Gebruiker:Bertrik Sikken
User info Bertrik Sikken
Name Bertrik Sikken
Nick bertrik
Tagline heb ik niet
 Project Status
FrontDoorDisplayAbandoned
HabAlertAppAbandoned
ISSOAbandoned
IbmPosDisplayAbandoned
Pico TrackersAbandoned
RadarOnAStickAbandoned
WifiLampAbandoned
A4PaperDispenserCompleted
CJMCU-811Completed
CO2MeterHackingCompleted
CrawlSpaceSensorCompleted
DecodingLoraCompleted
DustSensorCompleted
ElectronicLoadCompleted
EspNowSkipCompleted
IntakefancontrollerCompleted
LichtKrantCompleted
LoRaGatewayCompleted
LoraBatBoxCompleted
LoraWanNodeCompleted
MHZ19Completed
MainsFrequencyCompleted
MiniSTM32F103ZECompleted
PowerLightCompleted
RC522HackingCompleted
RevRadioCompleted
STM32Completed
Secure iButtonCompleted
SoilHumiditySensorCompleted
StofAnanasCompleted
StofradarCompleted
TTNHABBridgeCompleted
VINDRIKTNINGCompleted
ZigbeeCoordinatorCompleted
Sensor-data-bridgeCompleted
AntiLostIn progress
AudioMothIn progress
BT785In progress
CubeCellIn progress
EspAudioSensorIn progress
Esp32camIn progress
FMCWRadarIn progress
Its-g5In progress
KaraburanIn progress
LoRa-E5-miniIn progress
LoraWanDustSensorIn progress
MainsFrequency2.0In progress
MeshtasticIn progress
Msi2500SDRIn progress
... meer resultaten
investigate thread/matter
  • check out openthread
cd openthread
  scripts/bootstrap
* Build it:
action lsc stekker
https://keetsupport.nl/2024/03/20/how-to-flash-lsc-power-plug-with-esphome/ https://community.home-assistant.io/t/detailed-guide-on-how-to-flash-the-new-tuya-beken-chips-with-openbk7231t/437276
sipeed maix dock
Bought this a couple of years ago. Get familiar with this board. Can I run a chess program on this, for example? * https://wiki.sipeed.com/soft/maixpy/en/develop_kit_board/maix_dock.html
rfid keyfob
* aliexpress page: https://nl.aliexpress.com/item/1005009569496736.html * firmware github: ** https://github.com/RfidResearchGroup/ChameleonUltra ** https://github.com/GameTec-live/ChameleonUltraGUI
advanced lidars for bat detection
livox: * github page https://github.com/Livox-SDK/Livox-SDK/tree/master * web page: https://www.livoxtech.com/
cubecell meshtastic motion detector
I have a cubecell AB01 board. This board is focused on low power, has a connection to attach a solar panel and has a lora radio. Relatively small amount of RAM, barely enough to run a LoRaWAN stack but probably plenty to run meshtastic The plan is to build a simple motion detector from this (using a PIR). The PIR can wake up the board from low-power, or a timer can wake it periodically. See also: https://github.com/HelTecAutomation/CubeCell-Arduino/tree/master/libraries/Basics/examples/LowPower
configure multitech outdoor gateway
https://www.multitech.net/developer/products/multiconnect-conduit-platform/basestation/ https://multitech.com/product/multitech-conduit-mtcdt-246a-868-eu-gb/ emergency procedure: https://www.multitech.net/developer/software/mlinux/using-mlinux/flashing-mlinux-firmware-for-conduit/
esp32 wtf
* https://forum.arduino.cc/t/ttgo-lilygo-lora-esp32-26mhz-problem/1353750 * "26 MHz crystal has been deprecated" https://github.com/espressif/arduino-esp32/issues/10117
kakofonie counter
Sample room audio, use neural network to distinguish voices to estimate number of people talking in the past 30 seconds or so. Show this number on some kind of display, publish it to MQTT, make a nice graph of it. Stuff to figure out: * this is called 'speaker diarization' * can it run on an ESP32? * make a prototype
hypno toad
Put these LEDS https://nl.aliexpress.com/item/1005007583528891.html into https://www.action.com/nl-nl/p/2560347/solar-tuinbeeldje/ Turns out that the default circuit is really basic and output a rough step-up waveform to the LED. The self-fading LEDs don't work very well with that. Also, putting some IPA on hotglue makes it release really easy.
