Designing the RhoCoCo Retro Home COlor COmputer hardware
Revision as of 23:07, 2 April 2019 by Mahjongg (talk | contribs)
Project RhoCoCo Retro HOme COlor COmputer
A brand new 8-bit homecomputer with modern parts. Above picture is an artist impression, showing how it could look, mounted on a plank of wood measuring 20cm wide and 22 cm deep. An expansion board can be connected to the main board in the top left corner. Conceptually it resembles my earlier ZX81 clone but when finished it will be a capable Z80 based 128K full color home computer, able to drive a VGA monitor in high resolution, and with 64 colors, it has sound, and will have (BBC) BASIC and an SD-card for storage.
Contact Mahjongg
Last Update 2019-04-02
This describes my desire, and the result of that desire, to build an 80's Home Computer in this decade (in the year 2017, 2018 and 2019). This first page describes what it took to design the hardware for RhoCoCo, planned future page will describe the design of an enclosure, and the firmware.
My long time desire was to remake a home-computer inspired on, but not compatible with, the Sinclair spectrum and/or Amstrad CPC, Initially I considered not basing it on a Z80, but on an ARM7TDMI based simple micro-controller, (probably an STR710FZ2) running at 66MHz with 256 + 16 KB internal fast Flash and with 64K internal fast RAM and a separate external 32K VRAM. But early 2017 I changed my mind, because I wanted the ability to port software from various Z80 based homecomputers, of which there were many (many more than those using other processors, like the 6502, 6809, or 1802, to name a few). see how many there were: [1]
The idea behind it is to bringing back a new home computer, such as they were popular in the 80's, but build with modern components, and using modern interfaces (VGA monitor instead of TV, SD-card storage devices instead of cassette recorders).
the Rhococo will support a simple SD-Card interface as storage, and will use a keyboard similar to my previous ZX81+34 design, but with more, and real, keys,and a more conventional keyboard imprint. This also means that rhococo will be just a bit larger than the Z81, so very small (and thus hopefully also very cheap). as a comparison think about the French "Alice" computer, or the small tandy MC-10. But much more capable than these two.
For sound I consider a PWM output. Or an emulated PSG (programmable sound generator). with at least similar capabilities to these used in the Amstrad CPC, spectrum + and MSX computers, but hopefully with capabilities not unlike a C64 SID chip.
It will be a "turn on and use" system, meaning that the "OS", and a programming language will permanently reside in ROM, ready the moment you turn the Rhococo on (Meaning it will be based on some kind of interpretative language), probably BASIC (if possible BBC BASIC).
It will not be yet another Linux based system, as I want something that can be completely understood, just like you could learn how any of the 80's homecomputers worked. It is deliberately a simple and limited system.
You can comment on it on the topic I started about it on the Raspberry PI forum, here: https://www.raspberrypi.org/forums/viewtopic.php?f=62&t=226889
After a year or so contemplating this idea of a new homecomputer, I came to the conclusion that an ARM based system with software VGA generation might be too complex for a the simple system I have in mind. I will make a NEW homecomputer design with components that can be bought in 2017 (and hopefully the next few decades). It will be based on a Z80 compatible CPU as it is one of the few 8-bit CPU's that is still relatively easy to get, and it was so popular in the 80's that there is a plethora of software available for them. One thing I don't want is to use an FPGA for it, as these are still relatively expensive and difficult to program for. This does cause a problem, as most old homecomputers either used some kind of programmable logic (Sinclairs ULA logic) or were based around a CRTC like the MC6845, which are no longer available, or they used a VDC (video display controller) like the TMS9918 (MSX an many others) which are also no longer available. My preference would have been using a CRTC, but as I said I can find no CRTC's for sale anymore, I could build one with standard logic (like the TRS-80 did) but that's too RETRO even for me, (uses far too many components). Instead I'm wondering if I can replace the CRTC with an simple AT-mega (Arduino) microcomputer. For a 320 x 200 display you would need 320 / 8 = 40 8-pixel wide rows and 200 lines, which means you need 40 * 200 = 8000 address locations, this is about 8191 or 2 ^ 13, meaning you need 13 address lines to address these 8191 (or hex 0x1FFF) locations. and a couple of other signals like HSYNC and VSYNC and video clock. An Arduino (nano) uses an ATmega328, and doesn't really have that many GPO (output) ports, but that can be solved with a few 8-bit latches. I'm planning to do this in little steps, so first I'm planning to connect 8K Byte SRAM (or an EPROM for testing) to an Arduino nano, plus a shift register to clock out a video stream, to try to generate a 320 x 200 (monochrome) VGA signal, using a Arduino nano as a CRTC surrogate. Then continue from there.
then, nothing.... :-( so the z80 uBIOS doesn't run, probably some wiring error still. Although it seems to finish running the first and second boot parts, with help from the Z80 for the second part. Next time debugging, and probably building it up on perfboard for better reliability and the possibility to remove the main chips from sockets, or even to add a programmer interface, for easier programming, although the ability to just take the ATMEGA32 out of its socket will also help a lot, as taking it out of the breadboard is now a pain, with all the Dupont wires crisscrossing over it. Here is a picture of it on breadboard.
