Gebruiker:Bertrik Sikken
| Name | Bertrik Sikken |
| Nick | bertrik |
| Tagline | heb ik niet |
TTN - HAB balloon telemetry bridge
This idea is about using the-things-network as a receiver for amateur balloon telemetry.
Receiving telemetry from amateur balloons is currently typically done on the 434 MHz band using RTTY modulation, sending ASCII strings to dedicated receivers. The operator of each receiver has to be prepared for receiving the telemetry, by tuning to the correct frequency at the correct time, setting up a dedicated software client that decodes the RTTY modulation and forwards the data to a central system over the internet. The central system accepts data from many such receivers, performs deduplication, keeps track of who received what and updates a nice graphical map of where each balloon is and where the receivers are.
A network like the-things-network can help a lot, it has a lot of gateways already (in the netherlands at least..), already performs deduplication. Also LoRa as a modulation scheme is much more sensitive than RTTY.
In short, the idea is:
- you attach a LoRaWAN transmitter to the balloon
- the LoRaWAN transmitter is pre-configured with a set of keys generated by the TTN
- for each packet, we know which gateways received it and where they are. So we can "fake" a client for each gateway and construct an ASCII sentence according to the HAB server conventions
- the HAB server still sees the same messages like it would if there many traditional receivers, so doesn't need any modification.
This way, the entire things network can be used to receive balloon telemetry! There is no longer a need for operators to be present at their receiver at the exact time the balloon is launched, making manual adjustments, etc. The Netherlands is already covered by many TTN gateways, greatly increasing the chance the balloon telemetry will be picked up.
Stuff to do:
- come up with a simple but flexible way to encode telemetry in a binary packet, to be transmitted over TTN.
- figure out how to receive data from TTN, I think this is an MQTT stream
- figure out how to find the coordinates of each TTN gateway
- figure out the protocol between dl-fldigi and the HAB server
- implement this (in Java for example)!
WiFi "top"
- only "stations" (like phones, laptops, etc) are recorded in this table, not access points
- the table records the following:
- the unique MAC address
- the time is has been seen first
- the time is has been seen last
- the wifi channel is switched at some interval
- every minute (for example), the stats are calculated from the table and published on MQTT
Operations on this table:
- entries older than 60 minutes are removed from the table.
- when we see a new unknown MAC, it's added to the table (if it fits) and we set the first-seen timestamp
- when we see a known MAC, the last-seen timestamp is updated
- getting stats from the table, for example:
- number of unique station MACs seen in the last minute
- number of unique station MACs seen in the last 5 minutes
- number of unique station MACs seen in the last 15 minutes
- number of unique station MACs seen in the last 60 minutes
- perhaps we can get stats using either the first-seen or the last-seen timestap?
Possible issues:
- privacy: the unique MAC of any Wifi station is never exposed, only cumulative numbers. If you're really concerned, consider turning off your WiFi devices (e.g. using airplane mode)
- random MACs: apparently some devices randomize their MAC address if they're not connected to a station. Not sure yet how to handle that.
- switching between promiscuous mode (for sniffing) and station mode (for reporting stats): I don't know how complicated this is, we'll see.
Understand Bluetooth AP
I'm trying to understand how to set up a bluetooth AP on a basic Linux system, such that you can connect to it using an Android phone or tablet.
The idea is that there is some kind of useful application running on the Linux system, and that the "app" on the tablet/phone provides the user interface, connecting to the Linux system using REST.
Possible useful links:
- https://www.linux.com/learn/weekend-project-personal-area-networking-bluetooth
https://www.osnews.com/story/9836/Make_your_Arch_Linux_a_Bluetooth_Access_Point: quite old, uses rfcomm, basically a serial port over bluetoothhttp://bluez.sourceforge.net/contrib/HOWTO-PAN: describes setting up a network using the "pand" utility, can't find that utility- bluetooth device class calculator
- http://blog.fraggod.net/2015/03/28/bluetooth-pan-network-setup-with-bluez-5x.html
- bt-pan script as referred by the link above
- Is Your Personal Area Network Giving You the BlueZ?
My starting point is:
- a Yocto based Linux distribution
- a Linux 4.1 kernel
- Bluez 5
Understanding the various Linux drivers and tools in the Linux bluetooth stack
- btusb: the Linux kernel driver module for many USB/bluetooth adapters, 'modprobe'-ing this module also magically takes care of downloading firmware needed
- hciconfig, low-level configuration utility for manipulating a bluetooth controller. A bit like ifconfig, it can bring the interface up or down, set options, etc.
- hcitool, yet another utility to perform low-level bluetooth operations, like querying the name of paired devices
- bluetoothd, the bluetooth daemon
- /etc/bluetooth/main.conf : supposedly (one of) the configuration files for bluetoothd
- bluetoothd can be accessed over DBUS apparently, see Bluez docs
- bluetoothctl, a more high-level configuration utility, basically a command line user interface towards bluetoothd as I understand it.
And some acronyms:
- NAP: network access protocol
- PAN: personal area network
- BNEP: bluetooth network encapsulation protocol
Getting somewhere: ?
dbus-send --system --type=method_call --print-reply --dest=org.bluez /org/bluez/hci0 org.bluez.NetworkServer1.Register string:'nap' string:'bnep'
- following this guide on the server-side (requires systemd): https://blind.guru/tag/bluetooth-pan.html#a-bluetooth-pan-access-point-with-systemd
- transmit our own control signal, to control a quadcopter from something different than the manual remote control, e.g. automatic control
- receive the control signal, so the manual remote control that comes with a quadcopter can be used to steer other things (like a model car).
mini word clock in dutch
Local date calculation:
- http://stackoverflow.com/questions/5590429/calculating-daylight-saving-time-from-only-date
- https://github.com/niekproductions/word-clock
Understanding LoRa
Simple Doppler motion sensors
Rust
Investigate the rust language.
ESP32
- ESP32 Arduino page by Wemos
AVR Arduino sample rate
Example C code
#define BUF_SIZE 16
static void ISR(void)
static int16_t lowpass = 0;
static int32_t sum = 0;
static bool even = false;
int16_t input, signal, mixed;
input = ....
// HPF input signal
signal = input - lowpass;
lowpass += signal >> 4;
// multiply by carrier
even = !even;
sum += mixed ;
sum -= buffer[index];
buffer[index] = mixed ;
// output LPF as 8-bit number
out = sum >> 7;
Bat call cleaner
- Apply a high-pass filter to get rid of non-ultrasonics like speech, say at 10 kHz
- Convert the signal into a complex analytic signal, by creating the imaginary part using a Hilbert transform.
- The Hilbert transform can be approximated by a FIR filter of appropriate length to get the desired bandwidth.
- Split the complex signal into an instantaneous frequency and amplitude.
- The frequency is determined by differentiating the instantaneous phase (inverse tangens i/q).
- The amplitude is determined by calculating the norm of the complex signal (sqrt of i^2 + q^2)
- Average/low-pass the frequency component, say at 0.1 ms intervals. Do the same to the amplitude.
- Re-synthesize the signal s using the simple model s = A.sin(2.pi.t/f) where A is amplitude, t is time and f is frequency, interpolating A and f.
Alternative:
- chop the signal up in segments of (say) 100 ms and determine the total energy content in each segment
- choose the quietest segment and use this as a "background noise template"
- perform a fourier analysis on the template
- reduce the noise on the signal using the template:
- for each segment, apply for each frequency an attenuation based on the signal level compared to the template level
- resynthesize from fourier back into the time domain using an overlap-add method
