ZX81PLUS35 ZX81 clone
(Doorverwezen vanaf ZX81PLUS34 ZX81 clone)
Project ZX81+35 ZX81 clone
My clone of the Sinclair ZX81
Contact Mahjongg
Last Update 2022-04-05
Introduction to the ZX81+35
  • wilf rigters "turbo.pdf"
  • wilf rigters "ZX81WAIt.pdf"
  • Other ZX80 /ZX81 info:
  • "Microace_Diagram_s1.jpg"
  • "ZX81CCP_schematic.jpg"
  • "tk82 (ZX81 clone) schemas"
3D Preview of early ZX81+34
Schematic 81+34
Layout ZX81+34
Keyboard for ZX81+34/35
The final ZX81+34
Starting the assembly
Finished assembly
Testing (continued)
ZX81+34 version TWO
3D preview version 2
Version 2.1
Version 2.2 (ZX81+35)
29 DECEMBER 2015
30 December 2015
5 January 2016
10 January 2016
23 January 2016
31 January 2016
2 February 2016
new layout for rev 2.3:
new schematic for rev 2.3:
21 February 2016
Here's the snapshot.
28 February 2016 It's alive!
2017 has arrived
it now includes:
to come (I'm working on it):
  • Keyboard PCB layout
10 FOR X = 0 TO 255
20 PRINT CHR$ X;
30 NEXT X
Bestand:ZX81+35 REV 4.2. schematic color.pdf
Bestand:ZX81+35 REV 4.2 layout preview.PDF
