Gebruiker:Bertrik Sikken
User info Bertrik Sikken
Name Bertrik Sikken
Nick bertrik
Tagline heb ik niet
 Project Status
FrontDoorDisplayAbandoned
HabAlertAppAbandoned
ISSOAbandoned
IbmPosDisplayAbandoned
Pico TrackersAbandoned
RadarOnAStickAbandoned
WifiLampAbandoned
A4PaperDispenserCompleted
CJMCU-811Completed
CO2MeterHackingCompleted
CrawlSpaceSensorCompleted
DecodingLoraCompleted
DustSensorCompleted
ElectronicLoadCompleted
EspNowSkipCompleted
IntakefancontrollerCompleted
LichtKrantCompleted
LoRaGatewayCompleted
LoraBatBoxCompleted
LoraWanNodeCompleted
MHZ19Completed
MainsFrequencyCompleted
MiniSTM32F103ZECompleted
PowerLightCompleted
RC522HackingCompleted
RevRadioCompleted
STM32Completed
Secure iButtonCompleted
SoilHumiditySensorCompleted
StofAnanasCompleted
StofradarCompleted
TTNHABBridgeCompleted
VINDRIKTNINGCompleted
ZigbeeCoordinatorCompleted
Sensor-data-bridgeCompleted
AntiLostIn progress
AudioMothIn progress
BT785In progress
CubeCellIn progress
EspAudioSensorIn progress
Esp32camIn progress
FMCWRadarIn progress
Its-g5In progress
KaraburanIn progress
LoRa-E5-miniIn progress
LoraWanDustSensorIn progress
MainsFrequency2.0In progress
MeshtasticIn progress
Msi2500SDRIn progress
... meer resultaten
QR codes for money transfer
https://www.europeanpaymentscouncil.eu/document-library/guidance-documents/quick-response-code-guidelines-enable-data-capture-initiation
STM32 stlink V2
ESP32 LoRa
I have one of these ESP32 TTGO LoRa boards.
First thing I tried:
Some more promising links:
HC-06 stuff
To set odd parity:
AT+PO
WiFi "top"
    • the unique MAC address
Operations on this table:
Possible issues:
mini word clock in dutch
Local date calculation:
Understanding LoRa
Simple Doppler motion sensors
AVR Arduino sample rate
Example C code
#define BUF_SIZE    16
static void ISR(void)
    static int16_t lowpass = 0;
    static int32_t sum = 0;
    static bool even = false;
    int16_t input, signal, mixed;
    input = ....
    // HPF input signal
    signal = input - lowpass;
    lowpass += signal >> 4;
    // multiply by carrier
    even = !even;
    sum += mixed ;
    sum -= buffer[index];
    buffer[index] = mixed ;
    // output LPF as 8-bit number
    out = sum >> 7;
Bat call cleaner
Alternative:
ESP8266 as modbus master:
GPS repeater
Plan:
Indoor radar speed sign
