ZX81PLUS35 ZX81 clone
The ZX81+34 (previously called the ZX14, and ZX15) retro homecomputer is a much improved Sinclair ZX81 [1] clone built with the modern materials techniques and components of 2015.
As for now comments and questions on the design can be made here [2] (raspberry PI forum off topic section)  :-)
Introduction to the ZX81+34
The ZX81+34 is a much improved ZX81 that people can build themselves.
The ZX81+34 should be fully compatible with the original ZX81, but with the following improvements over the original ZX81 :
Current Status, from January to march 2015
At the moment the PCB of the first prototype has been designed, and is ready to be tested.
3D Preview of early ZX81+34
Schematic 81+34
The old (version 1) schematic of revision 2.0 (.PDF) can be found here: File:ZX81+34 schema.pdf
There is also a color coded schematic (.PDF), it can be found here: File:ZX81+34 kleur REV 2.0.pdf.
The Bill of Material (BOM) for the original ZX81+34 can be found here File:Z81+34 BOM.ods
Layout ZX81+34
Keyboard for ZX81+34
File:Nieuw keyboard ZX14.pdf
A version that supports the ZXPand can be downloaded here: File:New ZX81+34 keyboard ZXPand version.pdf
Alternative font for ZX81+34
The final ZX81+34
Starting the assembly
Finished assembly
Testing (continued)
After I finally managed to program an EEPROM, I started testing the device, unfortunately disaster struck immediately! I could not get the device powered up, and after some searching I found out I made a mistake in the creation of the footprint of the microUSB connector, that caused the reversal of the GND and 5V pins. This means that for some time (minutes) the whole device was fed with negative 5V, a disaster! From previous experience I know that most CMOS devices can survive this, with the exception of (older types) of EEPROM's which are often erased by feeding the wrong polarity of signals. The EEPROM used 28HC256 is more modern, so I have some hope it has survived, time will tell. P.S. I have since verified that the EEPROM indeed was not affected! Normally I add protection in the form of a 1N4001 diode between +5V and GND, but because voltage inversions normally cannot happen with an USB fed design I failed to take that precaution. :-(. A very bad start indeed, its possible that any and all CMOS logic was destroyed.
With the Z80 not running, I tried to debug the Z80 logic, and found that the very first instruction the EEPROM does after reset is an OUT,&FD instruction, but that OUT,&FD was not happening! Perhaps the Z80 was blown up. I found a bug, namely the reversal of VCC and output pins of U17 (single gate OR), I fixed that with a patch, but the OUT&FD was still not happening. I replaced the Z80 with an old 4MHz Z80 I had, but with no luck (no video). Careful examination of the schematics revealed a few other errors, explaining the lack of video. The SH/LD signal must be driven by pin 8, not pin 9 of U29B, The CSYNC signal should be an XOR of VSYNC and the inverted HSYNC, not HSYNC itself, so pin 1 of U21a must be tied to pin 11 not pin 13 of U21C, also the clock inputs of U28 were not driven by the /WR signal, as they should have. So I added the corrections to the schematic, and also switched the OTP in the schematic to the EEPROM I used. I posted the new revision 2.0 schematic here, and patched the board. Later I found that the pullups on the databus were 1K, I forgot to change them when I copy pasted them, leaving them at 1K cannot work, as the databus series resistance between memory and CPU is also 1K, so only halve the voltage arrives! Changed the pullup resistors to 22K, that should work. I still had to test if the patches I found, and the new Z80, have solved the problem, If not, I have to resort to using a logic analyser to find the problem, that would be a bummer! But no luck, my ZX81 clone still did not work. I finally gave up and tried a (simple 8-channel) logic analyzer, and quickly found that half the databus signals were permanently low. some databits, but not all, seemed to be driven low permanently by U1, the NOP driver. after removing U1 the databus seemed okay, but replacing U1 with a new one did not solve the defect. arrrgh.... That was the moment I decided not to search for more defects, probably lots of logic ports are blown up! But instead to take my losses, and immediatley create revision two of the ZX81+34 (even when it meant it would become a ZX81+35 in 2016) .
So without further ado, I present to you the first changes for ZX81+34 rev 3.0 AKA "version two".
ZX81+34 version TWO
Here is the new schematic: ZX81+34 rev 2.1 schematic.png A .PDF of the new schematic can be found here: File:ZX81+34 rev 2.1.pdf
3D preview version 2
Version 2.1
Version 2.2 (ZX81+35)
November 24, 2015; Just when I wanted to order new PCB`s I received a Tip from some ZX81 hardware experts that there was an "error" in my schematic.
