ZX81plus38 simple to build ZX-81 clone
Project ZX81plus38
Contact mahjongg
Last Update 2023-03-23
P.S. No I won't!
October 1, 2019 continued
px800
January 28, 2020
February 12, 2020
February 19, 2020
February 26, 2020
March 4, 2020 layout finished
and this is the bottom layer:
and bottom view
March 16, RefSpace is closed!
The jumpers are:
and bottom:
my GitHub page is here: [2]
I managed to work from home
Now the clone should work.
and bottom:
and this is the bottom side:
here is the drawing:
  • An original ZX-81 ROM
I managed to get Windows 7 booting again on my laptop, but its quite a convoluted progress. I have a multi boot menu from my Linux Mint install, but when I chose windows 7 from the boot menu windows claimed "something has changed and I can't boot, please use a windows 7 install disk to fix the error" which I tried, but windows claimed not to be able to use my install disk, so I was stuck! And I still wanted to use the TL866 II plus programmer with windows (under linux there is only a command line driver, which makes using it impossible for me, don't get why there is no GUI for it!). But I found a way to start windows 7, the trick is to press enter to interrupt the standard boot up process of my laptop, then I could press F11 to start in Recovery mode, which again started the same ""something has changed and I can't boot" message but this time when I press ESC in that screen windows boots! So I booted windows, found new software for the (greatly enhanced TL866 II plus) programmer from a chinese site (if you choose the "download from local second download option it downloads an installer packed as an RAR file, so I also had to install WINRAR, and I installed some kind of HEX editor for good measure. So the programmer software was unRARed an installed which went smoothly, and I had working programming software. With that I found out that one of my two 74HC14 IC's was defective (use the 7414 options to test) that was due to me being stupid (foggy in the head) and placing it in it's socket the wrong way around, and no 74HC14 do not tolerate being fed negative 5Volt! but the other 74HC14 was fine. I have thought about why the 13MHz crystal oscillator did not work last time, even with the "good chip", and came to one of a few theories, the first is that the 2M2 feedback resistor was too large (in value), so I replaced it with a 1 Meg resistor, the second problem I could force is that a HC14 hex inverter might not like having its other five inputs floating, so I temporary fixed it so the other 5 inputs were either tied to +5V or another inverter output. next week I will test the oscillator with an oscilloscope, hopefully it will start working. I also was give three 27C512 EPROM's which the programmer said were not empty, but the donor of the chips found out these can actually be reprogrammed! they are in fact EEPROM's, not OTP's. also I was given a 28C256 by a generous german builder of my ZX81+38 (who also donated many chips and a revision 1.6 PCB). I found with the programmer this chip was filed with four copies of the ZX-81 ROM! so I had the code which I could download to my laptop from the EEPROM, and program twice in the 27C512, so it has eight 8K copies, which should work with my Revision 1.6 PCB without any modifications needed. also my 32K RAM chip tested good with the programmer. So now I have three 27C512 EEPROMs with ZX-81 code, and a 28C256, but that one needs patching the board so I probably will not need it, but as a source for ZX-81 BASIC ROM it was great.
and updated placement file
And as .PNG picture:
July 19, That wasn't it
  • U15, 74HC11
  • U11, U24, 74HC08
  • U27, 74HC138
  • U12, U16,U19 74HC32
  • U6, 74HC125
I ordered:
  • 2 x 74HC08
  • 1 x 74HC11
  • 3 x 74HC32
  • 1 x 74HC125
  • 1 X 74HC138
File:ZX81plus38rev1,9.pdf
and the PCB preview (top):
File:ZX-81Keyboard color.pdf ZX-81Keyboard color.png
here is a preview of the PCB:
Tuesday 27, December 2022
[[[File:Keyboard fits on ZX-81 seen from front cropped.jpg|1000px]]
