Designing the RhoCoCo Retro Home COlor COmputer hardware
Project Rhococo Retro Home COlor COmputer | |
A brand new 8-bit homecomputer with modern parts. Above picture is just an artist impression, its probably not how it will look. | |
Contact | Mahjongg |
Last Update | 2018-07-13 |
April 18, 2017 Changed my mind, will try to build a Z80 based more "home computer like design", with a CRTC, and not software driven
After a year or so contemplating this idea of a new homecomputer, I came to the conclusion that an ARM based system with software VGA generation might be too complex for a the simple system I have in mind. I will make a NEW homecomputer design with components that can be bought in 2017 (and the next few decades). It will be based on a Z80 compatible CPU as it is one of the few 8-bit CPU's that is still relatively easy to get, and it was so popular in the 80's that there is a plethora of software available for them. One thing I don't want is to use an FPGA for it, as these are still relatively expensive and difficult to program for. This does cause a problem, as most old homecomputers either used some kind of programmable logic (Sinclairs ULA logic) or were based around a CRTC like the MC6845 which are no longer available, or they used a VDC (video display controller) like the TMS9918 (MSX an many others) which are also no longer available. My preference would have been using a CRTC, but as I said I can find no CRTC's for sale anymore, I could build one with standard logic (like the TRS-80 did) but that's too RETRO even for me, (uses far too much components). Instead I'm wondering if I can replace the CRTC with an simple AT-mega (Arduino) microcomputer. For a 320 x 200 display you would need 320 / 8 = 40 8-pixel wide rows and 200 lines, which means you need 40 * 200 = 8000 address locations, this is about 8191 or 2 ^ 13, meaning you need 13 address lines to address these 8191 (or hex 0x1FFF) locations. and a couple of other signals like HSYNC and VSYNC and video clock. An Arduino (nano) uses an ATmega328, and doesn't really have that many GPO (output) ports, but that can be solved with a few 8-bit latches. I'm planning to do this in little steps, so first I'm planning to connect 8K Byte SRAM (or an EPROM for testing) to an Arduino nano, plus a shift register to clock out a video stream, to try to generate a 320 x 200 (monochrome) VGA signal, using a Arduino nano as a CRTC surrogate. Then continue from there.
Ik denk dat ik eerst maar eens de $4 4-chip Z80 homemade computer ga nabouwen, en daarmee ga experimenteren. This is its schematic: File:Z80 with AVR schematic.pdf
Some thoughts
Colors of wires are:
Thick Red, +5V
Red, Databus
Yellow, lower 8 address lines
Green, Higher 8 address lines
Blue, control signals
Anyway, for the moment I ignored the problem, and made a conceptual drawing of RHOCOCCO where I replaced the ATMega CPU with a Propeller, here is the new schematic: File:RHOCOCO with propeller.pdf.
Via Z80 I/O and specially written routines, I should be able to access all of the Z80's RAM, so I can upload code. As a basis the rhococco should be a bit like a sinclair spectrum, TRS-80 or MSX.
it works like this:
I think it should be possible to power the Z80's at 5V, and use a simple resistor divider to lower voltages between Z80 and Prop to 3V3, while providing the full prop ViH voltage to the Z80. I think these dividers are only necessary for signal the prop reads, like data and /RD /WR and /IORQ. I think 2K2, and 3K3 will suffice.
When a port read or port write operation is requested by the Z80 the Propeller chip stops the Z80 master clock. The 74HC165 parallel to serial register is used to read the 8 bit port address from the Z80 address buss. If the Z80 requests a port write operation the 8 bit data value is read directly by the Propeller chip from the Z80 data buss. The Propeller chip uses the supplied port address and executes the required code to complete the request. If the Z80 performed a port read operation the resultant data is placed on the Z80 data buss and and the Z80 is clocked until the /RD line is set high by the Z80. If the Z80 performed a port write operation the Z80 is clocked until the /WT line is set high by the Z80. Finally the Propeller chip starts the Z80 master clock and goes back to waiting for an I/O port operation.
A relevant change compared to the original design of the simple CP/M system is that I insist that I must support a video framebuffer in the Z80 memory map. Only this will allow the fast video updating that is necessary for engaging video gameplay, (although it must be said that it should be possible to use an I/O driven video sub-processor system like the TMS9914 based systems (like MSX) use).
so on top of the above boot and I/O interface structures, I will need hardware to scan (read) through an 8K (&H1FFF) section from &H4000 to &H5FFF from the RAM chip, so a 13-bit address range (8192 Bytes). with 3 address lines fixed (with weak pullup/pulldown resistors). Either a 13-bit counter, or a 8-bit counter, with a 5-bit latch. Actually, the original idea was to use an 8-bit counter and an 8-bit latch, so we can put the video framebuffer anywhere in the 64K memory space, and use any size we want. We don't need to put the Z80 in tri-state mode, as we can just use the same trick the spectrum uses, with isolation resistors in the address lines (and other lines we need to drive to read from the RAM) (note that I have found a simpler solution later).