wasbeer / kat classifier
ESP32 with resnet50 neural net to distinguish house cats from other animals, see also: * https://ieeexplore.ieee.org/document/10556848/
Nespresso brew counter
Several hacker spaces have one of these Nespresso cup coffee makers, but there's no obvious easy way to monitor usage (monitor ALL the things!). Inspired by https://hackaday.com/2021/04/25/arduino-mkr-makes-nespresso-monitoring-easy/ this idea is making an even simpler nespresso monitor, using an inexpensive WiFi enabled ESP8266 with an ubiquitous I2S microphone such as the INMP441. Use this sound monitoring project: https://github.com/aleiei/ESP8266-BUG-I2S-MIC and turn it into a WiFi connected brew counter. Software for getting microphone data from an ESP8266/I2S mic into Linux https://github.com/bertrik/EspMicServer Nespresso sound is typically 50 Hz with overtones. In a recording with the ESP8266, it appears that oddly the 17th harmonic (around 850 Hz) is quite strong. The plan in the short term is this: * apply a gentle IIR filter to subtract any DC bias from the microphone signal * calculate autocovariance at offsets 0 and 20 ms (inverse of 50 Hz), representing the total energy and the energy at 50 Hz respectively * compare amplitudes to decide about presence of 50 Hz signal, e.g. calculate ratio in dB * use this to count the length of time that a 50 Hz signal is heard (increments of 100 ms or so) * decide about none / espresso / lungo based on time Might even integrate with esphome / home assistant later.
Remote bat box monitor
Idea: * goal: check if remote bat boxes are occupied and identify the species * challenges: ** connectivity: need to transport images/videos (no LoRaWAN), possibly out of range of mobile data networks ** autonomy: cannot reach the bat box once installed ** power: no fixed power connection, so probably needs a battery + solar panel * design ** wake up every hour, take a picture, go to sleep, upload photos/videos once per day ** run from batteries, recharge by solar, rules of thumb *** batteries should last for about 10 days *** battery should be able to charge in 1 day *** consider only 10% of peak solar power ** KPN "4G-op-zee" somewhat confusing article: https://www.kpn.com/zakelijk/mobiel/roaming/noordzee * hardware ** main processor: raspberry pi zero *** raspberry pi power consumption overview: https://www.pidramble.com/wiki/benchmarks/power-consumption ** this hat to wake up the main CPU: https://www.waveshare.com/wiki/Power_Management_HAT_(B) sold at https://www.kiwi-electronics.com/en/power-management-hat-for-raspberry-pi-with-rtc-and-rp2040-mcu-11373
KNMI API
WeAct CH55x board
Cheap little boards, using a similar chip as used in USB-serial converters. The hardware https://github.com/WeActStudio/WeActStudio.CH552CoreBoard Flashing it: https://hackaday.io/page/137447-flashing-the-ch552-dev-board-from-the-command-line See also: * https://hackaday.io/project/198238-more-weact-ch5xx * https://community.platformio.org/t/manually-adding-support-for-ch55x-controller-by-adding-existing-ardunio-core/41138
Zigbee device with esp32
See https://github.com/P-R-O-C-H-Y/arduino-esp32/blob/8169a434c3e46e1bb7711ebcc04f27267db2093c/libraries/ESP32/examples/Zigbee/Zigbee_Light_Bulb/Zigbee_Light_Bulb.ino See https://github.com/espressif/arduino-esp32/tree/master/libraries/ESP32/examples/Zigbee Espressif32 arduino platform git: https://github.com/platformio/platform-espressif32
Cameratoezicht in Gouda
Gemeente Gouda publiceert een lijst van camera's in Gouda, zie https://gis.gouda.nl/nl/app/Basisviewer_open#!eAGT8uRiNBRy4ZIRYFKSyKkssjJwdzFxNDMz8TKKsLC0cnb0dQ1y5FIByirgkg3xd43ydPYIAQBXGBFm Aanmelden (semi-automatisch) bij bijvoorbeeld Surveillance-under-surveillance ?
