Secure iButton
| Project Secure iButton | |
| Contact | User:Bertrik Sikken |
| Last Update | 2013-01-09 |
| Project Name | Project Status | Project Contact | |
| 35c3bus | 35C3Bus | Abandoned | Bas |
| Afkortzaag Trolley | Afkortzaag Trolley | Abandoned | Crashjuh |
| Bakfiets | Bakfiets | Abandoned | Hammercat |
| Blahaj counter | Blahaj counter | Abandoned | Noor |
| BBQ Dak | Dak voor de BBQ space | Abandoned | Cfw |
| DeCRASH | DeCRASH | Abandoned | Crashjuh |
| Esp32ink | ESP32Ink | Abandoned | Bas |
| EpsonHX20 | Epson HX20 | Abandoned | Bas |
| FrontDoorDisplay | FrontDoorDisplay | Abandoned | Bertrik Sikken |
| HabAlertApp | HAB alert app | Abandoned | Bertrik Sikken |
| HackVerbatimPowerBay | Hacking the Verbatim PowerBay Nas | Abandoned | FooBar |
| ISSO | ISSO | Abandoned | Bertrik Sikken Bas |
| IbmPosDisplay | IbmPosDisplay | Abandoned | Bertrik Sikken |
| Ik leg een tientje in | Ik leg een tientje in | Abandoned | Bas |
| ImprovedLaosLaser | Improved LaosLAser | Abandoned | FooBar |
| KinderSupriseChallenge | KinderSupriseChallenge | Abandoned | Crashjuh Jelly Bas |
| Klokkie | Klokkie | Abandoned | Pwuts |
| Knopje 2 | Knopje 2 | Abandoned | Bas |
| Laadpunt | Laadpunt | Abandoned | Merethan |
| Lange lichtkrant | Lange Lichtkrant | Abandoned | Maxell Bas |
| Lasercutter2 | Lasercutter2 | Abandoned | Mux |
| RevSpace App | MacOS in Qemu-KVM RevSpace App | Abandoned Completed | Peetz0r |
| Noise cancelling megaphone | Noise Cancelling Megaphone | Abandoned | Walter |
| Noodlamp 2.0 | Noodlamp 2.0 | Abandoned | Pwuts |
| Norfolk | Norfolk | Abandoned | Qguv |
| Pico Trackers | Pico Trackers | Abandoned | Bertrik Sikken |
| RadarOnAStick | RadarOnAStick | Abandoned | Bertrik Sikken |
| Projects/RevDome | RevDome | Abandoned | Walter |
| Lathe | RevLathe | Abandoned | Pwuts |
| RevSmoker | RevSmoker | Abandoned | Gori |
| RevQuest | Revspace Oculus Quest | Abandoned | Bas |
| RevspaceMug | RevspaceMug | Abandoned | Bas |
| Rf24deurbel | Rf24deurbel v1.1 | Abandoned | Crashjuh |
| Ruimteposters | Ruimteposters | Abandoned | Bas |
| SEM oud | SEM | Abandoned | PeterC Shiz Peterbjornx |
| Space-tv | Space-tv | Abandoned | Dave o |
| SparkShack 2 | SparkShack | Abandoned | Morphje Gori Juerd Bas |
| SparkshackAlert | SparkshackAlert | Abandoned | Bas |
| SpiekerFoon | SpiekerFoon | Abandoned | Pwuts |
| Thuisrecepten | Thuisrecepten | Abandoned | F0x Bas |
| Transpotter | Transpotter | Abandoned | Bas |
| UMD | UMD | Abandoned | Eightdot Bas |
| Useless Machine | Useless Machine | Abandoned | Costyn van Dongen |
| Watermeter | Watermeter | Abandoned | Bas |
| WifiLamp | WifiLamp | Abandoned | Bertrik Sikken |
| Zwart | Zwart | Abandoned | Boekenwuurm Bas |
| RevUAV | revUAV | Abandoned | Marcel |
| !revbank | !revbank | Completed | Juerd |
| 35C3 Tickets | 35C3 Tickets | Completed | FooBar |
| 36C3 Streams | 36C3 Streams kijken | Completed | Bas |
| 36C3 Tickets | 36C3 Tickets | Completed | Bestuur |
| 4G IoT | 4G IoT | Completed | Juerd |
| A4PaperDispenser | A4PaperDispenser | Completed | Bertrik Sikken Bas |
| ACS Current probe | ACS730 Hall-Effect Current Probe | Completed | Kartoffel |
| AddiSpecificKnittingLoom | Addi compatible knitting loom | Completed | Molenaar |
| Analogecams | Analoge Cams | Completed | Peetz0r Bas |
| Another JBC | Another JBC | Completed | Bas |
| Arcade repair course | Arcade console repair classes | Completed | Mahjongg |
| Assembling RhoCoCo | Assembling a RhoCoCo home computer | Completed | Mahjongg |
| Augurken | Augurken | Completed | |
| ... meer resultaten | |||
This project is about investigating and using the secure features of the iButton that people currently use for physical access to RevSpace.
