xC760
- 0x23
- length byte
- 0x10 0x04 fixed header
- 0x00 is ...
ribbon tweeter for bat audio
Someone gave me this idea:
3d glasses
A tear-down here:
Interesting documents:
Waterniveaumeter
Idee:
Online bat detector
- inexpensive ep2c5t144 board
mini word clock in dutch
Simple Doppler motion sensors
AVR Arduino sample rate
Indoor radar speed sign