SolarEdge
Interact with the solar edge api for PV installations. https://developers.solaredge.com/ See https://github.com/bertrik/solaredge-api
Stookalert
Idee: gekleurd lampje dat aangeeft of er op dit moment een stookalert actief is Implementatie: * kijk m.b.v. WiFi locatieservice in welke provincie je je bevindt * haal JSON op bij https://www.lml.rivm.nl/stookalert/stookalert.json * toon de bijbehorende kleur op het lampje Resources: * Officiele pagina: https://www.atlasleefomgeving.nl/stookwijzer * Achterliggende JSON met toestand per provincie: https://www.lml.rivm.nl/stookalert/stookalert.json * Er moet ook nog ergens een API zijn die fijnmaziger aangeeft wat de toestand is ...
I have a slimme lezer connected to the P1 port of my smart electricity meter. The default firmware exposes meter readings using an event stream (SSE) at http://slimmelezer.local/events So for example, you can read this with curl: curl http://slimmelezer.local/events With result: event: state data: {"id":"sensor-power_consumed_phase_1","value":0.046,"state":"0.046 kW"} Specification of SSE: https://html.spec.whatwg.org/multipage/server-sent-events.html#parsing-an-event-stream What I would like to do is to read these events and control a simple display to display the current usage number.
https://bat-migration-europe.netlify.app/project/ Use an audiomoth for this.
ESP32 C3
* processor page * luatos basic esp32 c3 board
Flexible LED ticker
Ordered a flexible 32x8 RGB LED display: https://nl.aliexpress.com/item/4001296811800.html Matching diffuser to be 3D printed: https://www.thingiverse.com/thing:1903744
Washing machine API
TinyML
Investigate TinyML, see https://www.tinyml.org/ Apparently can run on a RP2040 (raspi pi pico). https://www.hackster.io/mjrobot/esp32-cam-tinyml-image-classification-fruits-vs-veggies-4ab970
Bat box busy signal
My brother built little pyramid 'blinkies': solar cell + Lithium-supercapacitor + harvesting circuit + LED encased in clear expoxy. Can we add a low-power PIR sensor to this, and make a blinky that blinks if movement was detected by the PIR in the past hour?
Super tiny RFID
See https://www.sparkfun.com/products/16464 an almost sand grain size RFID chip, 1.25mmx1.25mmx0.55mm The accompanying reader "M6E Nano" is still quite expensive at $235.95 : https://www.sparkfun.com/products/14066 Uses the MuRata LXMSJZNCMF-198: "This product can be used as an ultra small tag and this can be fit on any metal objects, non-metal objects, as well as embedding into any objects by glue or adhesive and so on." See also: ISO18000-63 and EPC global Gen2(v2) Specification: * https://www.gs1.org/standards/rfid/uhf-air-interface-protocol
Uploads balloon telemetry to sondehub. See https://github.com/bertrik/ttnhabbridge/issues/6
Actually smart boiler
The boiler for hot water is about half of my electricity bill. The idea is to use/build a smart switch that switches it on at time when electricity prices are lowest. Currently have a "Slimme boiler module" from Eneco, which is *not* actually smart, since it allows me no control whatsoever when it switches on (besides cutting the power in the meterkast). For example, it will switch on mid-day when my price is high and eneco's price is low, perhaps good for Eneco, not for me. Apparently, they even received a subsidy for this. A boiler is a pretty big load, about 3 kW, but it is not inductive. Alternatives: * https://www.shelly.cloud/en-nl/products/product-overview/shelly-plus-1-pm-2-pack/shelly-plus-1-pm * https://www.solyxenergy.nl/solar-iboost/ to store excess solar energy in hot water, might also be useful for just controlling a boiler to use cheaper rates * tuya smartplug, like https://www.wifilampkoning.nl/merken-slimme-verlichting/tuya/tuya-enkele-smartplug-met-energiemeting ? * tuya 20A smart plug: https://nl.aliexpress.com/item/1005003347568206.html
Receiving gas meters
Apparently gas meters send gas consumption data to the slimme meter using a wireless link in the 868 MHz band. Probably just FSK at 38.4, as mentioned here: https://a35.veron.nl/nieuwe-elektra-en-gasmeters/ Interesting leads: * https://github.com/stef/smeter * https://www.rtl-sdr.com/reading-household-wireless-utility-meters-with-an-rtl-sdr-and-plotting-the-data-in-home-automation-software/ * https://github.com/bemasher/rtlamr
Multi-network wifi manager
Figure out or create software so that ESP8266/ESP32 wifi manager can use multiple networks to connect (not just one), so it allowing storing credentials for more than one network. For example, the network at home, the hacker space, at work. Instead of reconfiguring the wifi manager for each network, you just *add* your credentials (and the existing credentials are not replaced). See https://github.com/folkertvanheusden/M.A.X.X Interesting candidates: * https://registry.platformio.org/libraries/martinverges/ESP32%20Wifi%20Manager wifi manager for ESP32, has a REST API for managing wifi network, but is incomplete in the sense that you need to write your own code (e.g. javascript) to actually *use* its API * https://github.com/arduino-libraries/Arduino_MultiWiFi is the arduino multi wifi library, to allow connecting to multiple different WiFi networks, but it is not a wifi manager, that starts a captive portal, etc
Automated bat counting
Can we automatically count the number of bats from the image of a webcam mounted in a bat colony? Perhaps using some kind of AI or machine learning algorithm? The image in question: https://stofradar.nl/coenecoop/
I have a spare TTIG that could perhaps be used as a Helium gateway, investigate what is possible. One possiblity is to capture the gateway traffic from the TTN gateway events API, convert uplink data to a format that the Helium network understands and forward it. I don't really care about the Helium crypto tokens, this is just for fun and science. What I definitely can do: * Capture data from the TTN gateway events API, convert it back to Semtech UP format and forward it somewhere to Helium (just not sure where!) * See also my https://github.com/bertrik/ttn-gateway-collector project which contains an initial implementation of TTN-to-UDP conversion Showstoppers: * If you want to be a gateway on the Helium network, you have to *pay Helium*! Obviously I don't want that, I just want to share data to improve *their* network. Open work: * Investigate if Helium has an open uplink API for their hotspots, if so study it etc, without paying the gateway fee * Investigate if Thingsix has an open uplink API for their hotspots, if so study it etc, without paying any gateway fee * Investigate if Thingsix is just another Helium, with weird crypto money Interesting stuff: * https://docs.helium.com/use-the-network/setup-a-packet-forwarder unfortunately the link to setting up the 'light hotspot client' does not work! * https://docs.helium.com/mine-hnt/light-hotspots/ * https://thingsix.com/
The GATT specification allows measurement properties to be defined and transferred continuously over Bluetooth low-energy. With GATT you can define a collection of properties (e.g. measurement items like temperature/humidity/particulate matter/noise, etc) organised in a simple structure of a BLE service. The 'notification' method allows you to basically push the data continuously to a connected host, e.g. a smart phone. Services collects characteristic, a characteristic has values with units. Each of these (service, characteristic, unit) have their own unique "UUID". This is described in the so-called 16-bit UUID numbers document Interesting stuff in GATT: * See GATT_Specification_Supplement_v5 paragraph 3.151, it has a noise characteristic with 1 dB resolution. * 0x27C3 is the GATT *unit* for sound pressure * 0x181A is the GATT environmental sensing *service*, document name "ESP_V1.0.0.pdf" * 0x2A6E is the GATT Characteristic and Object Type for temperature * 0x2A6F is the GATT Characteristic and Object Type for humidity * 0x2BD5 is the GATT Characteristic and Object Type for Particulate Matter - PM1 Concentration * 0x2BD6 is the GATT Characteristic and Object Type for Particulate Matter - PM2.5 Concentration * 0x2BD7 is the GATT Characteristic and Object Type for Particulate Matter - PM10 Concentration * Unfortunately I cannot find a characteristic for carbon-dioxide (CO2) in the BLE GATT unit document See also https://programmaticponderings.com/2020/08/04/getting-started-with-bluetooth-low-energy-ble-and-generic-attribute-profile-gatt-specification-for-iot/
