Gebruiker:Bertrik Sikken
| Name | Bertrik Sikken |
| Nick | bertrik |
| Tagline | heb ik niet |
ESP mesh networking
The makers of the ESP8266 provide a software stack to run a 'mesh network' between ESP8266 nodes. As I understand this allows several ESP devices to join together and create a kind of dynamic network.
What is not quite clear is how this is all modelled. For example, do devices have addresses. And if so, what kind? Does this thing run on top of TCP/IP, or does it run on raw wifi frames? Can you designate one particular node as the 'root node' and let it bridge communication with other networks? Can you do transient low-power communication with the mesh network, e.g. wake-up, send a message, go back to sleep?
Links:
Zigbee stick for home automation
zigbee2mqtt site has information on how to flash a CC2531 usb-zigbee stick:
- How to flash using an ESP8266 https://www.zigbee2mqtt.io/information/alternative_flashing_methods.html
- Supported Zigbee devices (like an IKEA TRADFRI): https://www.zigbee2mqtt.io/information/supported_devices.html
Battery-powered ESP8266 nodes
These ESP8266 boards with 18650 battery look like nice candidates for a low-power standalone sensor node.
Measured battery current: the board draws about 14 mA in deep sleep mode, so this totally ruins any low-power possibilities, draining a typical 18650 in about 100 hours.
The battery makes it a standalone board. Putting it in sleep mode most of the time makes it low power. Using ESP now makes it possible to send data with very low latency so the time that the board is actually powered up is very short time (approximately 200 ms) and so power consumption stays low.
- inexpensive ep2c5t144 board
AI on Raspberry Pi
Particulate matter sensor at RevSpace
- Sensor id: 12012657
- BME280 https://www.madavi.de/sensor/graph.php?sensor=esp8266-12012657-bme280
- SDS011 https://www.madavi.de/sensor/graph.php?sensor=esp8266-12012657-sds011
P1 meter on MQTT
The plan is to push the P1-data from my smart meter onto MQTT and then have other things listening on it and perhaps do actual smart things with this data.
I have a Kaifa M105a, more info about smart meters: http://domoticx.com/p1-poort-slimme-meter-hardware/
This could be as simple as an ESP8266-based microcontroller (Wemos D1 mini) just listening on the P1 port and forwarding the data. Unfortunately the port does not appear to provide enough power for the microcontroller, and I have no socket to plug in a power supply in the metering closet.
LoRa node for airborne particulate matter measurement
The idea is to use an SDS011 particulate matter sensor and make it send its measurement data over LoRa to TheThingsNetwork (TTN). An application listens on the TTN MQTT stream and forwards it to luftdaten.
TODO
- configure an application with TTN (application id, keys etc.)
- create firmware for an ESP32-TTGO-LoRa module
- create middleware that listens on the TTN MQTT stream, decodes it and forwards the data to luftdaten (I have done both before in Java, just combine it in a new application).
The plan is:
- I have a cool housing for this, which already has a connection for the antenna and a bunch of solar cells.
- Use with an SDS011 for airborne particulate measurement
For the embedded software:
- use Arduino framework
- use Arduino LMIC library for TTN communication
- use Arduino SDS011 libs from luftdaten.info?
For the forwarding software:
- use Java to listen on TTN MQTT
- use Java code I've already written to forward it to luftdaten API
- all sensors send to the same TTN 'application'
SpaceBike tracker
The idea is to use an ESP32-LoRa board + GPS to track the location of the SpaceBike. It sends periodic position updates of the location using radio to TheThingsNetwork. Power consumption is not really an issue since it's an e-bike and has a huge onboard battery, but is still expected to be fairly low anyway (milliamps).
For the privacy-conscious, it can be switched on/off. Perhaps we can do other fun/useful stuff too:
- send data about the state of the battery.
- capture WiFi APs for projects like https://wigle.net/
- measure air pollution vs position
- collect cool stats about usage, e.g. distance achieved, hours spent, etc.
