Gebruiker:Bertrik Sikken
User info Bertrik Sikken
Name Bertrik Sikken
Nick bertrik
Tagline heb ik niet
 Project Status
FrontDoorDisplayAbandoned
HabAlertAppAbandoned
ISSOAbandoned
IbmPosDisplayAbandoned
Pico TrackersAbandoned
RadarOnAStickAbandoned
WifiLampAbandoned
A4PaperDispenserCompleted
CJMCU-811Completed
CO2MeterHackingCompleted
CrawlSpaceSensorCompleted
DecodingLoraCompleted
DustSensorCompleted
ElectronicLoadCompleted
EspNowSkipCompleted
IntakefancontrollerCompleted
LichtKrantCompleted
LoRaGatewayCompleted
LoraBatBoxCompleted
LoraWanNodeCompleted
MHZ19Completed
MainsFrequencyCompleted
MiniSTM32F103ZECompleted
PowerLightCompleted
RC522HackingCompleted
RevRadioCompleted
STM32Completed
Secure iButtonCompleted
SoilHumiditySensorCompleted
StofAnanasCompleted
StofradarCompleted
TTNHABBridgeCompleted
VINDRIKTNINGCompleted
ZigbeeCoordinatorCompleted
Sensor-data-bridgeCompleted
AntiLostIn progress
AudioMothIn progress
BT785In progress
CubeCellIn progress
EspAudioSensorIn progress
Esp32camIn progress
FMCWRadarIn progress
Its-g5In progress
KaraburanIn progress
LoRa-E5-miniIn progress
LoraWanDustSensorIn progress
MainsFrequency2.0In progress
MeshtasticIn progress
Msi2500SDRIn progress
... meer resultaten
Old project ideas:
  • Use two old satellite dishes to allow speech to be transferred over some distance
    • Figure out focal point
    • Create some kind of dish mount
Project ideas for 2016:
New project ideas:
  • Create a RFM69HW TNC, based on code by flok
    • Remove 'flok' framing, make it comply with KISS protocol
    • Use 'infinite' package length mode to send typical TCP/IP frames (1500 bytes)
  • Create a 'HabAlert' android app, see HabAlertApp
  • add opus audio codec support to squeezeboxserver and/or squeezelite
    • an opus web radio stream already seems to be redirected to the client, but squeezelite crashes on it
  • create code for remote control of my ZwaaiLicht
    • implement wireless protocol for the NOMZ message ("\x4NOMZ") on address 0x66996699L (no ack)
    • possibly implement a more capable protocol on a different pipe (with ack, learn about extra pipes on NRF24L01+)
    • possibly split control of the light and the motor
  • Experiment with an ESP8266 serial-wifi module, WiFiBat project plan:
    • attach an ESP8266 to a migrating bat and program it to record a list of wifi APs every day, so the location over time can be determined from the AP-list (use Mozilla geolocation service to convert from AP-list to location), main challenge: keep weight and power consumption low.
  • Create better algorithm for detecting heartbeat using this optical heart beat sensor: sample the analog signal at 100 Hz and do an autocorrelation to get a continuous estimate of the heart rate.
  • Play around with so-called LoRa (long range) RF modules. These modules have improved range owing to spread-spectrum modulation, error correction and 100 mW RF output.
Laser cutting: I would like to get more creative with the laser cutter, starting with cutting existing designs, for example:
