User:Bertrik Sikken
User info Bertrik Sikken
Name Bertrik Sikken
Nick bertrik
Tagline heb ik niet
  • citizen science, particulate matter measurement, noise (future)
 Project Status
FrontDoorDisplayAbandoned
HabAlertAppAbandoned
ISSOAbandoned
IbmPosDisplayAbandoned
Pico TrackersAbandoned
RadarOnAStickAbandoned
WifiLampAbandoned
A4PaperDispenserCompleted
CJMCU-811Completed
CO2MeterHackingCompleted
CrawlSpaceSensorCompleted
DecodingLoraCompleted
DustSensorCompleted
ElectronicLoadCompleted
EspNowSkipCompleted
IntakefancontrollerCompleted
LichtKrantCompleted
LoRaGatewayCompleted
LoraBatBoxCompleted
LoraWanNodeCompleted
MHZ19Completed
MainsFrequencyCompleted
MiniSTM32F103ZECompleted
PowerLightCompleted
RC522HackingCompleted
RevRadioCompleted
STM32Completed
Secure iButtonCompleted
SoilHumiditySensorCompleted
StofAnanasCompleted
StofradarCompleted
TTNHABBridgeCompleted
VINDRIKTNINGCompleted
ZigbeeCoordinatorCompleted
Sensor-data-bridgeCompleted
AntiLostIn progress
AudioMothIn progress
CubeCellIn progress
EspAudioSensorIn progress
Esp32camIn progress
FMCWRadarIn progress
LoRa-E5-miniIn progress
LoraWanDustSensorIn progress
MainsFrequency2.0In progress
Msi2500SDRIn progress
Sim7020In progress
StereoBatRecorderIn progress
UltrasonicPlayerIn progress
EspNowAudioInitializing
... further results
Flexible LED ticker
Washing machine API
TinyML
Bat box busy signal
Super tiny RFID
Specification:
Actually smart boiler
Alternatives:
TinyGS
I run a tinyGS satellite ground station. It should be able to receive LoRa transmission from cube sats.
Station page: https://tinygs.com/station/bertrik@1430247931
Antenna design:
Receiving gas meters
Interesting leads:
Multi-network wifi manager
Interesting candidates:
Automated bat counting
XBEE
What I definitely can do:
Showstoppers:
Open work:
Interesting stuff:
Interesting stuff in GATT:
  • service 0xC760
  • 0x23
  • length byte
  • 0x10 0x04 fixed header
  • 0x00 is ...
ribbon tweeter for bat audio
3d glasses
A tear-down here:
Interesting documents:
Waterniveaumeter
Idee:
Online bat detector
Blood pressure meter hacking
mini word clock in dutch
Simple Doppler motion sensors
AVR Arduino sample rate
GPS repeater
Plan:
Indoor radar speed sign