Colors of wires are:
Thick Red, +5V
Red, Databus
Yellow, lower 8 address lines
Green, Higher 8 address lines
Blue, control signals
Fill in a very small section of boot code (256 bytes) to the first page of RAM
React to I/O reads and writes (while halting the Z80)
read out a somewhat larger part (10K or so) of RAM somewhere else in memory (read out the video frame buffer) efficiently (quickly) while not disturbing, or by halting the Z80.
it works like this:
   Pull Z80 reset line low.
   Generate enough clock pulse to allow Z80 core to fully reset then set reset line high.
   Set the tri-state buffer enable pin high to tri-state Z80 read and write lines (/RD, /WT).
   Provide clock pulses to the Z80 until the Z80 indicates a read operation.
   Place the desire data on to the data buss, then pulse the RAM /WT pin low to write the memory location, Z80 provides address and RAM chip select.
   Place the 8 bit Z80 op-code NOP (0) on the data buss.
   Provide clock pulses to the Z80 until the Z80 indicates the read operation completed (/RD = high).
   Repeat steps 4..7 until the required boot code is copied to RAM, each cycle the Z80 will increment its memory address starting at address zero.
   Set the tri-state buffer enable pin low to enable Z80 read and write lines (/RD, /WT).
   Set the Propeller chip counter to clock the CPU at required frequency.
catching I/O requests (simple CP/M system style)
When a port read or port write operation is requested by the Z80 the Propeller chip stops the Z80 master clock.
The 74HC165 parallel to serial register is used to read the 8 bit port address from the Z80 address bus.
If the Z80 requests a port write operation the 8 bit data value is read directly by the Propeller chip from the Z80 data buss.
The Propeller chip uses the supplied port address and executes the required code to complete the request.
If the Z80 performed a port read operation the resultant data is placed on the Z80 data bus and and the Z80 is clocked until the /RD line is set high by the Z80.
If the Z80 performed a port write operation the Z80 is clocked until the /WT line is set high by the Z80.
Finally the Propeller chip starts the Z80 master clock and goes back to waiting for an I/O port operation.
My method for catching I/O requests, and reading the keyboard
In the Rhococo doing an I/O request will automatically latch in the first (lower) eight address lines into a latch, which can be later read out in parallel by temporarily tri-stating the Z80. Otherwise the same method will be used to halt the Z80 clock when the propeller detects an I/O request, then read out the latch to see which of the 256 possible I/O requests it is, then detection whether its an I/O write or I/O read, and handling it. Reading the keyboard implies that an I/O read is done, from a specific I/O location (I will choose $FF), with an I/O instruction that puts the high address byte on A8 to A15. Depending on the content of A8 to A15 being either 0 (to quickly scan if any key at all is pressed), or a pattern where one bit is low and the rest high, the keyboard (or joystick) pulls one or more of the six column lines low, and a subsequent low on the keyboard read line (initiated by the propeller who sees we want to to a keyboard read) data is put on the databus, to be read by the Z80. So an I/O read of (16 bit address) $xxFF, (where xx drives the keyboard rows) will read relevant keyboard data.
Adding a keyboard
Adding sound
I updated the two .PDF's, (ie: RHOCOCO MAIN PROP.pdf and : RHOCOCO Z80CPU with RAM.pdf ) and the above schematics. Refresh the page if you don't see a VGA connector on the main sheet. The new main sheet now has VGA and sound (PWM) output and an EEPROM, the two address latches were removed as they are no longer needed (because we will use the NMI triggered memory to IOWR copy routines.) The Z80 + RAM (and now keyboard) sheet has also been revised. The simple boot method is supported, and address lines A0 to A7 are latched on any IO request, and can be read-out by the Propeller to distinguish between various IO request types. The same keyboard matrix system is used as a spectrum, (drawn on a new sub-sub-sheet) and an IO-READ to a keyboard read location can be captured, and the keyboard-scan data can then be pushed onto the Z80 data-bus to finish the IO-READ instruction.
About the keyboard
Full schematics as pictures
The pictures below are/will be always fully updated to the latest version (now rev 1,8 of December 9, 2018). Sheet 1 of 3: is the Main sheet. P1 to P7 of the propeller are used for the VGA output signals. So the propeller chip is capable of producing 64 colors per pixel, 8 times as many as a spectrum. Audio output is supported, as well as an SD-card (through the use of an I2C I/O expander).
