ZX81plus38 simple to build ZX-81 clone
| Project ZX81plus38 | |
| Most people I showed my ZX-81 clone (ZX81+35) said they liked it, but with such a tiny board and with so many "difficult" surface mount components, they doubted whether they would be able to build this kit, so I restarted my effort, to try to build a 100% compatible ZX-81 clone that anybody could build, with commonly available pin-through-hole parts. | |
| Contact | mahjongg |
| Last Update | 2020-10-18 |
P.S. No I won't!
October 1, 2019 continued
January 28, 2020
February 12, 2020
February 19, 2020
February 26, 2020
March 4, 2020 layout finished
and this is the bottom layer:
and bottom view
March 16, RefSpace is closed!
The jumpers are:
and bottom:
my GitHub page is here: [2]
I managed to work from home
Now the clone should work.
and bottom:
A new found error makes Revision 1,6 necessary
We (the members of the microcontroller.net forum) have found another small error. The keyboard matrix uses address line A8 to A15, but A8 of this range of signals goes through a 10K resistor (signal is called A8' ) this is wrong! Just as A9 to A15 do not go through a 10K resistor so shouldn't A8 go through a resistor, as otherwise the data-line driven by A8 cannot pull the signal to nearly ground level, but only to about halfway (both pullup and pulldown resistors are 10K). So the layout must be changed so that A8' becomes just A8.
and this is the bottom side:
File:PCB PrevIew ZX81+38 rev 1,6 bottom.png
