File:PSG for ZX81+35 REV 1.4.pdf
Revision as of 21:08, 24 July 2016 by Mahjongg (talk | contribs) (revised version with resistor dividers between PSG and SD-card slot to convert 5V PSG levels to 3V3 SD-card levels, datalines are pulled up clock and latch lines not (pulled low by resistor divider).)
PSG_for_ZX81+35_REV_1.4.pdf(file size: 23 KB, MIME type: application/pdf)
Date/TimeDimensionsUserComment
current22:28, 24 July 2016 (23 KB)Mahjongg (talk | contribs)corrected resistor values, so that SD can actually pull down level on PSG below logic low level of PSG.
21:08, 24 July 2016 (23 KB)Mahjongg (talk | contribs)revised version with resistor dividers between PSG and SD-card slot to convert 5V PSG levels to 3V3 SD-card levels, datalines are pulled up clock and latch lines not (pulled low by resistor divider).
