Designing the RhoCoCo Retro Home COlor COmputer hardware
Project Rhococo Retro HOme COlor COmputer | |
A brand new 8-bit homecomputer with modern parts. Above picture is just an artist impression, its probably not at all how it will look. | |
Contact | Mahjongg |
Last Update | 2018-07-20 |
After a year or so contemplating this idea of a new homecomputer, I came to the conclusion that an ARM based system with software VGA generation might be too complex for a the simple system I have in mind. I will make a NEW homecomputer design with components that can be bought in 2017 (and the next few decades). It will be based on a Z80 compatible CPU as it is one of the few 8-bit CPU's that is still relatively easy to get, and it was so popular in the 80's that there is a plethora of software available for them. One thing I don't want is to use an FPGA for it, as these are still relatively expensive and difficult to program for. This does cause a problem, as most old homecomputers either used some kind of programmable logic (Sinclairs ULA logic) or were based around a CRTC like the MC6845 which are no longer available, or they used a VDC (video display controller) like the TMS9918 (MSX an many others) which are also no longer available. My preference would have been using a CRTC, but as I said I can find no CRTC's for sale anymore, I could build one with standard logic (like the TRS-80 did) but that's too RETRO even for me, (uses far too much components). Instead I'm wondering if I can replace the CRTC with an simple AT-mega (Arduino) microcomputer. For a 320 x 200 display you would need 320 / 8 = 40 8-pixel wide rows and 200 lines, which means you need 40 * 200 = 8000 address locations, this is about 8191 or 2 ^ 13, meaning you need 13 address lines to address these 8191 (or hex 0x1FFF) locations. and a couple of other signals like HSYNC and VSYNC and video clock. An Arduino (nano) uses an ATmega328, and doesn't really have that many GPO (output) ports, but that can be solved with a few 8-bit latches. I'm planning to do this in little steps, so first I'm planning to connect 8K Byte SRAM (or an EPROM for testing) to an Arduino nano, plus a shift register to clock out a video stream, to try to generate a 320 x 200 (monochrome) VGA signal, using a Arduino nano as a CRTC surrogate. Then continue from there.
Colors of wires are:
Thick Red, +5V
Red, Databus
Yellow, lower 8 address lines
Green, Higher 8 address lines
Blue, control signals
it works like this:
Adding a keyboard
Adding sound
updated first on July 4, then on July 18, 2018. The first (main) sheet is here: File:RHOCOCO MAIN PROPELLER.pdf its the main sheet with the propeller chip and VGA output, and a sub-sheet for the Z80 and its RAM, and now also keyboard I/O The second (sub) sheet is here: File:RHOCOCO Z80CPU with RAM.pdf its the sub-sheet with the Z80 and its RAM running at 5V, the 74HCT574 is used to latch the lower 8 address lines when an I/O request is pending, and can be read while converting the data to 3V3 levels. The third sheet File:RHOCOCO KEYBOARD with Joystick.pdf contains keyboard I/O and joystick interface, note that three new keys can be added (compared to a spectrum), plus the joystick can be copied as cursor keys, plus a few more keys compared to a spectrum.
P16 to P23 of the propeller are used for the VGA output signals. So the propeller chip is capable of producing 64 colors per pixel, 8 times as many as a spectrum. Audio output is supported, as well as an SD-card (through the use of an I2C I/O expander).
the Z80 (running at 5V) with its 128K (two banks of 64K) RAM, and a latch that can capture the lower 8-address-lines during an I/O (write or read) operation, during the I/O operation the propeller can read out the data, and then the 8 address lines for an I/O write, or can read out the addresses, then put 8-bit data on the Z80 data bus for an I/O read operation. added an I/O, and memory, expansion port, for now its based on the ZX81 expansion port, but that will probably change, as it will get one unique to the Rhococo.
The keyboard interface, also supports a joystick.
The fourth sheet covers a separate PCB, its compatible with a spectrum, but slightly extended with cursor keys, and a CTRL button, which duplicates as the fire button. this is the schematic:
About the keyboard