This is a thing that measures CO2, humidity, temperature, TVOC and formaldehyde. See also https://wiki.liutyi.info/display/CO2/ZN-2CO3+Inside This teardown looks a lot like my sensor: https://www.youtube.com/watch?v=APnjhMrJChI Mine contains a "TPM-300A" sensor for measuring VOC. It has a bluetooth interface, device name is XS-8217. It has a BLE GATT profile, with the following services * service 0xC760 ** characteristic 0xC762 (WRITE) ** characteristic 0xC761 (NOTIFY) *** example data: 0x23 0x06 0x10 0x04 0xF1 0x00 0x23 0x65 *** example data: 0x23 0x08 0x10 0x04 0x01 0x9A 0x00 0x0A 0x00 0x03 0x0E *** data shown on screen was approximately: CO2=418ppm, HCHO=0.003mg/m3, TVOC=0.013mg/m3, temp=24degC, humi=35% So data in the characteristic 0xC761 seems to have a 4 byte constant header: * 0x23 * length byte Then we have for the first message: 0x10 0x04 0xF1 0x00 0x23 0x65 * 0x10 0x04 fixed header * 0xF1 is temperature in 0.1 degree Celcius most likely (24.1) * 0x00 is ... * 0x23 is humidity most likely (35) * 0x65 is ... checksum perhaps And for the second message: 0x10 0x04 0x01 0x9A 0x00 0x0A 0x00 0x03 0x0E * 0x10 0x04 fixed header * 0x01 0x9A is the CO2 concentration (410) * 0x00 0x0A is TVOC most likely (10) * 0x00 0x03 is HCHO most likely (3) * 0x0E is ... checksum perhaps
ribbon tweeter for bat audio
Someone gave me this idea: Use a ribbon tweeter like this for playing back bat audio: https://nl.aliexpress.com/item/4000973201791.html https://nl.aliexpress.com/item/1005002565880660.html https://nl.aliexpress.com/item/1005002635086050.html The frequency spectrum shows no sign of dropping off at 20 kHz.
3d glasses
I got some 2nd hand 3d glasses, they look exactly like these ones: * GH-15 https://www.dhgate.com/product/g15-dlp-3d-active-shutter-glasses-96-144hz/213983026.html * Sintron https://www.amazon.de/Sintron-Kompatibel-TDG-BT500A-TDG-BT400A-Deutschland/dp/B015PCWMZ8 The common name appears to be "G15-DLP". A tear-down here: * https://blog.danman.eu/3d-shutter-glasses-teardown/ Interesting documents: * http://cmst.curtin.edu.au/wp-content/uploads/sites/4/2016/05/2012-28-woods-helliwell-cross-compatibility_of_shutter_glasses.pdf * http://cmst.curtin.edu.au/local/docs/pubs/2011-17-woods-helliwell-3D-Sync-IR.pdf Someone claims he got something to work with some hacks: https://www.avsforum.com/threads/how-i-got-cheap-dlp-link-glasses-to-work-great.1887145/
Waterniveaumeter
Op verschillende plekken in Gouda staat er water in de kruipruimte van huizen van bewoners. Kunnen we dat meten en inzichtelijk maken, voor bewoners, op een kaart bijvoorbeeld? Idee: * in de kruipruimte plaats je een module die waterhoogte kan meten * de module bestaat uit een microcontroller en een afstandsmeter, die de waterhoogte bepaalt * de gegevens worden via WiFi doorgestuurd naar een centraal punt, waar de data wordt verwerkt en gevisualiseerd * op een webpagina kan je een overzicht zien van alle meters die online zijn * de meting wordt gedaan door bijv. een laser-afstandsmeter of een ultrasoon-afstandsmeter * voeding? lastig, hoe krijg je 5v naar een potentieel natte plek? * kosten? verwachting < E 40,- In Gouda wordt op veel verschillende plekken de grondwaterstand gemeten, zie https://opendata.munisense.net/portal/wareco-water2/group/581/Gouda-KJ38A , maar: * geen visualisatie op de kaart, je ziet alleen de meetlokaties d.m.v. een icoontje! * geen meetpunten in Gouda noord!
