Gebruiker:Bertrik Sikken
Versie door Bertrik Sikken (overleg | bijdragen) op 4 apr 2018 om 14:30 (line frequency counter idea)
User info Bertrik Sikken
Name Bertrik Sikken
Nick bertrik
Tagline heb ik niet
 Project Status
FrontDoorDisplayAbandoned
HabAlertAppAbandoned
ISSOAbandoned
IbmPosDisplayAbandoned
Pico TrackersAbandoned
RadarOnAStickAbandoned
WifiLampAbandoned
A4PaperDispenserCompleted
CJMCU-811Completed
CO2MeterHackingCompleted
CrawlSpaceSensorCompleted
DecodingLoraCompleted
DustSensorCompleted
ElectronicLoadCompleted
EspNowSkipCompleted
IntakefancontrollerCompleted
LichtKrantCompleted
LoRaGatewayCompleted
LoraBatBoxCompleted
LoraWanNodeCompleted
MHZ19Completed
MainsFrequencyCompleted
MiniSTM32F103ZECompleted
PowerLightCompleted
RC522HackingCompleted
RevRadioCompleted
STM32Completed
Secure iButtonCompleted
SoilHumiditySensorCompleted
StofAnanasCompleted
StofradarCompleted
TTNHABBridgeCompleted
VINDRIKTNINGCompleted
ZigbeeCoordinatorCompleted
Sensor-data-bridgeCompleted
AntiLostIn progress
AudioMothIn progress
BT785In progress
CubeCellIn progress
EspAudioSensorIn progress
Esp32camIn progress
FMCWRadarIn progress
Its-g5In progress
KaraburanIn progress
LoRa-E5-miniIn progress
LoraWanDustSensorIn progress
MainsFrequency2.0In progress
MeshtasticIn progress
Msi2500SDRIn progress
... meer resultaten
ESP8266-based line frequency counter
This idea is about connecting a device to mains power and make it measure the AC line frequency. Compare it using a reference clock (GPS PPS clock? 32768 Hz watch crystal? TCXO?). Display the frequency with 2 significant digits and also publish it over MQTT (over WiFi). Perhaps keep track of cumulative error too.
Measurement principles:
  • You could count the number of cycles over a fixed period, say 100 seconds. This should be 5000 counts nominally, so just place a dot in the middle and you have your frequency. This could be done using a 100-element buffer that acts as a moving window averager. Each buffer element keeps the cycle count of one particular second in the 100-second period. This way you get 0.01 Hz resolution but also 1 second update rate, it takes 100 seconds for the filter to 'settle' though.
  • Count the time taken for a fixed number cycles and take the inverse. Seems more complicated.
Input circuit:
PlatformIO
Investigate PlatformIO for Arduino projects. It appears this framework can help you build Arduino projects as a self-contained project with all properties defined in a text file, without having to configure them manually in the IDE each time (e.g. which board you are compiling for, board options, lwip settings, memory size, cpu speed, etc.)
HC-06 stuff
To set odd parity:
AT+PO
WiFi "top"
    • the unique MAC address
Operations on this table:
Possible issues:
mini word clock in dutch
Local date calculation:
Understanding LoRa
Simple Doppler motion sensors
Rust
Investigate the rust language.
ESP32
AVR Arduino sample rate
Example C code
#define BUF_SIZE    16
static void ISR(void)
    static int16_t lowpass = 0;
    static int32_t sum = 0;
    static bool even = false;
    int16_t input, signal, mixed;
    input = ....
    // HPF input signal
    signal = input - lowpass;
    lowpass += signal >> 4;
    // multiply by carrier
    even = !even;
    sum += mixed ;
    sum -= buffer[index];
    buffer[index] = mixed ;
    // output LPF as 8-bit number
    out = sum >> 7;
Bat call cleaner
Alternative:
Disable flashy modes on an inexpensive flashlight
I have one of those flashlights with an XML-T6 LED. It runs on a single 18650 and puts out about 250 lumens (guesstimate). However it also has a bunch of annoying 'modes':
  • max
  • bright
  • low
  • strobe
  • SOS
The flashy modes are really annoying, I see no use for them and only makes the flashlight harder to use.
The plan is to modify the light according to instructions like these, so it becomes a '1-mode' light. Ideally, I'd like to have the max/bright/low modes without the flashy modes and also have a bigger difference between the modes, like 2.5/25/250 lumens.
ESP8266 as modbus master:
GPS repeater
Plan:
Indoor radar speed sign
