Gebruiker:Bertrik Sikken
| Name | Bertrik Sikken |
| Nick | bertrik |
| Tagline | heb ik niet |
Receiving gas meters
Apparently sending data to the smart meter using a wireless link in the 868 MHz band. Probably just FSK at 38.4, as mentioned here: https://a35.veron.nl/nieuwe-elektra-en-gasmeters/
Multi-network wifi manager
Interesting candidates:
Automated bat counting
XBEE
- XBR-001-06
- FCC ID: MCQ-PROS2B, see https://fccid.io/MCQ-PROS2B
- IC: 1846A-PROS2B
What I definitely can do:
Showstoppers:
Open work:
- investigate if Helium has an open uplink API for their hotspots, if so study it etc, without paying the gateway fee
Interesting stuff:
Interesting stuff in GATT:
- service 0xC760
- 0x23
- length byte
- 0x10 0x04 fixed header
- 0x00 is ...
ribbon tweeter for bat audio
3d glasses
A tear-down here:
Interesting documents:
Waterniveaumeter
Idee:
Online bat detector
Blood pressure meter hacking
- bluetooth GATT profile for blood pressure monitors https://www.bluetooth.com/specifications/gatt/
- hacking the UART on an Omron RS8 : https://blog.adafruit.com/2016/05/26/hacking-uart-to-an-omron-rs8-blood-pressure-sphygmomanometer/
- https://hackaday.com/2015/10/11/push-blood-pressure-data-to-the-cloud-via-esp8266/
- hacking a blood pressure monitor by monitoring i2c traffic to the EEPOM: https://www.edusteinhorst.com/hacking-a-blood-pressure-monitor/
- inexpensive ep2c5t144 board
mini word clock in dutch
Simple Doppler motion sensors
AVR Arduino sample rate
GPS repeater
Plan:
Indoor radar speed sign
