User:Bertrik Sikken
User info Bertrik Sikken
Name Bertrik Sikken
Nick bertrik
Tagline heb ik niet
 Project Status
FrontDoorDisplayAbandoned
HabAlertAppAbandoned
ISSOAbandoned
IbmPosDisplayAbandoned
Pico TrackersAbandoned
RadarOnAStickAbandoned
WifiLampAbandoned
A4PaperDispenserCompleted
CJMCU-811Completed
CO2MeterHackingCompleted
CrawlSpaceSensorCompleted
DecodingLoraCompleted
DustSensorCompleted
ElectronicLoadCompleted
EspNowSkipCompleted
IntakefancontrollerCompleted
LichtKrantCompleted
LoRaGatewayCompleted
LoraBatBoxCompleted
LoraWanNodeCompleted
MHZ19Completed
MainsFrequencyCompleted
MiniSTM32F103ZECompleted
PowerLightCompleted
RC522HackingCompleted
RevRadioCompleted
STM32Completed
Secure iButtonCompleted
SoilHumiditySensorCompleted
StofAnanasCompleted
StofradarCompleted
TTNHABBridgeCompleted
VINDRIKTNINGCompleted
ZigbeeCoordinatorCompleted
Sensor-data-bridgeCompleted
AntiLostIn progress
AudioMothIn progress
BT785In progress
CubeCellIn progress
EspAudioSensorIn progress
Esp32camIn progress
FMCWRadarIn progress
KaraburanIn progress
LoRa-E5-miniIn progress
LoraWanDustSensorIn progress
MainsFrequency2.0In progress
MeshtasticIn progress
Msi2500SDRIn progress
MysteryLidarIn progress
... further results
Zo'n ding 3d printen: https://twitter.com/MeOwOser/status/1250879531830915073
LoRa tracker
I ordered the LGT-92, a LoRaWAN tracker. It sends a position fix from GPS over LoRaWAN at regular intervals, so it can be used as a TTN mapper node.
This thing is open source:
Stuff to play with:
  • compile the firmware
  • compile it in platformio
  • upload it using platformio
  • flash bootloader?
  • update the firmware, e.g. fix bugs/warnings, add Cayenne payload (number of satellites in a specific field), discuss this with TTN mapper creator, etc.
Cheat sheet:
 AT+ADR=0
 AT+NJM=0
 AT+CFM=0
 AT+DR=5
 AT+LON=1
 AT+MD=0
 AT+DADDR=26 01 1A 30
 AT+NWKSKEY=FB 09 6B 85 86 AF 47 12 E8 AE 67 CB 7F A9 CB 51
 AT+APPSKEY=CB 9B 8F F5 E6 2C 8E 87 9E 0B 6B 1F 4B 69 14 FA
 AT+TDC=15000
 AT+NMEA886=2
 AT+PORT=1
ST-Link pin connections (from: https://github.com/dragino/LGT-92_-LoRa_GPS_Tracker/issues/10):
 ST-LINK v2 5.0v  <--> Dupont red pin
 ST-LINK v2 GND   <--> Dupont black pin
 ST-LINK v2 SWCLK <--> Dupont green pin
 ST-LINK v2 SWDIO <--> Dupont white pin
Some "guides" get this wrong.
Command to connect with cheapie stlinkv2:
 openocd -f /usr/share/openocd/scripts/interface/stlink.cfg -f /usr/share/openocd/scripts/target/stm32l0.cfg
3d glasses
A tear-down here:
Interesting documents:
Waterniveaumeter
Idee:
Online bat detector
Blood pressure meter hacking
mini word clock in dutch
Simple Doppler motion sensors
AVR Arduino sample rate
GPS repeater
Plan:
Indoor radar speed sign
