Gebruiker:Bertrik Sikken
| Name | Bertrik Sikken |
| Nick | bertrik |
| Tagline | heb ik niet |
NRF52840 boards
NRF52840 is potentially a very nice platform:
- low-power. quick wake-up
- inexpensive
- decent amount of flash (512k), RAM (512k) and CPU cycles (10s of MHz)
- support various radio protocols like zigbee, ble, thread, matter, enhanced shockburst
- built-in support for quadrature counting
- looks like it can run arduino too
However the eco-system of inexpensive boards is a complicated landscape:
- AliExpress sellers offer "promicro" and "supermini" board with unclear characteristics
- LEDs are often swapped (blue = hardware charge, red = software led?)
- Confusing firmware upload interface options
- Serial DFU
- Mass storage UF2, possibly activated using the double-reset
- SWD debug interface (requires soldering!)
- Confusing situation regarding bootloaders:
- Most boards seem to come with a modified version of a bootloader meant for another type of board
- Type of bootloader depends on type of firmware you want to run, "ZMK", Arduino using Arduino IDE, Arduino using platformio
- Space for "SoftDevice" needs to be reserved, what is this?
- Risk of accidentally overwriting the bootloader, with UF2 flash offsets sometimes being absolute, sometimes being relative
- Even multiple levels of bootloader? Like the normal one during application and another one using the double-reset method?
action lsc stekker
sipeed maix dock
rfid keyfob
- firmware github:
advanced lidars for bat detection
livox:
cubecell meshtastic motion detector
configure multitech outdoor gateway
esp32 wtf
kakofonie counter
Stuff to figure out:
- can it run on an ESP32?
- make a prototype
hypno toad
wasbeer / kat classifier
Nespresso brew counter
Remote bat box monitor
Idea:
- challenges:
- design
- hardware
KNMI API
WeAct CH55x board
Zigbee device with esp32
Cameratoezicht in Gouda
SolarEdge
Stookalert
Implementatie:
Resources:
With result:
event: state
Use an audiomoth for this.
ESP32 C3
Flexible LED ticker
Washing machine API
TinyML
Bat box busy signal
Super tiny RFID
Specification:
Actually smart boiler
Alternatives:
Receiving gas meters
Interesting leads:
Multi-network wifi manager
Interesting candidates:
Automated bat counting
What I definitely can do:
Showstoppers:
Open work:
Interesting stuff:
- https://thingsix.com/
Interesting stuff in GATT:
- service 0xC760
- 0x23
- length byte
- 0x10 0x04 fixed header
- 0x00 is ...
ribbon tweeter for bat audio
Someone gave me this idea:
3d glasses
A tear-down here:
Interesting documents:
Waterniveaumeter
Idee:
Online bat detector
- inexpensive ep2c5t144 board
mini word clock in dutch
Simple Doppler motion sensors
AVR Arduino sample rate
Indoor radar speed sign
