User:Bertrik Sikken
Revision as of 07:55, 31 May 2017 by Bertrik Sikken (talk | contribs) (Add arduino bat detector idea)
User info Bertrik Sikken
Name Bertrik Sikken
Nick bertrik
Tagline heb ik niet
 Project Status
FrontDoorDisplayAbandoned
HabAlertAppAbandoned
ISSOAbandoned
IbmPosDisplayAbandoned
Pico TrackersAbandoned
RadarOnAStickAbandoned
WifiLampAbandoned
A4PaperDispenserCompleted
CJMCU-811Completed
CO2MeterHackingCompleted
CrawlSpaceSensorCompleted
DecodingLoraCompleted
DustSensorCompleted
ElectronicLoadCompleted
EspNowSkipCompleted
IntakefancontrollerCompleted
LichtKrantCompleted
LoRaGatewayCompleted
LoraBatBoxCompleted
LoraWanNodeCompleted
MHZ19Completed
MainsFrequencyCompleted
MiniSTM32F103ZECompleted
PowerLightCompleted
RC522HackingCompleted
RevRadioCompleted
STM32Completed
Secure iButtonCompleted
SoilHumiditySensorCompleted
StofAnanasCompleted
StofradarCompleted
TTNHABBridgeCompleted
VINDRIKTNINGCompleted
ZigbeeCoordinatorCompleted
Sensor-data-bridgeCompleted
AntiLostIn progress
AudioMothIn progress
CubeCellIn progress
EspAudioSensorIn progress
Esp32camIn progress
FMCWRadarIn progress
LoRa-E5-miniIn progress
LoraWanDustSensorIn progress
MainsFrequency2.0In progress
Msi2500SDRIn progress
Sim7020In progress
StereoBatRecorderIn progress
UltrasonicPlayerIn progress
EspNowAudioInitializing
... further results
Understand Bluetooth AP
I'm trying to understand how to set up a bluetooth AP on a basic Linux system, such that you can connect to it using an Android phone or tablet.
The idea is that there is some kind of useful application running on the Linux system, and that the "app" on the tablet/phone provides the user interface, connecting to the Linux system using REST.
Possible useful links:
My starting point is:
  • a Yocto based Linux distribution
  • a Linux 4.1 kernel
  • Bluez 5
Understanding the various Linux drivers and tools in the Linux bluetooth stack
  • btusb: the Linux kernel driver module for many USB/bluetooth adapters, 'modprobe'-ing this module also magically takes care of downloading firmware needed
  • hciconfig, low-level configuration utility for manipulating a bluetooth controller. A bit like ifconfig, it can bring the interface up or down, set options, etc.
  • hcitool, yet another utility to perform low-level bluetooth operations, like querying the name of paired devices
  • bluetoothd, the bluetooth daemon
    • /etc/bluetooth/main.conf : supposedly (one of) the configuration files for bluetoothd
    • bluetoothd can be accessed over DBUS apparently, see Bluez docs
  • bluetoothctl, a more high-level configuration utility, basically a command line user interface towards bluetoothd as I understand it.
And some acronyms:
  • NAP: network access protocol
  • PAN: personal area network
  • BNEP: bluetooth network encapsulation protocol
Getting somewhere: ?
mini word clock in dutch
Local date calculation:
Understanding LoRa
Simple Doppler motion sensors
Rust
Investigate the rust language.
ESP32
I have a Wemos "LOLIN32 V1.0.0" ESP32 board, play with it. Discover bluetooth capabilities, low power modes. Compare it with ESP32.
  • apply a basic IIR high-pass filter to remove DC bias, this takes one shift instruction and one addition.
  • low-pass filter the signal, this can be done using a moving average filter, say 32 samples long. This takes some storage, an addition and a subtraction.
The microphone can be a 40 kHz piezo transducer, to keep it cheap (but also limited to 40 kHz). The pre-amplifier can be a single transistor with some resistors around it, providing about 50x gain. The arduino does the signal processing (mixing, low-pass filter) to shift the bat audio to human range. The speaker amplifier can just be a simple two transistor push-pull circuit, since the output from the Arduino is digital/PWM.
Pseudo-code in C (this is the general idea, but I don't know if it compiles):
#define BUF_SIZE    32
static void ISR(void)
    static int16_t lowpass = 0;
    static int32_t sum = 0;
    static bool even = false;
    int16_t input, signal, mixed;
    // sample signal at 10 bits
    input = ....
    // HPF input signal
    signal = input - lowpass;
    lowpass += signal >> 4;
    // multiply by carrier
    even = !even;
    sum += signal;
    sum -= buffer[index];
    // store in buffer
    buffer[index] = signal;
    // output LPF as 8-bit number
    out = sum >> 7;
