Gebruiker:Bertrik Sikken
| Name | Bertrik Sikken |
| Nick | bertrik |
| Tagline | heb ik niet |
Understand Bluetooth AP
I'm trying to understand how to set up a bluetooth AP on a basic Linux system, such that you can connect to it using an Android phone or tablet.
The idea is that there is some kind of useful application running on the Linux system, and that the "app" on the tablet/phone provides the user interface, connecting to the Linux system using REST.
Possible useful links:
- https://www.linux.com/learn/weekend-project-personal-area-networking-bluetooth
https://www.osnews.com/story/9836/Make_your_Arch_Linux_a_Bluetooth_Access_Point: quite old, uses rfcomm, basically a serial port over bluetoothhttp://bluez.sourceforge.net/contrib/HOWTO-PAN: describes setting up a network using the "pand" utility, can't find that utility- bluetooth device class calculator
- http://blog.fraggod.net/2015/03/28/bluetooth-pan-network-setup-with-bluez-5x.html
- bt-pan script as referred by the link above
My starting point is:
- a Yocto based Linux distribution
- a Linux 4.1 kernel
- Bluez 5
Understanding the various Linux drivers and tools in the Linux bluetooth stack
- btusb: the Linux kernel driver module for many USB/bluetooth adapters, 'modprobe'-ing this module also magically takes care of downloading firmware needed
- hciconfig, low-level configuration utility for manipulating a bluetooth controller. A bit like ifconfig, it can bring the interface up or down, set options, etc.
- hcitool, yet another utility to perform low-level blue operations, like querying the name of paired devices
- bluetoothd, the bluetooth daemon
- /etc/bluetooth/main.conf supposedly (one of) the configuration files for bluetoothd
- bluetoothd can be accessed over DBUS apparently, see Bluez docs
- bluetoothctl, a more high-level configuration utility, basically a command line user interface towards bluetoothd as I understand it.
And some acronyms:
- NAP: network access protocol
- PAN: personal area network
- BNEP: bluetooth network encapsulation protocol
Getting somewhere: ?
dbus-send --system --type=method_call --print-reply --dest=org.bluez /org/bluez/hci0 org.bluez.NetworkServer1.Register string:'nap' string:'bnep'
- transmit our own control signal, to control a quadcopter from something different than the manual remote control, e.g. automatic control
- receive the control signal, so the manual remote control that comes with a quadcopter can be used to steer other things (like a model car).
mini word clock in dutch
Local date calculation:
- http://stackoverflow.com/questions/5590429/calculating-daylight-saving-time-from-only-date
- https://github.com/niekproductions/word-clock
Understanding LoRa
Simple Doppler motion sensors
Rust
Investigate the rust language.
ESP32
I have a Wemos "LOLIN32 V1.0.0" ESP32 board, play with it. Discover bluetooth capabilities, low power modes. Compare it with ESP32.
- ESP32 Arduino page by Wemos
