Designing the RhoCoCo Retro Home COlor COmputer hardware
Project RhoCoCo Retro HOme COlor COmputer
A brand new 8-bit homecomputer with modern parts. Above picture is an artist impression, it is how it will look mounted on a plank of wood measuring 18cm wide and 20 cm deep, an expansion can be connected to the main board in the top left corner, if needed. Conceptually it resembles my earlier ZX81 clone https://revspace.nl/ZX81PLUS34_ZX81_clone but when finished it will be a capable Z80 based 128K full color home computer, able to drive a VGA monitor in high resolution, and with 64 colors, it has sound, (BBC) BASIC and an SD-card for storage.
Contact Mahjongg
Last Update 2018-09-04
Less is more, less complexity, more fun is the driving force behind the Rhococo Retro Home Color Computer. It will be a remake home-computer inspired on, but not compatible with, the Sinclair spectrum, Initially I considered not basing it on a Z80, but on an ARM7TDMI based simple micro-controller, (probably an STR710FZ2) running at 66MHz with 256 + 16 KB internal fast Flash and with 64K internal fast RAM and a separate external 32K VRAM. But early 2017 I changed my mind, because I wanted the ability to port software from Z80 based homecomputers.
The idea behind it is bringing back a new homecomputer as it was popular in the 80's, but build with modern components, and using modern interfaces (VGA monitor instead of TV, SD-card storage devices instead of cassette recorders).
I want it to be capable of a 320x200 VGA full high resolution graphics 16 color display (i.e. with Mode "D" timings, 70Hz, Horizontal Sync = 31.778 KHz, pixel clock 25.175 MHz).
To be able to keep the design simple, but still able to be drive a VGA monitor, I chose to support only the lowest VGA resolution of 320 x 200 with 16 colors. It means we only need to have, (and manipulate) a 256000 bit (32K) frame buffer. Three bytes will be shifted to the Red, Green an Blue color inputs, and one to the intensity input, giving sixteen colours per pixel. Preferably the "glue logic" for it will consist of standard logic, but if necessary I will consider a small FPGA.
the Rhococo will support a simple SD-Card interface as storage, and will use a keyboard similar to the ZX81+34, but with more keys,and a more conventional keyboard imprint.
After a year or so contemplating this idea of a new homecomputer, I came to the conclusion that an ARM based system with software VGA generation might be too complex for a the simple system I have in mind. I will make a NEW homecomputer design with components that can be bought in 2017 (and hopefully the next few decades). It will be based on a Z80 compatible CPU as it is one of the few 8-bit CPU's that is still relatively easy to get, and it was so popular in the 80's that there is a plethora of software available for them. One thing I don't want is to use an FPGA for it, as these are still relatively expensive and difficult to program for. This does cause a problem, as most old homecomputers either used some kind of programmable logic (Sinclairs ULA logic) or were based around a CRTC like the MC6845, which are no longer available, or they used a VDC (video display controller) like the TMS9918 (MSX an many others) which are also no longer available. My preference would have been using a CRTC, but as I said I can find no CRTC's for sale anymore, I could build one with standard logic (like the TRS-80 did) but that's too RETRO even for me, (uses far too much components). Instead I'm wondering if I can replace the CRTC with an simple AT-mega (Arduino) microcomputer. For a 320 x 200 display you would need 320 / 8 = 40 8-pixel wide rows and 200 lines, which means you need 40 * 200 = 8000 address locations, this is about 8191 or 2 ^ 13, meaning you need 13 address lines to address these 8191 (or hex 0x1FFF) locations. and a couple of other signals like HSYNC and VSYNC and video clock. An Arduino (nano) uses an ATmega328, and doesn't really have that many GPO (output) ports, but that can be solved with a few 8-bit latches. I'm planning to do this in little steps, so first I'm planning to connect 8K Byte SRAM (or an EPROM for testing) to an Arduino nano, plus a shift register to clock out a video stream, to try to generate a 320 x 200 (monochrome) VGA signal, using a Arduino nano as a CRTC surrogate. Then continue from there.
then, nothing.... :-( so the z80 uBIOS doesn't run, probably some wiring error still. Although it seems to finish running the first and second boot parts, with help from the Z80 for the second part. Next time debugging, and probably building it up on perfboard for better reliability and the possibility to remove the main chips from sockets, or even to add a programmer interface, for easier programming, although the ability to just take the ATMEGA32 out of its socket will also help a lot, as taking it out of the breadboard is now a pain, with all the Dupont wires crisscrossing over it. Here is a picture of it on breadboard.
Colors of wires are:
Thick Red, +5V
Red, Databus
Yellow, lower 8 address lines
Green, Higher 8 address lines
Blue, control signals
Fill in a very small section of boot code (256 bytes) to the first page of RAM
React to I/O reads and writes (while halting the Z80)
read out a somewhat larger part (10K or so) of RAM somewhere else in memory (read out the video frame buffer) efficiently (quickly) while not disturbing, or by halting the Z80.
it works like this:
   Pull Z80 reset line low.