Online bat detector
Small inexpensive modules that play mp3 from an internal flash. Could be nice for a custom door bell for example. More info at: * https://www.elecfreaks.com/wiki/index.php?title=JQ6500_Mini_MP3_Module * https://sparks.gogo.co.nz/jq6500/index.html
Cheap FPGA boards and nice applications: * https://bitbucket.org/appanp/artificial-neural-networks/wiki/Home/FPGAsAndNeuralNets.md#!sbcs-and-iot-boards * inexpensive ep2c5t144 board * http://land-boards.com/blwiki/index.php?title=Cyclone_II_EP2C5_Mini_Dev_Board
Investigate if you can run a powerful neural network on relatively low-end/cheap/low-power hardware. For example a Raspberry pi. A RPI runs Linux, run python, just like some common neural frameworks. Do we need hardware acceleration from the GPU and does the RPI GPU support that? Read list: * https://www.zdnet.com/pictures/raspberry-pi-meets-ai-the-projects-that-put-machine-learning-on-the-35-board/ * https://www.pyimagesearch.com/2017/12/18/keras-deep-learning-raspberry-pi/ * https://www.indiegogo.com/projects/sipeed-maix-the-world-first-risc-v-64-ai-module#/ * https://ai.intel.com/intel-neural-compute-stick-2-smarter-faster-plug-and-play-ai-at-the-edge/ Bought a MaixPy: * see https://maixpy.sipeed.com/en/ * see https://www.youtube.com/watch?v=KResVuAIMb4 * see http://educ8s.tv/sipeed-m1-dock-review/ * interesting? https://www.instructables.com/id/Transfer-Learning-With-Sipeed-MaiX-and-Arduino-IDE/
mini word clock in dutch
Basically an monochrome 8x8 word clock, in Dutch, showing local time in the Netherlands. This git repo has the current code. See here for a demo running on an arduino nano. The plan is to run this from an ESP8266 instead of an arduino nano, so it can get the time from the internet using NTP. Andreas Spiess demonstrated on youtube how existing libraries on the ESP8266 can be used to do the local time (including summer-time) calculations.
Simple Doppler motion sensors
You can find basic doppler microwave motion sensors based on a single transistor, with some weird traces on the PCB very cheaply, for example * https://www.aliexpress.com/item/RCWL-0516-microwave-radar-sensor-module-Human-body-induction-switch-module-Intelligent-sensor/32708877914.html Typically the microwave part of these consists of a single transistor with a rectangular area on one leg and a meandering trace (with lots of vias to the other side) on the other leg. The output of this circuit seems to go into a chip very much like the ones used in PIR sensors. See also https://github.com/jdesbonnet/RCWL-0516 for a reverse engineering effort of these doppler radar modules.
This is an idea for a very basic heterodyne bat detector, doing signal processing on an Arduino, requiring minimal external components. The basic principle of a heterodyne detector is that it just mixes (multiplies) the audio signal with a square wave, low-pass filters the result and puts it on a speaker. Multiplying with a square wave can also be considered to be just alternatively inverting and not-inverting the signal. So if you sample an ultrasonic signal at twice the rate you want to multiply, you can just subtract odd samples from even samples and low-pass filter that. How this can be done in an AVR Arduino: * sample the audio signal at twice the detection frequency, say 84 kHz. An AVR should just be able to do that. * apply a 1-pole IIR high-pass filter to remove DC bias, this takes one shift instruction and one addition. * multiply by the detection frequency, this means just inverting the odd samples. * low-pass filter the signal, this can be done using a moving average filter, say 16 samples long (first null at 5.25 kHz). Theoretically, averaging 16 samples should result in two bits extra accuracy. This operation takes some storage, an addition and a subtraction. * output the filtered signal using PWM, possibly at the same rate that we are sampling the input audio. The microphone can be a 40 kHz piezo transducer, to keep it cheap (but also limited to 40 kHz). The pre-amplifier can be a single transistor with some resistors around it, providing about 40x gain. The arduino does the signal processing (mixing, low-pass filter) to shift the bat audio to human range. The speaker amplifier can just be a simple two transistor push-pull circuit, since the output from the Arduino is digital/PWM.
AVR Arduino sample rate
Indoor radar speed sign
This idea about placing a simple IQ-output radar sensor indoors in the hacker space, do some basic signal processing on the IQ doppler signal and determine movement speed and direction, then display this on a LED display. This is of no immediate practical use other than fun, but helps me to gain a bit more experience with microwave radar sensors and eventually build a more effective setup for detecting/counting bats flying in and out of a roost. Implement this on a PSOC5 platform or on the STM32 using Arduino.
