Gebruiker:Bertrik Sikken
| Name | Bertrik Sikken |
| Nick | bertrik |
| Tagline | heb ik niet |
- investigate if Helium has an open uplink API for their hotspots, if so study it etc
- write an application to capture TTN uplinks and forward them to Helium
- publish it as a project!
Interesting stuff in GATT:
- service 0xC760
- 0x23
- length byte
- 0x10 0x04 fixed header
- 0x00 is ...
TheThingsNetwork gateway stats
Goal: provide insight in local LoRaWAN spectrum use by watching traffic received on gateways
Source code: https://github.com/bertrik/ttn-gateway-collector
ribbon tweeter for bat audio
3d glasses
A tear-down here:
Interesting documents:
Waterniveaumeter
Idee:
Online bat detector
Blood pressure meter hacking
- bluetooth GATT profile for blood pressure monitors https://www.bluetooth.com/specifications/gatt/
- hacking the UART on an Omron RS8 : https://blog.adafruit.com/2016/05/26/hacking-uart-to-an-omron-rs8-blood-pressure-sphygmomanometer/
- https://hackaday.com/2015/10/11/push-blood-pressure-data-to-the-cloud-via-esp8266/
- hacking a blood pressure monitor by monitoring i2c traffic to the EEPOM: https://www.edusteinhorst.com/hacking-a-blood-pressure-monitor/
- inexpensive ep2c5t144 board
mini word clock in dutch
Simple Doppler motion sensors
AVR Arduino sample rate
GPS repeater
Plan:
Indoor radar speed sign
