ZX81plus38 simple to build ZX-81 clone
Project ZX81plus38
Most people I showed my ZX-81 clone (ZX81+35) said they liked it, but with such a tiny board and with so many "difficult" surface mount components, they doubted whether they would be able to build this kit, so I restarted my effort, to try to build a 100% ZX-81 clone that anybody could build, with commonly available pin-through-hole parts.
Status Initializing
Contact mahjongg
Last Update 2020-02-18
October 1, 2019 continued
px800
The easy part is done, routing now becomes more difficult. Ratsnest ZX81 plus 38 14 jan 2020.png
January 28, 2020
February 12, 2020
February 19, 2020
