Revision as of 23:53, 23 November 2016 by Mahjongg (talk | contribs) (GND and VCC wiring on bottom of PCB, right hand side of picture is left hand site when the PCB is turned with buttons up, with the "cross buttons". The lower two rows of pins will be soldered to the GPIO header, with two rows of two holes on either sid...)
Original file(4,032 × 3,024 pixels, file size: 1.86 MB, MIME type: image/jpeg)
GND and VCC wiring on bottom of PCB, right hand side of picture is left hand site when the PCB is turned with buttons up, with the "cross buttons". The lower two rows of pins will be soldered to the GPIO header, with two rows of two holes on either side left over.
current23:53, 23 November 2016Thumbnail for version as of 23:53, 23 November 20164,032 × 3,024 (1.86 MB)Mahjongg (talk | contribs)GND and VCC wiring on bottom of PCB, right hand side of picture is left hand site when the PCB is turned with buttons up, with the "cross buttons". The lower two rows of pins will be soldered to the GPIO header, with two rows of two holes on either sid...
