User:Bertrik Sikken
User info Bertrik Sikken
Name Bertrik Sikken
Nick bertrik
Tagline heb ik niet
 Project Status
FrontDoorDisplayAbandoned
HabAlertAppAbandoned
ISSOAbandoned
IbmPosDisplayAbandoned
Pico TrackersAbandoned
RadarOnAStickAbandoned
WifiLampAbandoned
A4PaperDispenserCompleted
CJMCU-811Completed
CO2MeterHackingCompleted
CrawlSpaceSensorCompleted
DecodingLoraCompleted
DustSensorCompleted
ElectronicLoadCompleted
EspNowSkipCompleted
IntakefancontrollerCompleted
LichtKrantCompleted
LoRaGatewayCompleted
LoraBatBoxCompleted
LoraWanNodeCompleted
MHZ19Completed
MainsFrequencyCompleted
MiniSTM32F103ZECompleted
PowerLightCompleted
RC522HackingCompleted
RevRadioCompleted
STM32Completed
Secure iButtonCompleted
SoilHumiditySensorCompleted
StofAnanasCompleted
StofradarCompleted
TTNHABBridgeCompleted
VINDRIKTNINGCompleted
ZigbeeCoordinatorCompleted
Sensor-data-bridgeCompleted
AntiLostIn progress
AudioMothIn progress
BT785In progress
CubeCellIn progress
EspAudioSensorIn progress
Esp32camIn progress
FMCWRadarIn progress
KaraburanIn progress
LoRa-E5-miniIn progress
LoraWanDustSensorIn progress
MainsFrequency2.0In progress
MeshtasticIn progress
Msi2500SDRIn progress
MysteryLidarIn progress
... further results
NRF52840 boards
NRF52840 is potentially a very nice platform:
  • low-power. quick wake-up
  • inexpensive
  • decent amount of flash (1024k), RAM (256k) and CPU cycles (64 MHz)
  • support various radio protocols like zigbee, ble, thread, matter, enhanced shockburst
  • built-in support for quadrature counting
  • looks like it can run arduino too
Links:
My promicro board currently has bootloader 0.6.0:
 UF2 Bootloader 0.6.0 lib/nrfx (v2.0.0) lib/tinyusb (0.10.1-41-gdf0cda2d) lib/uf2 (remotes/origin/configupdate-9-gadbb8c7)
 Model: nice!nano
 Board-ID: nRF52840-nicenano
 SoftDevice: not found
 Date: Jun 19 2021
My supermini board came with bootloader 0.6.0:
 Model: nice!nano
 Date: Jun 19 2021
However the eco-system of inexpensive boards is a complicated landscape:
  • AliExpress sellers offer "promicro" and "supermini" board with unclear characteristics
  • LEDs are often swapped (blue = hardware charge, red = software led?)
  • Various firmware upload interface options (which one to use?):
    • Using nrfutil, sends a .zip file containing various parts
    • Serial DFU, used by nrfutil?
    • Mass storage UF2, possibly activated using the double-reset
    • SWD debug interface (requires soldering!)
  • Confusing situation regarding bootloaders:
    • Most boards seem to come with a modified version of a bootloader meant for another type of board
    • Type of bootloader depends on type of firmware you want to run, "ZMK", Arduino using Arduino IDE, Arduino using platformio
    • Space for "SoftDevice" needs to be reserved, what is this?
    • Risk of accidentally overwriting the bootloader, with UF2 flash offsets sometimes being absolute, sometimes being relative
    • Even multiple levels of bootloader? Like the normal one during application and another one using the double-reset method?
Getting 'circuitpython' to work:
action lsc stekker
sipeed maix dock
rfid keyfob
advanced lidars for bat detection
livox:
cubecell meshtastic motion detector
configure multitech outdoor gateway
esp32 wtf
kakofonie counter
Stuff to figure out:
  • can it run on an ESP32?
  • make a prototype
hypno toad
wasbeer / kat classifier
Nespresso brew counter
Remote bat box monitor
Idea:
KNMI API
WeAct CH55x board
Zigbee device with esp32
Cameratoezicht in Gouda
SolarEdge
Stookalert
Implementatie:
Resources:
With result:
 event: state
Use an audiomoth for this.
ESP32 C3
Flexible LED ticker
Washing machine API
TinyML
Bat box busy signal
Super tiny RFID
Specification:
Actually smart boiler
Alternatives:
Receiving gas meters
Interesting leads:
Multi-network wifi manager
Interesting candidates:
Automated bat counting
What I definitely can do:
Showstoppers:
Open work:
Interesting stuff:
Interesting stuff in GATT:
  • service 0xC760
  • 0x23
  • length byte
  • 0x10 0x04 fixed header
  • 0x00 is ...
ribbon tweeter for bat audio
3d glasses
A tear-down here:
Interesting documents:
Waterniveaumeter
Idee:
Online bat detector
mini word clock in dutch
Simple Doppler motion sensors
AVR Arduino sample rate
Indoor radar speed sign
