Designing the RhoCoCo Retro Home COlor COmputer hardware
A brand new 8-bit homecomputer with modern parts. Above picture is an artist impression, showing how it could look, mounted on a plank of wood measuring 20cm wide and 22 cm deep. An expansion board can be connected to the main board in the top left corner. Conceptually it resembles my earlier ZX81 clone but when finished it will be a capable Z80 based 128K full color home computer, able to drive a VGA monitor in high resolution, and with 64 colors, it has sound, (BBC) BASIC and an SD-card for storage. | |
Contact | Mahjongg |
Last Update | 2018-11-13 |
It should become a remake home-computer inspired on, but not compatible with, the Sinclair spectrum and/or Amstrad CPC, Initially I considered not basing it on a Z80, but on an ARM7TDMI based simple micro-controller, (probably an STR710FZ2) running at 66MHz with 256 + 16 KB internal fast Flash and with 64K internal fast RAM and a separate external 32K VRAM. But early 2017 I changed my mind, because I wanted the ability to port software from various Z80 based homecomputers. [1]
The idea behind it is to bringing back a new homecomputer, such as they were popular in the 80's, but build with modern components, and using modern interfaces (VGA monitor instead of TV, SD-card storage devices instead of cassette recorders).
the Rhococo will support a simple SD-Card interface as storage, and will use a keyboard similar to the ZX81+34, but with more keys,and a more conventional keyboard imprint.
For sound I consider a PWM output. Or an emulated PSG (programmable sound generator). with at least similar capabilities to these used in the Amstrad CPC, spectrum + and MSX computers, but hopefully with capabilities not unlike a C64 SID chip.
It will be a "turn on and use" system, meaning that the "OS", and a programming language will permanently reside in ROM, ready the moment you turn the Rhococo on (Meaning it will be based on some kind of interpretative language), probably BASIC (if possible BBC BASIC).
It will not be yet another Linux based system, as I want something that can be completely understood, just like you could learn how any of the 80's homecomputers worked. It is deliberately a simple and limited system.
After a year or so contemplating this idea of a new homecomputer, I came to the conclusion that an ARM based system with software VGA generation might be too complex for a the simple system I have in mind. I will make a NEW homecomputer design with components that can be bought in 2017 (and hopefully the next few decades). It will be based on a Z80 compatible CPU as it is one of the few 8-bit CPU's that is still relatively easy to get, and it was so popular in the 80's that there is a plethora of software available for them. One thing I don't want is to use an FPGA for it, as these are still relatively expensive and difficult to program for. This does cause a problem, as most old homecomputers either used some kind of programmable logic (Sinclairs ULA logic) or were based around a CRTC like the MC6845, which are no longer available, or they used a VDC (video display controller) like the TMS9918 (MSX an many others) which are also no longer available. My preference would have been using a CRTC, but as I said I can find no CRTC's for sale anymore, I could build one with standard logic (like the TRS-80 did) but that's too RETRO even for me, (uses far too many components). Instead I'm wondering if I can replace the CRTC with an simple AT-mega (Arduino) microcomputer. For a 320 x 200 display you would need 320 / 8 = 40 8-pixel wide rows and 200 lines, which means you need 40 * 200 = 8000 address locations, this is about 8191 or 2 ^ 13, meaning you need 13 address lines to address these 8191 (or hex 0x1FFF) locations. and a couple of other signals like HSYNC and VSYNC and video clock. An Arduino (nano) uses an ATmega328, and doesn't really have that many GPO (output) ports, but that can be solved with a few 8-bit latches. I'm planning to do this in little steps, so first I'm planning to connect 8K Byte SRAM (or an EPROM for testing) to an Arduino nano, plus a shift register to clock out a video stream, to try to generate a 320 x 200 (monochrome) VGA signal, using a Arduino nano as a CRTC surrogate. Then continue from there.
Colors of wires are:
Thick Red, +5V
Red, Databus
Yellow, lower 8 address lines
Green, Higher 8 address lines
Blue, control signals
it works like this:
Adding a keyboard
Adding sound
About the keyboard
and this is the bottom:
I also finally found a suitable VGA text demo that worked on my Hydra, and it should also work on the propeller chip of rhocococ. The hydra uses a 10MHz crystal, not a 5MHz one like most other propeller system, and also has the VGA pins on an unusual range of pins, that makes that you need specially adapted versions of popular VGA drivers. I will use a 5MHz crystal for Rhococo (at least initially), and hopefully my choice for the VGA pin-group will not be a problem. In theory it should be easy to adapt VGA drivers for it, but we will have to wait and see how easy it will turn out in practice.
Supported screen resolutions:
I got a great idea, replace the Z80 with a -second- Propeller chip !!!
Luckily I still have not sent in the gerber files to create a PCB, as I suddenly had a brainwave. I was reading the site of "the 8-bit guy" which is a proficient you-tube vlogger specialized in retro computers, but he also has a web-site. I was reading there about his "ideal new home-computer", a subject near to my heart obviously. However his first requisite was that it should be 6502 based, and use "commodore BASIC" (read level 2 Microsoft basic with a screen editor). Now don't get me wrong, I like the idea of a screen editor, but the BASIC of a C64 was one of its biggest let-downs, it was exactly the same BASIC as the original Commodore PET, so very primitive. Still the request for a 6502 CPU wasn't so alien to me, I learned 6502 Assembler (on a MOS KIM-1) before I learned Z80 assembler, and I truly think its a great little CPU, and there are probably more home computers based on it than on the Z80. Unfortunately its very difficult to get your hands on one, so out of necessity I chose the Z80 instead. and yes, I do know the WDC 65816/65802 is still being made, but its not readily available to me. Then I remembered that there is code for the propeller to emulate both a Z80, and also a 6502, so why not use a propeller running a CPU emulator for the CPU of RhoCoCo. You can choose the CPU architecture you want, either Z80 OR 6502, or for that matter you could emulate an 6809 CPU too if you wanted, or an 1802 or any other 8-bit (or 16-bit) CPU.
The 40-pin propeller has four 8-bit ports, so you can emulate an 8-bit databus, plus a 16-bit (or 17-bit for 128K) address bus, with 7 or 8-bits left. 2 bits to interface the emulated CPU to RAM, another 2-bits to communicate serially with with the other propeller, leaving 3-bits for IRQ and other signaling (DMA between the two propellers).
sounds do-able, and offers much larger flexibility, such as direct 128K memory mapping with an emulated memory manager. with a real Z80 it should be possible to address 128K RAM, but only with a slow and convoluted method.
Because the CPU is emulated, you can do all kinds of special tricks that makes interfacing with the second propeller much easier.
And level converting is not necessary, as both chips run on 3V3.
I'm not going to give this version a new name, I will still call it simply RhoCoCo (not RhoCoCo 2 or ][ or something like it). Because the first version was never finished anyway.
I almost have the feeling that this idea was the last piece of the puzzle, that I felt was still missing, (perhaps the reason I hesitated to call the design finished) and now I found it.
