Designing the RhoCoCo Retro Home COlor COmputer hardware
Project Rhococo Retro Home COlor COmputer | |
Status | Initializing |
Contact | Mahjongg |
Last Update | 2017-04-18 |
Less is more, less complexity, more fun is the driving force behind the Rhococo Retro Home COlor Computer. It will be a remake home-computer inspired on the Sinclair spectrum, but not based on a Z80, but on an ARM7TDMI based simple micro-controller, (probably an STR710FZ2) running at 66MHz with 256 + 16 KB internal fast Flash and with 64K internal fast RAM and a separate external 32K VRAM. The idea behind it is no less than bringing back the home computer of decades past. It will be capable of 320x200 VGA full high resolution graphics 16 colour display (Mode "D" timings, 70Hz, Horizontal Sync = 31.778 KHz, pixel clock 25.175 MHz).
To be able to keep the design simple, but still able to be drive a VGA monitor, I chose to support only the lowest VGA resolution of 320 x 200 with 16 colours. It means we only need to have, (and manipulate) a 256000 bit (32K) frame buffer. The display logic will be designed to read out four bytes (a 32 bit "word") in the time assigned to eight consecutive pixels, three bytes will be shifted to the Red, Green an Blue colour inputs, and one to the intensity input, giving sixteen colours per pixel. Preferably the "glue logic" for it will consist of standard logic, but if necessary I will consider a small FPGA.
For sound the ARM chip will offer a PWM output.
It will be a "turn on and use" system, meaning that the "OS", and a programming language will permanently reside in ROM, ready the moment you turn the Rhococo on.
For the moment (quarter 4 2015) the Rhococo has been stalled, as I have problems getting the ZX81+34 ZX81 clone to work. Now working on version two.
April 18, 2017 Changed my mind, will try to build a color Z80 more "home computer" like design with a CRTC not software driven
After a year or so contemplating this I came to the conclusion that an ARM based system with software VGA generation might be too complex for a the simple system I have in mind. I will make a NEW homecomputer design with components that can be bought in 2017 (and the next decades). It will be based on a Z80 compatible CPU as it is one of the few 8-bit CPU's that is still relatively easy to get, and it was so popular in the 80's that there is a plethora of software available for them. One thing I don't want is to use an FPGA for it, as these are still relatively expensive and difficult to program for. This does cause a problem, as most old homecomputers either used some kind of programmable logic (Sinclairs ULA logic) or were based around a CRTC like the MC6845 which are no longer available, or they used a VDC (video display controller) like the TMS9916 (MSX an many others) which are also no longer available. My preference would have been using a CRTC, but as I said I can find no CRTC's for sale anymore, I could build one with standard logic (like the TRS-80 did) but thats too RETRO even for me. Instead I'm wondering if I can replace the CRTC with an simple AT-mega (Arduino) microcomputer.
