Gebruiker:Bertrik Sikken
User info Bertrik Sikken
Name Bertrik Sikken
Nick bertrik
Tagline heb ik niet
 Project Status
FrontDoorDisplayAbandoned
HabAlertAppAbandoned
ISSOAbandoned
IbmPosDisplayAbandoned
Pico TrackersAbandoned
RadarOnAStickAbandoned
WifiLampAbandoned
A4PaperDispenserCompleted
CJMCU-811Completed
CO2MeterHackingCompleted
CrawlSpaceSensorCompleted
DecodingLoraCompleted
DustSensorCompleted
ElectronicLoadCompleted
EspNowSkipCompleted
IntakefancontrollerCompleted
LichtKrantCompleted
LoRaGatewayCompleted
LoraBatBoxCompleted
LoraWanNodeCompleted
MHZ19Completed
MainsFrequencyCompleted
MiniSTM32F103ZECompleted
PowerLightCompleted
RC522HackingCompleted
RevRadioCompleted
STM32Completed
Secure iButtonCompleted
SoilHumiditySensorCompleted
StofAnanasCompleted
StofradarCompleted
TTNHABBridgeCompleted
VINDRIKTNINGCompleted
ZigbeeCoordinatorCompleted
Sensor-data-bridgeCompleted
AntiLostIn progress
AudioMothIn progress
BT785In progress
CubeCellIn progress
EspAudioSensorIn progress
Esp32camIn progress
FMCWRadarIn progress
Its-g5In progress
KaraburanIn progress
LoRa-E5-miniIn progress
LoraWanDustSensorIn progress
MainsFrequency2.0In progress
MeshtasticIn progress
Msi2500SDRIn progress
... meer resultaten
Remote bat box monitor
Idea:
  • goal: check if remote bat boxes are occupied and identify the species
  • challenges:
    • connectivity: need to transport images/videos (no LoRaWAN), possibly out of range of mobile data networks
    • autonomy: cannot reach the bat box once installed
    • power: no fixed power connection, so probably needs a battery + solar panel
  • wake up every hour, take a picture, go to sleep, upload photos/videos once per day
  • wireless connectivity: 4G "mifi" stick connected to USB
  • run from batteries, recharge by solar, rules of thumb
    • batteries should last for about 10 days
    • battery should be able to charge in 1 day
    • consider only 10% of peak solar power
  • this hat to wake up the main CPU: https://www.kiwi-electronics.com/en/power-management-hat-for-raspberry-pi-with-rtc-and-rp2040-mcu-11373
  • raspberry pi power consumption overview: https://www.pidramble.com/wiki/benchmarks/power-consumption
KNMI API
WeAct CH55x board
Zigbee device with esp32
Cameratoezicht in Gouda
SolarEdge
Stookalert
Implementatie:
Resources:
With result:
 event: state
Use an audiomoth for this.
ESP32 C3
Flexible LED ticker
Washing machine API
TinyML
Bat box busy signal
Super tiny RFID
Specification:
Actually smart boiler
Alternatives:
Receiving gas meters
Interesting leads:
Multi-network wifi manager
Interesting candidates:
Automated bat counting
What I definitely can do:
Showstoppers:
Open work:
Interesting stuff:
Interesting stuff in GATT:
  • service 0xC760
  • 0x23
  • length byte
  • 0x10 0x04 fixed header
  • 0x00 is ...
ribbon tweeter for bat audio
3d glasses
A tear-down here:
Interesting documents:
Waterniveaumeter
Idee:
Online bat detector
mini word clock in dutch
Simple Doppler motion sensors
AVR Arduino sample rate
Indoor radar speed sign
