Designing the RhoCoCo Retro Home COlor COmputer hardware
Project Rhococo Retro HOme COlor COmputer | |
A brand new 8-bit homecomputer with modern parts. Above picture is an artist impression, it is how it will look mounted on a plank of wood measuring 18cm wide and 20 cm deep, an expansion can be connected to the main board in the top left corner, if needed. Conceptually it resembles my earlier ZX81 clone https://revspace.nl/ZX81PLUS34_ZX81_clone but when finished it will be a capable Z80 based 128K full color home computer, able to drive a VGA monitor in high resolution, and with 64 colors, it has sound, (BBC) BASIC and an SD-card for storage. | |
Contact | Mahjongg |
Last Update | 2018-08-31 |
Less is more, less complexity, more fun is the driving force behind the Rhococo Retro Home Color Computer. It will be a remake home-computer inspired on, but not compatible with, the Sinclair spectrum, Initially I considered not basing it on a Z80, but on an ARM7TDMI based simple micro-controller, (probably an STR710FZ2) running at 66MHz with 256 + 16 KB internal fast Flash and with 64K internal fast RAM and a separate external 32K VRAM. But early 2017 I changed my mind, because I wanted the ability to port software from Z80 based homecomputers.
The idea behind it is bringing back a new homecomputer as it was popular in the 80's, but build with modern components, and using modern interfaces (VGA monitor instead of TV, SD-card storage devices instead of cassette recorders).
It will be capable of 320x200 VGA full high resolution graphics 16 color display (Mode "D" timings, 70Hz, Horizontal Sync = 31.778 KHz, pixel clock 25.175 MHz). Or perhaps PAL color, I'm not sure yet.
To be able to keep the design simple, but still able to be drive a VGA monitor, I chose to support only the lowest VGA resolution of 320 x 200 with 16 colors. It means we only need to have, (and manipulate) a 256000 bit (32K) frame buffer. Three bytes will be shifted to the Red, Green an Blue color inputs, and one to the intensity input, giving sixteen colours per pixel. Preferably the "glue logic" for it will consist of standard logic, but if necessary I will consider a small FPGA.
After a year or so contemplating this idea of a new homecomputer, I came to the conclusion that an ARM based system with software VGA generation might be too complex for a the simple system I have in mind. I will make a NEW homecomputer design with components that can be bought in 2017 (and the next few decades). It will be based on a Z80 compatible CPU as it is one of the few 8-bit CPU's that is still relatively easy to get, and it was so popular in the 80's that there is a plethora of software available for them. One thing I don't want is to use an FPGA for it, as these are still relatively expensive and difficult to program for. This does cause a problem, as most old homecomputers either used some kind of programmable logic (Sinclairs ULA logic) or were based around a CRTC like the MC6845, which are no longer available, or they used a VDC (video display controller) like the TMS9918 (MSX an many others) which are also no longer available. My preference would have been using a CRTC, but as I said I can find no CRTC's for sale anymore, I could build one with standard logic (like the TRS-80 did) but that's too RETRO even for me, (uses far too much components). Instead I'm wondering if I can replace the CRTC with an simple AT-mega (Arduino) microcomputer. For a 320 x 200 display you would need 320 / 8 = 40 8-pixel wide rows and 200 lines, which means you need 40 * 200 = 8000 address locations, this is about 8191 or 2 ^ 13, meaning you need 13 address lines to address these 8191 (or hex 0x1FFF) locations. and a couple of other signals like HSYNC and VSYNC and video clock. An Arduino (nano) uses an ATmega328, and doesn't really have that many GPO (output) ports, but that can be solved with a few 8-bit latches. I'm planning to do this in little steps, so first I'm planning to connect 8K Byte SRAM (or an EPROM for testing) to an Arduino nano, plus a shift register to clock out a video stream, to try to generate a 320 x 200 (monochrome) VGA signal, using a Arduino nano as a CRTC surrogate. Then continue from there.
Colors of wires are:
Thick Red, +5V
Red, Databus
Yellow, lower 8 address lines
Green, Higher 8 address lines
Blue, control signals
it works like this:
Adding a keyboard
Adding sound
About the keyboard
so now we have a valid ratsnest (the spiderweb of white lines) showing all the connections we have to create using the two copper layers of our dual sided PCB. As you can see its a bit of a downing task. I think the first order of business is to try if we can simplify the job somehow by swapping address lines and data lines to the SRAM chip, because it really doesn't matter if any of the datalines (or address lines) is connected to a specific data (or address line), so we can swap lines to simplify routing. This means that the schematics could change because of this.
The main page of the schematic has changed, as connections between SD-card holder, and I/O expander chip have swapped to make the layout possible.
the new schematic is revision 1.3; File:RHOCOCO PROP rev1.3.pdf the above picture is updated.
This is how far we are now:
