Gebruiker:Bertrik Sikken
| Name | Bertrik Sikken |
| Nick | bertrik |
| Tagline | heb ik niet |
CC2540 bluetooth low-energy dongle
The plan is to get this dongle to work and to sniff bluetooth low energy traffic. Also it would be nice if this things works under Linux, e.g. in combination with WireShark with a plugin that can make sense of BTLE frames.
I've had this BLE dongle for at least a year, but was somehow under the impression that it doesn't work. When you plug it into a Linux computer, you just see a USB configuration with one bulk input pipe.
It's supposedly a CC2540 (or compatible) dongle, the USB id is 0451:16b3. It appears it already has a sniffing firmware flashed onto it. It works under Windows with the software from TI. I've successfully sniffed the USB traffic to/from this dongle while capturing some BLE traffic.
Interesting links:
- https://lacklustre.net/bluetooth/wireshark.html
- https://processors.wiki.ti.com/index.php/BLE_sniffer_guide
- https://github.com/andrewdodd/ccsniffpiper
- transmit our own control signal, to control a quadcopter from something different than the manual remote control, e.g. automatic control
- receive the control signal, so the manual remote control that comes with a quadcopter can be used to steer other things (like a model car).
TTN gateway info panel
Problem: if you're running a gateway for the-things-network (TTN), you can see packets coming in by following the packet forwarder log file, but it gives very limited and rather cryptic information. For example, you don't see which node sent a message, so you have no idea how many unique nodes are sending data through your gateway.
This idea is about creating a simple info panel that you can run directly on the TTN gateway itself. The plan is to write this in Python. A typical gateway probably already runs some sort of Linux distribution which has the python binaries available or allows them to be installed easily. Using Python also means that you don't need a compiler/Makefile/etc.
Basic operation of this utility:
- the gateway software is configured to send its data not just to TTN but also to the gateway info panel utility (running on "localhost"), using the poly packet forwarder
- the utility listens on a specific UDP port, accepting data according to the Semtech v1 protocol.
- it parses the plain JSON metadata (modulation parameters, like frequency, LoRa mode, SF, BW, etc.)
- it also parses the payload bytes, part of the payload is not encrypted, so we can extract the message type, device address and sequence number (FCNT).
- all incoming packets are shown in a table-like view in the console using the ncurses library.
Initially, the utility will just keep the packets in memory, so it just shows things that happened since you last started it. Later, we can decide to store the data, for example in a database.
The information shown can be just the incoming messages in order of arrival, one line per message. Alternatively it could show a kind of node-centric view, one line per device with info only on the latest message from that node.
mini word clock in dutch
Understanding LoRa
Android HabAlert app
see HabAlertApp
Inexpensive ultrasonic player
see UltrasonicPlayer
