ZX81plus38 simple to build ZX-81 clone
Revision as of 11:21, 7 October 2019 by Mahjongg (talk | contribs)
Project ZX81plus38
Error creating thumbnail: File with dimensions greater than 12.5 MP
Most people I showed my ZX-81 clone (ZX81+35) said they liked it, but with such a tiny board and with so many "difficult" surface mount components, they they doubted whether they would be able to build this kit, so I restarted my effort, to try to build a 100% ZX-81 clone that anybody could build, with commonly available parts.
Status Initializing
Contact mahjongg
Last Update 2019-10-07
October 1, 2019 continued
Yesterday I finished placing of the mounting holes in the PCB, today I mostly finished the schematic, here is the updated .PDF. File:ZX81plus38.pdf