   Generate enough clock pulse to allow Z80 core to fully reset then set reset line high.
   Set the tri-state buffer enable pin high to tri-state Z80 read and write lines (/RD, /WT).
   Provide clock pulses to the Z80 until the Z80 indicates a read operation.
   Place the desire data on to the data buss, then pulse the RAM /WT pin low to write the memory location, Z80 provides address and RAM chip select.
   Place the 8 bit Z80 op-code NOP (0) on the data buss.
   Provide clock pulses to the Z80 until the Z80 indicates the read operation completed (/RD = high).
   Repeat steps 4..7 until the required boot code is copied to RAM, each cycle the Z80 will increment its memory address starting at address zero.
   Set the tri-state buffer enable pin low to enable Z80 read and write lines (/RD, /WT).
   Set the Propeller chip counter to clock the CPU at required frequency.
When a port read or port write operation is requested by the Z80 the Propeller chip stops the Z80 master clock.
The 74HC165 parallel to serial register is used to read the 8 bit port address from the Z80 address bus.
If the Z80 requests a port write operation the 8 bit data value is read directly by the Propeller chip from the Z80 data buss.
The Propeller chip uses the supplied port address and executes the required code to complete the request.
If the Z80 performed a port read operation the resultant data is placed on the Z80 data bus and and the Z80 is clocked until the /RD line is set high by the Z80.
If the Z80 performed a port write operation the Z80 is clocked until the /WT line is set high by the Z80.
Finally the Propeller chip starts the Z80 master clock and goes back to waiting for an I/O port operation.
Adding a keyboard
Adding sound
I updated the two .PDF's, (ie: RHOCOCO MAIN PROP.pdf and : RHOCOCO Z80CPU with RAM.pdf ) and the above schematics. Refresh the page if you don't see a VGA connector on the main sheet. The new main sheet now has VGA and sound (PWM) output and an EEPROM, the two address latches were removed as they are no longer needed (because we will use the NMI triggered memory to IOWR copy routines.) The Z80 + RAM (and now keyboard) sheet has also been revised. The simple boot method is supported, and address lines A0 to A7 are latched on any IO request, and can be read-out by the Propeller to distinguish between various IO request types. The same keyboard matrix system is used as a spectrum, (drawn on a new sub-sub-sheet) and an IO-READ to a keyboard read location can be captured, and the keyboard-scan data can then be pushed onto the Z80 data-bus to finish the IO-READ instruction.
About the keyboard
a screenshot of KiCad's layout editor during placement of the various components on a 10 x 10cm board, the ratsnest is temporarily turned off. Screenshot 2018-08-01 02-59-00.png
so now we have a valid ratsnest (the spiderweb of white lines) showing all the connections we have to create using the two copper layers of our dual sided PCB. As you can see its a bit of a downing task. I think the first order of business is to try if we can simplify the job somehow by swapping address lines and data lines to the SRAM chip, because it really doesn't matter if any of the datalines (or address lines) is connected to a specific data (or address line), so we can swap lines to simplify routing. This means that the schematics could change because of this.
The main page of the schematic has changed, as connections between SD-card holder, and I/O expander chip have swapped to make the layout possible. the new schematic is revision 1.3; File:RHOCOCO PROP rev1.3.pdf the above picture is updated. This is how far we are now: Schermafdruk van 2018-08-04 02-03-05.png
I completed the layout, the next picture shows an overview of the finished PCB, followed by the top and bottom copper layers. RhoCoCo van 2018-08-29 00-54-18.png
September 3, 2018 Checked keyboard wiring, found errors
Looking at the keyboard schematic, [1] I noticed the address lines are not in a logical order, while the keyboard connector address lines are, I have to correct that, and should also double check for other errors. My ZX81 clone keyboard worked fine, so I can use that as a starting point. After careful checking I concluded that the numbering and connector orientation of the keyboard schematic is correct, so from left to right the order of the connector pins is: KD0, KD1, KD2, KD3, KD4, (KD5) ---- KA11, KA10, KA12, KA9, KA13, KA8, KA14, and KA15, I have triple checked it with data from a real ZX81 to be sure.
This was a big job, had to create a footprint for the Molex SD-67600-006 sd-connector, instead of the version in the KiCad library which did not conform to the sd memory card connector that you can really buy. The keyboard connector is now female, and has correct rotation, with pin 1 on the left side. address and data ordering is now correct (hopefully) The schematic has also been updated, and is now revision 1.4. This is the updated schematic File:RhoCoCo rev1,4.pdf. here is a picture of the new layout: RhoCoCo rev 1,4.png RhoCoCo rev 1,4 top layer.png