QR codes for money transfer
The following document is a short description on how to encode a money transfer request in a QR code: https://www.europeanpaymentscouncil.eu/document-library/guidance-documents/quick-response-code-guidelines-enable-data-capture-initiation
The SEPA QR code is basically just a set of text lines with predefined meaning, describing the amount and the beneficiary.
https://qrcode.tec-it.com/en/sepa https://en.m.wikipedia.org/wiki/EPC_QR_code
STM32 stlink V2
ESP32 LoRa
I have one of these ESP32 TTGO LoRa boards.
First thing I tried:
- https://github.com/osresearch/esp32-ttgo seems mostly concerned with pretty graphics on the OLED, no LoRa code
Some more promising links:
HC-06 stuff
To set odd parity:
AT+PO
WiFi "top"
- only "stations" (like phones, laptops, etc) are recorded in this table, not access points
- the table records the following:
- the unique MAC address
- the time is has been seen first
- the time is has been seen last
- the wifi channel is switched at some interval
- every minute (for example), the stats are calculated from the table and published on MQTT
Operations on this table:
- entries older than 60 minutes are removed from the table.
- when we see a new unknown MAC, it's added to the table (if it fits) and we set the first-seen timestamp
- when we see a known MAC, the last-seen timestamp is updated
- getting stats from the table, for example:
- number of unique station MACs seen in the last minute
- number of unique station MACs seen in the last 5 minutes
- number of unique station MACs seen in the last 15 minutes
- number of unique station MACs seen in the last 60 minutes
- perhaps we can get stats using either the first-seen or the last-seen timestap?
Possible issues:
- privacy: the unique MAC of any Wifi station is never exposed, only cumulative numbers. If you're really concerned, consider turning off your WiFi devices (e.g. using airplane mode)
- random MACs: apparently some devices randomize their MAC address if they're not connected to a station. Not sure yet how to handle that.
- switching between promiscuous mode (for sniffing) and station mode (for reporting stats): I don't know how complicated this is, we'll see.
- transmit our own control signal, to control a quadcopter from something different than the manual remote control, e.g. automatic control
- receive the control signal, so the manual remote control that comes with a quadcopter can be used to steer other things (like a model car).
mini word clock in dutch
Local date calculation:
- http://stackoverflow.com/questions/5590429/calculating-daylight-saving-time-from-only-date
- https://github.com/niekproductions/word-clock
Understanding LoRa
Simple Doppler motion sensors
AVR Arduino sample rate
Example C code
#define BUF_SIZE 16
static void ISR(void)
static int16_t lowpass = 0;
static int32_t sum = 0;
static bool even = false;
int16_t input, signal, mixed;
input = ....
// HPF input signal
signal = input - lowpass;
lowpass += signal >> 4;
// multiply by carrier
even = !even;
sum += mixed ;
sum -= buffer[index];
buffer[index] = mixed ;
// output LPF as 8-bit number
out = sum >> 7;
Bat call cleaner
- Apply a high-pass filter to get rid of non-ultrasonics like speech, say at 10 kHz
- Convert the signal into a complex analytic signal, by creating the imaginary part using a Hilbert transform.
- The Hilbert transform can be approximated by a FIR filter of appropriate length to get the desired bandwidth.
- Split the complex signal into an instantaneous frequency and amplitude.
- The frequency is determined by differentiating the instantaneous phase (inverse tangens i/q).
- The amplitude is determined by calculating the norm of the complex signal (sqrt of i^2 + q^2)
- Average/low-pass the frequency component, say at 0.1 ms intervals. Do the same to the amplitude.
- Re-synthesize the signal s using the simple model s = A.sin(2.pi.t/f) where A is amplitude, t is time and f is frequency, interpolating A and f.
Alternative:
- chop the signal up in segments of (say) 100 ms and determine the total energy content in each segment
- choose the quietest segment and use this as a "background noise template"
- perform a fourier analysis on the template
- reduce the noise on the signal using the template:
- for each segment, apply for each frequency an attenuation based on the signal level compared to the template level
- resynthesize from fourier back into the time domain using an overlap-add method
ESP8266 as modbus master:
GPS repeater
Plan:
Indoor radar speed sign
