User:Bertrik Sikken
User info Bertrik Sikken
Name Bertrik Sikken
Nick bertrik
Tagline heb ik niet
 Project Status
FrontDoorDisplayAbandoned
HabAlertAppAbandoned
ISSOAbandoned
IbmPosDisplayAbandoned
Pico TrackersAbandoned
RadarOnAStickAbandoned
WifiLampAbandoned
A4PaperDispenserCompleted
CJMCU-811Completed
CO2MeterHackingCompleted
CrawlSpaceSensorCompleted
DecodingLoraCompleted
DustSensorCompleted
ElectronicLoadCompleted
EspNowSkipCompleted
IntakefancontrollerCompleted
LichtKrantCompleted
LoRaGatewayCompleted
LoraBatBoxCompleted
LoraWanNodeCompleted
MHZ19Completed
MainsFrequencyCompleted
MiniSTM32F103ZECompleted
PowerLightCompleted
RC522HackingCompleted
RevRadioCompleted
STM32Completed
Secure iButtonCompleted
SoilHumiditySensorCompleted
StofAnanasCompleted
StofradarCompleted
TTNHABBridgeCompleted
VINDRIKTNINGCompleted
ZigbeeCoordinatorCompleted
Sensor-data-bridgeCompleted
AntiLostIn progress
AudioMothIn progress
CubeCellIn progress
EspAudioSensorIn progress
Esp32camIn progress
FMCWRadarIn progress
KaraburanIn progress
LoRa-E5-miniIn progress
LoraWanDustSensorIn progress
MainsFrequency2.0In progress
Msi2500SDRIn progress
Sim7020In progress
StereoBatRecorderIn progress
UltrasonicPlayerIn progress
... further results
With GATT you can basically have a collection of properties (e.g. measurement items like temperature/humidity/particulate matter/noise, etc) organised in a simple structure of a BLE service. The 'notification' method allows you to basically push the data continuously to a connected host, e.g. a smart phone.
Interesting stuff in GATT:
  • 0x2A6E/0x2A6F are characterstics for temperature/humidity
  • 0x2BD5 is the GATT Characteristic and Object Type Particulate Matter - PM1 Concentration
  • 0x2BD6 is the GATT Characteristic and Object Type Particulate Matter - PM2.5 Concentration
  • 0x2BD7 is the GATT Characteristic and Object Type Particulate Matter - PM10 Concentration
  • service 0xC760
  • 0x23
  • length byte
  • 0x10 0x04 fixed header
  • 0x00 is ...
TheThingsNetwork gateway stats
Goal: provide insight in local LoRaWAN spectrum use by watching traffic received on gateways
Source code: https://github.com/bertrik/ttn-gateway-collector
ribbon tweeter for bat audio
3d glasses
A tear-down here:
Interesting documents:
Waterniveaumeter
Idee:
Online bat detector
Blood pressure meter hacking
mini word clock in dutch
Simple Doppler motion sensors
AVR Arduino sample rate
GPS repeater
Plan:
Indoor radar speed sign
