Gebruiker:Bertrik Sikken
| Name | Bertrik Sikken |
| Nick | bertrik |
| Tagline | heb ik niet |
WiFi "top"
- only "stations" (like phones, laptops, etc) are recorded in this table, not access points
- the table records the following:
- the unique MAC address
- the time is has been seen first
- the time is has been seen last
- the wifi channel is switched at some interval
- every minute (for example), the stats are calculated from the table and published on MQTT
Operations on this table:
- entries older than 60 minutes are removed from the table.
- when we see a new unknown MAC, it's added to the table (if it fits) and we set the first-seen timestamp
- when we see a known MAC, the last-seen timestamp is updated
- getting stats from the table, for example:
- number of unique station MACs seen in the last minute
- number of unique station MACs seen in the last 5 minutes
- number of unique station MACs seen in the last 15 minutes
- number of unique station MACs seen in the last 60 minutes
- perhaps we can get stats using either the first-seen or the last-seen timestap?
Possible issues:
- privacy: the unique MAC of any Wifi station is never exposed, only cumulative numbers. If you're really concerned, consider turning off your WiFi devices (e.g. using airplane mode)
- random MACs: apparently some devices randomize their MAC address if they're not connected to a station. Not sure yet how to handle that.
- switching between promiscuous mode (for sniffing) and station mode (for reporting stats): I don't know how complicated this is, we'll see.
- transmit our own control signal, to control a quadcopter from something different than the manual remote control, e.g. automatic control
- receive the control signal, so the manual remote control that comes with a quadcopter can be used to steer other things (like a model car).
mini word clock in dutch
Local date calculation:
- http://stackoverflow.com/questions/5590429/calculating-daylight-saving-time-from-only-date
- https://github.com/niekproductions/word-clock
Understanding LoRa
Simple Doppler motion sensors
Rust
Investigate the rust language.
ESP32
- ESP32 Arduino page by Wemos
AVR Arduino sample rate
Example C code
#define BUF_SIZE 16
static void ISR(void)
static int16_t lowpass = 0;
static int32_t sum = 0;
static bool even = false;
int16_t input, signal, mixed;
input = ....
// HPF input signal
signal = input - lowpass;
lowpass += signal >> 4;
// multiply by carrier
even = !even;
sum += mixed ;
sum -= buffer[index];
buffer[index] = mixed ;
// output LPF as 8-bit number
out = sum >> 7;
Bat call cleaner
- Apply a high-pass filter to get rid of non-ultrasonics like speech, say at 10 kHz
- Convert the signal into a complex analytic signal, by creating the imaginary part using a Hilbert transform.
- The Hilbert transform can be approximated by a FIR filter of appropriate length to get the desired bandwidth.
- Split the complex signal into an instantaneous frequency and amplitude.
- The frequency is determined by differentiating the instantaneous phase (inverse tangens i/q).
- The amplitude is determined by calculating the norm of the complex signal (sqrt of i^2 + q^2)
- Average/low-pass the frequency component, say at 0.1 ms intervals. Do the same to the amplitude.
- Re-synthesize the signal s using the simple model s = A.sin(2.pi.t/f) where A is amplitude, t is time and f is frequency, interpolating A and f.
Alternative:
- chop the signal up in segments of (say) 100 ms and determine the total energy content in each segment
- choose the quietest segment and use this as a "background noise template"
- perform a fourier analysis on the template
- reduce the noise on the signal using the template:
- for each segment, apply for each frequency an attenuation based on the signal level compared to the template level
- resynthesize from fourier back into the time domain using an overlap-add method
Disable fancy modes on an inexpensive flashlight
I have one of those flashlights with an XML-T6 LED. It runs on a single 18650 and puts out about 250 lumens (guesstimate). However it also has a bunch of annoying 'modes':
- max
- bright
- low
- strobe
- SOS
The flashy modes are really annoying, I see no use for them and only makes the flashlight harder to use.
The plan is to modify the light according to instructions like these, so it becomes a '1-mode' light. Ideally, I'd like to have the max/bright/low modes without the flashy modes and also have a bigger difference between the modes, like 2.5/25/250 lumens.