If you want to see older versions, click on the picture an you will go to a page with intermediate versions.
Sheet 2 of 3: The Z80 (running at 5V) with its 128K/256K (eight or 16 banks of 16) RAM, and a latch that can capture the lower 8-address-lines during an I/O (write or read) operation, during the I/O operation the propeller can read out the data, and then the 8 address lines for an I/O write, or can read out the addresses, then put 8-bit data on the Z80 data bus for an I/O read operation. To the top right is the Rhococo specific expansion port.
The keyboard itself is on a larger single sided PCB, connected with angled headers to the main PCB. this is the latest version of the schematic, the "deluxe" version for rev 1,8.
and this is the bottom:
Supported screen resolutions:
     320x240 Pixels, 40x30 Chars, 4:3 Ratio,  9600 Byte Buffer.
     160x120 Pixels, 20x15 Chars, 4:3 Ratio,  2400 Byte Buffer.
     384x240 Pixels, 48x30 Chars, 8:5 Ratio, 11520 Byte Buffer.
     192x120 Pixels, 24x15 Chars, 8:5 Ratio,  2880 Byte Buffer.
     320x240 Pixels, 40x30 Chars, 4:3 Ratio, 19200 Byte Buffer.
     160x120 Pixels, 20x15 Chars, 4:3 Ratio,  4800 Byte Buffer.
     384x240 Pixels, 48x30 Chars, 8:5 Ratio, 23040 Byte Buffer.
     192x120 Pixels, 24x15 Chars, 8:5 Ratio,  5760 Byte Buffer.
November 13, 2018 I got a great idea, replace the Z80 with a -second- Propeller chip !!!
On the raspberry PI forum, where I have a thread about RhoCoCo a member called "Hippy" hinted that I could solve the bank switching problem by using a 74LS670 4 x 4 bit register file. This is just a small 16-pin DIP IC, that contains all the logic that is needed. I have not yet tried to figure out completely how to integrate it in the rhococo, but it seems possible, so my first thought was, "can I fit it in", is there physical space for it left on the PCB, so I returned back to my Altium 3D preview mockup, to see if I theoretically could find room for it, and I did (which doesn't mean layouting it is possible). This is a preview of the 3D rendering of Rhococo with an added 74LS670 (U10) Revision 1.7.
Note that Z80-A14 and Z80-A15 are used to select one of the four bits that contain the settings for RAM-A14 RAM-A15 and RAM-A16. The bits are programmed using Z80-D0 .. Z80-D5, two databits are used to select one of the four bits, and three what the bits should contain. To program them the Z80 is halted, and tri-stated, so that the propeller can drive the data-bus, (ViH of the 74LS670 is 2.0V, so logic level compatible with the 3V3 levels of the propeller). This programming can be done before the Z80 is started, so that the bits can be set so that the four 16K blocks appear in their logical order, from the first 64K bank of the RAM. After this is done the propeller can then initialize the RAM with BOOT and BASIC code. In a more conventional system the lack of a reset input on the 74LS670 would have been a major problem, for in the addition of extra hardware to circumvent the 74LS670 before code could boot.
I think the layout work will take at least a few Tuesday evenings, and Saturdays, hopefully I can make it fit.
P.S. the LS version might have a problem with the series resistors in the databus, the best solution would be to use the data signals directly from the propeller. or use a HCT version instead, but these are hard to get (in DIP form).
November 28, 2018 Started with new rev 1,7 schematic, and layout, with 74LS670 memory mapper
Cleaned up schematic, and added 74LS670 memory mapper, initially for 128K RAM (eight 16K pages) later (if I succeed with the layout) I will try to fit traces for 256K support. here is the new schematic (rev 1,7):
File:RHOCOCO rev 1,7.pdf
I think I did 80% of the layout work.
The white lines are connections I have yet to do. As you can see I temporarily removed the copper fills. Updated the 3D picture above, and the impression picture, and tweaked the placement of parts in an attempt to fit all the connections in, especially made more room between the 74LS670, and the IO-Expander chip, as I expect to need to fit more traces there. As I'm gaining more confidence it will fit I have updated the main 3D impression picture on the top of this page too.
December 2 Various layout jobs
Updated the schematic to rev 1.8, with support for large ROM's on the expansion port. And done more remaining layout work (as shown in the updated picture above). I updated the keyboard layout too, as I moved the left keyboard pin-header connector a tiny bit, and so the keyboard had to be corrected too, and I have put "74LS670" on the silk screen. I have also routed the RAM-A14, RAM-A15 and RAM-A16 lines to the expansion port, instead of the Z-80 A14 and A15, so that an (up-to) 128 K RAM/ROM on the expansion port can disable (part off) the RAM and take its address space, or possibly expand it.