Adding a keyboard
I tend to prefer the first method, as more "pure" way to do it, without using things that are already becoming hard to get now (PS/2 keyboards) which will become impossible to get in the future.
Adding sound
Because I think the schematic will be too big for a "flat file" (single sheet) schematic, even on an A3 sheet, I have now split the schematic into two sheets. A main sheet (with the propeller chip), and (for now) one sub sheet, containing the Z80 8-bit CPU, and the (128K) RAM chip, both running on a separate +5V supply. Z80 and propeller share the data-bus, using a resistor divider, (on each data-line) which divides 5V data signals to about 3V for the 3V3 powered, and not 5V tolerant Propeller chip, while 3V3 ViH propeller data reaches the Z80 essentially unmitigated (and so satisfies its ViH levels). when the propeller needs to set up addresses to the RAM chip, or wants to read which I/O address the Z80 tries to access, interface logic takes care of that, which logic is 5V tolerant, and also acts like logic level translators.
July 4, 2018 First two sheets (concept) schematic
updated on July 11, 2018. The first (main) sheet is here: File:RHOCOCO MAIN PROP.pdf its the main sheet with the propeller chip smf VGA output, and a subsheet for the z80 and its RAM, and now also keyboard I/OThe second (sub) sheet is here: File:RHOCOCCO Z80CPU with RAM.pdf its the sub-sheet with the Z80 and its RAM running at 5V, the 74HCT574 is used to latch the lower 8 address lines when an I/O request is pending, and can be read while converting the data to 3V3 levels.
P16 to P23 of the propeller are used for the VGA output signals.
the Z80 (running at 5V) with its 128K (two banks of 64K) RAM, and a latch that can capture the lower 8-address-lines during an I/O (write or read) operation, during the I/O operation the propeller can read out the data, and then the 8 address lines for an I/O write, or can read out the addresses, then put 8-bit data on the Z80 data bus for an I/O read operation.
July 9, 2018 Had a new idea on how to read out RAM
I updated the two .PDF's, (ie: RHOCOCO MAIN PROP.pdf and : RHOCOCCO Z80CPU with RAM.pdf ) and the above schematics. Refresh the page if you don't see a VGA connector on the main sheet. The new main sheet now has VGA and sound (PWM) output and an EEPROM, the two address latches were removed as they are no longer needed (because we will use the NMI triggered memory to IOWR copy routines.) The Z80 + RAM (and now keyboard) sheet has also been revised. The simple boot method is supported, and address lines A0 to A7 are latched on any IO request, and can be read-out by the Propeller to distinguish between various IO request types. The same keyboard matrix system is used as a spectrum, (drawn on a new sub-sub-sheet) and an IO-READ to a keyboard read location can be captured, and the keyboard-scan data can then be pushed onto the Z80 data-bus to finish the IO-READ instruction.
P.S. Corrections: SRAM is not a 628128 but a (DIP-32) AS6C1008, and has to run at a somewhat lower voltage (4.5V) as its ViH = 0.7 x VCC, or 3.5V for 5V. 4.5V would be fine as 4.5V would mean that ViH becomes 3.15V. Use a simple diode to lower VCC for the RAM. The ram can function between 2.7 and 5.5V. its VoH is 2.2V minimal, which is just enough for a Z80 at a load of 1mA meaning for a 2.2V a resistance to ground of R=V/I of 2.2/0.001 = 2K2, so the resistance dividers which are now 470 Ohm plus 680 Ohm = 1150 Ohm, should be doubled to 1K and 1K5 (2K5 total). The RD# WR# and WREQ# signals must be routed directly to the RAM, NOT through the resistor divider! to overrule them with the propeller chips another solution must be found. Probably we don't need to take precautions to connect these signals directly to the propeller, maybe all we need are a few 1K series resistors between the Z80 and RAM , but not a resistor divider. For the keyboard I/O we can use a 74HCT365 hex 3-state driver, we only ever need D0 to D4 and maybe use D5 for joystick switches, so a hex driver is enough, and nice and small. Don't use a whole 74HCT04 for a task that can be solved with a single 2N7000 FET, and a pullup resistor. Remember, use HCT logic, as its ViH is guaranteed 2.0V, not 0.7 x VCC as HC logic.