Planned project phases are:
- phase 1: investigate possbilities of the iButton and experiment with it
- phase 2: write software for the iButton functionality and package it into a library
- phase 3: apply knowledge and software for application within RevSpace
iButton investigation
The iButton used at RevSpace is the DS1961, with the following features:
- 4 pages of 32-byte user data each
- an 8-byte write-only "secret"
- SHA-1 algorithm that can calculate a hash over a 32-byte user data page, the 8-byte secret, a 3-byte "challenge" and the unique iButton id.
Basically authentication could work like this:
- (the secret key has been installed on the iButton previously)
- user presents iButton to the reader
- reader reads the unique iButton id
- reader generates a random number and uses this as the challenge to read a 32-byte user page
- iButton sends the user page, followed by the SHA-1 hash
- reader also calculates SHA-1 hash and compares it with the iButton hash
- if the hash matches, the user data can be considered as authentic and the reader can interpret the user data as a "deelnemer id" (or something) for example.
Bus pirate experimentation
Investigation of the DS1961-specific commands can be done with a Bus Pirate. A bus pirate speaks the 1-wire protocol that any iButton-like device uses.
Examples of bus pirate commands to communicate with the DS1961:
- Initialise the bus pirate
# (reset the bus pirate) M (select mode) 2 (1-wire mode) W (enable power)
- Reset the iButton and get iButton unique id
(240)
- Write scratchpad (command 0x0F) at address 0,0 with data 1 2 3 4 5 6 7 8
0x0f 0 0 1 2 3 4 5 6 7 8 r:2
- Read scratchpad (command 0xAA)
0xaa r:3 r:8 r:2
- Read auth page (command 0xA5), which is the secure read command
0xa5 0 0 r:32 r r:2 &:1500 r:20 r:2
Example response:
1-WIRE>0xa5 0 0 r:32 r r:2 &:1500 r:20 r:2 WRITE: 0xA5 WRITE: 0x00 WRITE: 0x00 READ 0x20 BYTES: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 READ: 0xFF READ 0x02 BYTES: 0x6D 0x0D DELAY 0xDCuS READ 0x14 BYTES: 0x45 0x31 0x40 0x42 0xAE 0xD3 0x4B 0xC5 0x18 0xCC 0x10 0x43 0x27 0x56 0x33 0xD0 0xEB 0x47 0xA7 0x81 READ 0x02 BYTES: 0xAA 0x6D
DS1961 library
This library provides an API for the DS1961 specific functions. It will be targeted at the Arduino microcontroller, to run on top of the existing 1-wire library.
Application
We could apply this to improve the security of RevSpace access for example. to be discussed.
Stuff to be considered for access control:
- an extra initialisation step to install the secret before use is needed
- how can we handle the transition of the current iButton system to a more secure system?
- how advanced do we make the authentication scheme / how is key management handled?
- Simplest: one secret for all revspace iButtons. Disadvantage: cracking one iButton means that *all* revspace iButtons are cracked.
- More advanced: different secret for each revspace iButton (e.g. calculated from a master secret and the iButton serial number)
- More advanced: master secret is re-newed every X time, so we have multiple versions of the master secret (e.g. renewed each year)
