ZX81plus38 simple to build ZX-81 clone
Project ZX81plus38 | |
Most people I showed my ZX-81 clone (ZX81+35) said they liked it, but with such a tiny board and with so many "difficult" surface mount components, they doubted whether they would be able to build this kit, so I restarted my effort, to try to build a 100% compatible ZX-81 clone that anybody could build, but now with commonly available pin-through-hole parts. | |
Contact | mahjongg |
Last Update | 2021-04-26 |
P.S. No I won't!
October 1, 2019 continued
January 28, 2020
February 12, 2020
February 19, 2020
February 26, 2020
March 4, 2020 layout finished
and this is the bottom layer:
and bottom view
March 16, RefSpace is closed!
The jumpers are:
and bottom:
my GitHub page is here: [2]
I managed to work from home
Now the clone should work.
and bottom:
and this is the bottom side:
If you want to communicate with me you can post in the ZX81plus38 thread I have on the raspberry PI forum here: https://www.raspberrypi.org/forums/viewtopic.php?f=62&t=254492 if it locks (it will automatically be locked after 180 days of inactivity) click on the flag icon above the post to flag a moderator, and ask to unlock the thread.