December 5, 2018 Finished 100% routing
PCB is fully routed, so I did it! Amazingly it fits, although at the end stage I started worrying if it could, without switching to a higher density layout (with 0.15mm wires instead of 0.25mm, so I could route two lines between two pins with a pitch of 1/10". That would have made the PCB less easy to produce, so probably much more expensive. This result still needs some cleanup work, and optimizations (especially of the ground plane copper fill) but I now know that it is layout technical possible to integrate the 74LS670! Here is the picture of the 100% laid out board, still revision 1,7 (will update to revision 1.8 after cleanup, optimization and final checks).
I realized that if I manage to route a wire from pin-1 of the RAM chip to the unused output pin of the 74LS670, and add another data-line from the propeller data port to the 74LS670, it would be possible to use the memory mapper to address 256K of RAM (not eight, but sixteen 16K pages). It would be a missed chance if I did not try to add this option too, even if I will not initially use 256K RAM's (they are harder to find, as the 512K versions are more common). an initial observation of the current layout does not immediately disqualify the possibility that adding these connections is possible. P.S. After looking at the layout I wondered why pin 3 of the LS670 wasn't connected to GND, so I looked at the schematic, and realized that the data-line is already routed to the propeller, so all I need to do is to add the wire to pin-1 of the RAM chip.
December 9, 2018. Finished rev1,8 with 256K memory mapper
The new schematic is here: File:RHOCOCO rev 1,8 schematic.pdf
The picture of the finalized, Design rule checked, and optimized (especially the groundplane/copperfill) is this:
I made gerber/drill production files, and will test upload them ASAP. If all is well, I will order some PCB's for the main dual-sided 10x10cm PCB, and the keyboard PCB.
I have updated the schematic pictures of "Full schematics as pictures" halfway this page.
I will describe the ordering process in another project page.
December 10, 2018 final checked PCB layouts
Layouts are okay, the PCB's will look like this:
and finally the full 3D rendered preview of rev 1.8:
And yes, its really very compact, the "main PCB" measures just 10 x 10 cm, and so the whole thing is just a little bigger than a ZX81, about the size of a Matra Alice, or Tandy MC-10, but which much better specs.
December 10, 2018 made preview of the Rhococo in an enclosure
Just for fun, and so you can see how big it will be, I rendered a picture of Rhococo in a half transparent red plastic enclosure, (in the style of the French Matra Alice home-computer [4] ). For size comparison I added a match. This picture I used for the "designing an enclosure for RhoCoCo" wiki page. [5]
December 18, 2018 modified keyboard PCB
I have done some last minute tweaks on the keyboard PCB. I removed 8mm square areas from the front PCB corners so that the keyboard can be mounted inside of an enclosure with screw positions in the corners of the enclosure. The cutouts make space for plastic structures for the screws.
I have also enlarged the pads for the 6-wire and 8-wire connectors. I now plan to solder flexible cables to the keyboard, and expect somewhat larger mechanical forces on the connector pads of J1 and J2, so I gave these solder-pads a bit more "flesh" so the adhesion of the copper pads to the PCB has become a lot stronger.
January 29, 2019 Ordering the PCB's
I ordered the PCB's with the Chinese PCB manufacturer PCBWay. I made a separate project page about it.
March 7, 2019 PCB's are in
They look good. Next step creating a complete Bill of materials.
March 20, 2019 Finished Bill of materials
The price for parts, for the first prototype (without PCB's, or enclosure) comes to around €71, for main-PCB, and €32 for the keyboard. So around €103 for a single prototype board (without PCB's)
The integrated circuits alone are not the most expensive, around €20, and the connectors alone cost €33.
Obviously The price can go down substantially when you order multiple sets of parts, and for the cheaper parts the minimum order quantity is often larger than you need for one prototype.
Ordering parts for a second and third set would not have a great influence on the price, as often you need to buy at least five of something for the price to go down, so initially I will only order parts for one prototype. Ordering a second and third (or more) sets later won't mean I loose much money.
A .PDF version of the BOM can be found here: File:RHOCOCO rev 1.8 BOM.pdf
March 27, 2019 Ordered all components
The stuff that came from a special vendor (RS and Mouser) were ordered for all 5 prototypes, and I ordered three 20MHz Z80's and two 10MHz ones to experiment how fast I could clock the Z80. The rest was ordered from Farnell, simple to order stuff in unity, some for 3 or 5 boards. Expect to have it all before the end of the week. Will start a new page about building up RhoCoCo. This ends "designing the RhoCoCo Retro Home COlor COmputer hardware" page, at least for this hardware revision (rev 1.8).
March 28, 2019 Parts are in!
Parts I ordered from Farnell, and RS are in, Mouser parts come later today or tomorrow.
This weekend, during the open day of Revspace, I will start building up the first prototype.
